J Clow
Problem with Transitions
Mar 12, 2012 1:55 PM
Currently, I have the code below (keep in mind that I only posted relevant parts).
          <s:states>
                    <s:State name="preCopy" />
                    <s:State name="optionsState" />
          </s:states>
          <s:transitions>
                    <s:Transition fromState="*">
                              <s:Parallel>
                                        <s:Parallel filter="show">
                                                  <s:Fade alphaFrom="0" alphaTo="1"  duration="3000"/>
                                                  <s:Move yBy="-10" duration="3000" easer="{powerEasing}" />
                                        </s:Parallel>
                                        <s:Resize target="{appPanel.contentGroup}" duration="600" easer="{powerEasing}"/>
                              </s:Parallel>
                    </s:Transition>
          </s:transitions>
          <s:Panel title=" fooBar "
                                id="appPanel"
                                minHeight="0"
                                x="10"
                                y="10">
                    <s:VGroup includeIn="preCopy"
                                          paddingBottom="10"
                                          paddingLeft="10"
                                          paddingRight="10"
                                          paddingTop="10"
                                          width="160"
                                          horizontalAlign="center">
                              <s:Button label="Start Copy Now" click="startCopyNow(event)" />
                              <s:Label id="timeToCopyTxt" />
                              <s:Button label="Stop Autostart" click="mouseStopAutostart(event)" />
                              <s:Button label="Options" click="openOptions(event)" />
                    </s:VGroup>
                      <s:Form includeIn="optionsState">
                              <s:layout>
                                        <s:FormLayout gap="-14"
        paddingBottom="-5"
        paddingLeft="-10"
        paddingRight="-20"
        paddingTop="-5" />
                              </s:layout>
                              <s:FormItem label="Load Location">
                                        <s:TextInput id="loadInput" text="{loadDir}" width="200" change="loadDir = loadInput.text" />
                              </s:FormItem>
                              <s:FormItem label="Save Location">
                                        <s:TextInput id="saveInput" text="{saveDir}" width="200" change="saveDir = saveInput.text"/>
                              </s:FormItem>
                              <s:FormItem label="Extra Folders">
                                        <s:NumericStepper id="extraFInput" value="{extraFolders}" change="extraFolders = extraFInput.value"
                                        snapInterval="1" minimum="0" maximum="100" />
                              </s:FormItem>
                              <s:FormItem>
                                        <s:Button label="Close Options" click="copyPrep()" />
                              </s:FormItem>
                    </s:Form>
          </s:Panel>
When going between the two states, my panel shows its transition correctly, but the buttons that are now on the screen do not show the transition I gave to them (the fade in transition and move transition). How do I fix that?
Thanks.
    Mar 12, 2012 2:22 PM   in reply to J Clow
    I do not see them added to the targets property of the transision? did you add them?
