Tabs
Mar 14, 2012 8:07 AM
Hope you're well.
I am having some difficulty with tabs.
This example will help explain what I'm having trouble with
     *jjhkjhkjkjhkjkjkjhkjhkjhkjhkjhkjhkjhkjhkjhkjh
      kjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjl
I'm working on a resume. In the job description sections, I have the first line tabbed, add an asterisk and then start typing. On the following line, I tab again, this time to the same spot as the beginning of the text in the seconf line.
However, there are times when if I try to tab the second line to line up with the text of the first it just won't line-up. I'm lining-up the tab with all the others that have tabbed correctly.
Also, there are other times when the first line will go fine, and then I get to the second line and tab it and it ends up taking the first line with it (tabs it to the same spot.)
Any idea what's going on?
Thanks very much.
    Mar 14, 2012 8:19 AM   in reply to graph22
    Can't really tell a thing without seeing at least a screen shot of the document with non-printing characters showing, but I'm guessing you are using the tabs to try to indent the paragraph. That's not the way it's done. Instead add a left indent to the paragraph attributes, or better, to the style. Tabs should be used for making things that look like tables.
    Mar 14, 2012 9:50 AM   in reply to graph22
    As I said, we need to see screen shots of the InDesing pages, with non-printing characters showing.
    Most likely you still either have extraneous tabs, or you have used soft returns, or you've got a "based on" style that is picking up the left indent, but I can't tell by looking at what you've posted.
    if the headings are part of the same paragraph as what follows, you can apply a left indent to the entire paragraph, and a negative indent to the first line (in that order or ID will complain). There shold be NO tabs or inserted spaces at the start of any lines to adjust positioning.
    By the way, I'm curious why you are using InDesign to do this. Virtually nobody will accept a resume in InDesign format, and very few places will accept a PDF. Word is the near-univarsally requested format for digital submission.
    Mar 14, 2012 9:55 AM   in reply to graph22
    For this kind of formatting, you want to use a hanging indent. This does not require using a tab for positioning the second line. Screen capture shows 2 places to setup the hanging indent: tabs panel, paragraph panel. After establishing the desired format, create a paragraph style to use for other the bullets, but you will need to remove any previously inserted tabs.
  • Rob Day
    Oct 16, 2007
    Mar 14, 2012 1:25 PM   in reply to graph22
    There's no need to use tabs for a paragraph indent, use the Paragraph panel's Left Indent instead. You could have an indent for the first line and a different indent for the subsequent lines like this (.25" for the asterisk line and .33"for the others):
    Or, you can have one indent and hang the asterisk by setting an Optical Margin Alignment in the Story panel like this:
  • Rob Day
    Oct 16, 2007
    Mar 14, 2012 1:41 PM   in reply to Rob Day
    Also, if you want the indents to happen automatically as you type, set up 3 paragraph styles. One for the first paragraph with no indent, one for the asterisk line, and one for other lines with the extra indent. Set the first line style's Next Style to the asterisk line's style, and the asterisk style's Next Style to the extra indent style.
