kiranddd
Bulk Copy issue
Mar 14, 2012 9:50 PM
Tags: #cq5 #crx #cq
I am trying to copy parent node in CRX using workspace.copy , parent node has around 1L child nodes...
Below is the error message....
14.03.2012 09:14:19 *ERROR* TarPersistenceManager: Failed to read bundle: 22cab9bb-3dad-40ae-aa53-cd8e66eba562: java.io.IOException: File not found: 47 (TarPersistenceManager.java, line 1194)
        at com.day.crx.persistence.tar.TarSet.getInputStream(TarSet.java:731)
        at com.day.crx.persistence.tar.TarSet.getInputStream(TarSet.java:724)
Can somebody please help me...
Regards,
kiran
    Mar 18, 2012 12:39 AM   in reply to kiranddd
    How many is 1L?
    Why are you using workspace copy? (c.f. rule 3 of http://wiki.apache.org/jackrabbit/DavidsModel)
    What are you trying to achieve?
    your tar indexes seem corrupted. Stop your server, back everything up, remove index*.tar, start the server again (but you should first answer the questions below in order to see if you're on the good way).
    Mar 20, 2012 3:36 AM   in reply to kiranddd
    Mmm, i guess that if you're using CQ, your application is more or less related to WCM :-), so you have  content and scripts?
    Is this the whole content (business content + rendering scripts) you want to branch?
    Do you want to use your several branches through CQ, or just the last one?
    The next question i risk to ask you from your answers (no suspense then) is : couldn't you have each branch in separate nodes of the same workspace? (which makes sense if you don't use update/merge apis)
