Can not run flexunit tests from ant
Mar 14, 2012 9:39 AM
Tags: #flexunit #ant
Hello,
I'm trying to script test execution in order to integrate tests in Jenkins. I followed the wiki article here http://docs.flexunit.org/index.php?title=Ant_Task
The tests run successfully with Flash Builder but not with ant. I'm getting the following error:
Error
VerifyError: Error #1014: The class flash.filesystem::FileStream could not be found
I think that this occurs because I'm using the flashplayer_11 as suggested in the wiki article and flashplayer does not load the airglobal.swc component.
I noticed that Flash Builder launches the ADL.exe process; whereas flexunit within ant tests launches flashplayer.exe.
Should I use ADL.exe with flexunit instead of Flash player ? In that case how to use adl argument in flexunnit ? I saw that Richard Lee has committed a fix to make flexunit support ADL arguments, how ?
Is there a solution to my problem ?
Thanks in advance.
Ygor
    Mar 14, 2012 10:11 AM   in reply to Ygor Marwen
    Ygor,
    It seems like you might be using the AIRCIListener... which requires AIR. You really just need the CIListener, which is the one you would use if you launch in Flash Player
