M.Cummins
<cfexchangeconnection />
Mar 12, 2012 3:40 PM
Tags: #/> #<cfexchangeconnection
I haven't been able to get this to work on Exchange 2010 SP1 yet.
Right now the error I am getting is "Exchange Server doesn't support the requested version".
Any advice?
    Mar 12, 2012 9:32 PM   in reply to M.Cummins
         Could you post the code that you are using for connecting to the Exchange server?
    Regards,
    Paul
    Mar 12, 2012 10:44 PM   in reply to M.Cummins
    Make sure to specify the attribute serverversion="2010" while creating the exchange connection.
    Mar 13, 2012 6:54 AM   in reply to M.Cummins
    M. Cummins,
    According to the release notes, if you do not specify the details Exchange 2007 is the default.
    There are two ways to specify what version of exchange to use.
    1. In the CFApplication tag in your application.cfc you can specify exchangeServerVersion="2010"
    2. At the tag level in any of the cfexchange tags you can add serverVersion="2010"
    Try that and let us know if it works!
    Tim Cunningham
    Mar 13, 2012 11:22 PM   in reply to M.Cummins
    Could you try accessing the EWS wsdl in the browser?
    https://fqdn.server.net/ews/Exchange.asmx
    Provide the username and password in the pop up box and share me the wsdl. I will check it.
    Paul
    Mar 14, 2012 2:28 AM   in reply to M.Cummins
    I dont need the username/password.
    This is the EWS WSDL. This will be available with all the exchange servers. There are no sensitive informations in it. This contains the details about the operations that you can do on exchange server using EWS. These details are already publically available in MSDN library.
    Also if you could get me the exception stack traces from the exception.log, it would be more helpful.
    Paul
