Cross Dissolve Problem
Mar 14, 2012 9:03 AM
Tags: #cross_dissolve
Can someone help me figure out when I put a cross dissolve at the beginning of my movie it starts at 100% black, then a quick jump to 80% black, then it cross dissolves into the clip.
I can’t figure out why this jump in black happens.
I attached a visual example so you can see the difference in the blacks.
Thanks.
    Mar 14, 2012 9:30 AM   in reply to jasonjam
    Best guess is the linear light processing used with GPU acceleration.
    Try turning that off.
    Mar 14, 2012 12:31 PM   in reply to jasonjam
    Hardware acceleration is a Project Setting (under General).
    On a side note, how is W8 running?  Do the Adobe and other programs run OK?
    Mar 15, 2012 7:27 PM   in reply to jasonjam
    You're not using CS5 or 5.5, are you?
    Mar 15, 2012 8:35 PM   in reply to jasonjam
    Firstly, don't cross dissolve from nothing. Create a black video (you can do this in your project panel), and drop it on the timeline before the video clip. Make sure there isn't any space between your black video, and clip. Double check to make sure you've got enough frames at the beginning of the clip, so as the cross dissolve has enough frames to process.
    Make sure that there's no clips above or below the cross dissolve.
    Apply your cross dissolve. Hopefully this should fix any bugs.
