Gipto
Numbers to Text
Mar 15, 2012 1:37 PM
I'm a acrobat x pro and i need a javascript to convert number to text in a field form,
there's some way to make that?
sorry for my english i know that is bad...
    Mar 15, 2012 8:34 PM   in reply to Gipto
    When I purchased Acrobat 4 there were samples on the distribution CD and one of them was a check which had an amount field and text field for the number in words. The text field was read only and called the document level function "ConvertToWords" that had an imput parameter of the number and returned the words for the number.
    aTens = [ "Twenty", "Thirty", "Forty", "Fifty", "Sixty", "Seventy", "Eighty", "Ninety"];
    aOnes = [ "Zero", "One", "Two", "Three", "Four", "Five", "Six", "Seven", "Eight", "Nine",
      "Ten", "Eleven", "Twelve", "Thirteen", "Fourteen", "Fifteen", "Sixteen", "Seventeen", "Eighteen",
      "Nineteen" ];
    function ConvertToHundreds(num)
       var cNum, nNum;
       var cWords = "";
       num %= 1000;
       if (num > 99) {
          /* Hundreds. */
          cNum = String(num);
          nNum = Number(cNum.charAt(0));
          cWords += aOnes[nNum] + " Hundred";
          num %= 100;
          if (num > 0)
             cWords += " and "
       if (num > 19) {
          /* Tens. */
          cNum = String(num);
          cWords += aTens[nNum - 2];
          num %= 10;
          if (num > 0)
             cWords += "-";
       if (num > 0) {
          /* Ones and teens. */
          nNum = Math.floor(num);
          cWords += aOnes[nNum];
       return cWords;
    function ConvertToWords(num)
       var aUnits = [ "Thousand", "Million", "Billion", "Trillion", "Quadrillion" ];
       var cWords = (num >= 1 && num < 2) ? "Dollar and " : "Dollars and ";
       var nLeft = Math.floor(num);
       for (var i = 0; nLeft > 0; i++) {
           if (nLeft % 1000 > 0) {
              if (i != 0)
                 cWords = ConvertToHundreds(nLeft) + " " + aUnits[i - 1] + " " + cWords;
              else
                 cWords = ConvertToHundreds(nLeft) + " " + cWords;
           nLeft = Math.floor(nLeft / 1000);
       num = Math.round(num * 100) % 100;
       if (num > 0)
          cWords += ConvertToHundreds(num) + " Cents";
       else
          cWords += "Zero Cents";
       return cWords;
