I'm excited to say that we have video working with FMG!
At this point we are experiencing a problem that I'm hoping for some insight into: The video breaks up a lot.
We have tried adjusting many of the values in rtmp.xml. We have tried all the different options in videoqualitylevels.xml.
It is definitely a bit better when using the "low" profiles and worse with the "high" profiles but we do not think it is a bandwidth issue as we can pull a lot more bandwidth from the same server if we pull a high bandwidth VOD or live stream originating from FMLE.
We are seeing the following in our SipLogs.
03:07:14.817 -ERROR - PARSER - SIP Parser Error : Syntax Error, line 1, column 16 of the header value
03:07:14.817 -ERROR - PARSER - SipParserStartParsing - Syntax Error - The parser failed to parse line 1
03:07:14.817 -ERROR - MESSAGE - ParseHeader - header 0x0x7f29a496ecd0. Failed to parse stand-alone header. (rv=-3000)
03:07:14.817 -ERROR - MESSAGE - MsgParserParseStandAloneHeader - Failed to parse header 0x0x7f29a496ecd0
03:07:14.817 -ERROR - TRANSACTION - RvSipTransactionMake - Transaction 0x0x69cbc0: Failed to parse from header - bad syntax (rv=-3000)
Could this be related?
If not, what are these errors, and how can we solve them?
Are there other approaches to solving video-breakup isues?
Sincerely,
Greg P.
Greg,
This is a known issue. The severity of experience decreases with lower compexity video & frequency matches with keyframe. Apart from that, not much tweak are possible at this point. We are planning to fix it in upcoming releases.
What type of call your usecase involves, an interactive video call or one way video delivery?
-Pankaj
North America
Asia Pacific
