NortelT
if or else statement
Mar 16, 2012 12:55 PM
I have a dropdown with yes or no in the list when "yes" is selected I want a textfield to appear.
(dropdown is named "Snow" and the textfield is named "Ifyes"
I have the following code
if (Snow.rawValue == "1")
           Ifyes.presence = "visible";
else
          Ifyes.presence = "hidden";
It is not working in the "Change" Event
    Mar 16, 2012 7:02 PM   in reply to NortelT
    This will not work in the change event as Snow.rawValue does not contain the correct value since the form is the process of changing it. Only when the change action has completed does the rawValue contain the correct updated value. Instead the object change value is stored in an xfa.event object. xfa.event.newText contains the newly selected item of the drop down ( the display string) so it would be
    if ( xfa.event.newText == "Yes")
    if you bind display values to item values in the dropdown, it would be
    if ( this.boundItems ( xfa.event.newText ) == "1" )
    Mar 19, 2012 2:46 PM   in reply to NortelT
    You could add a textfield and put your script that textfield's change event and then make that new textfield invisible.  Just make sure that your bracket after "else" is the correct way.
    Mar 20, 2012 7:43 AM   in reply to NortelT
    The javascript syntax is incorrect for the if statement. Should be something like
    if ( this.boundItems ( xfa.event.newText ) == "1")
    else
    Have you got the dropdown items set to "1"? and set the script to javascript?
    Mar 20, 2012 9:42 AM   in reply to NortelT
    Oops, my bad. It should be this.boundItem and not this.boundItems. Just remove the s and it should work
