How do I pick the right sequence preset? Premiere Pro CS4
Mar 17, 2012 6:23 AM
Tags: #presets #codecs #premiere_pro_sequence_settings #premiere_pro_cs4
I'm really struggling with sequence presets. I have tried matching details from media info with presets, but my exports still don't look right. When I have looked at codec.com to download codecs that seem to match my assets, I don't know how to discover what codecs are already installed. Can someone please help me understand this difficult concept please?
Here are the Media Info specs from two different assests I have tried to match. They are just examples and don't need to be in the same sequence.
Thanks in advance!
General
Complete name                            : C:\Users\Jonathan\Desktop\Wendy the Hula Hooper-360p.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 1.36 MiB
Duration                                 : 33s 667ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 340 Kbps
Encoded date                             : UTC 2012-03-15 10:45:57
Tagged date                              : UTC 2012-03-15 10:45:57
gsst                                     : 0
gstd                                     : 33715
gssd                                     : BD075F942HH1331986762648687
gshh                                     : o-o.preferred.iad09g05.v22.lscache7.c.youtube.com
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Baseline@L1.3
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Format settings, GOP                     : M=1, N=30
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 265 Kbps
Maximum bit rate                         : 345 Kbps
Width                                    : 204 pixels
Height                                   : 360 pixels
Display aspect ratio                     : 0.567
Frame rate mode                          : Constant
Frame rate                               : 30.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.120
Stream size                              : 1.06 MiB (78%)
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 33s 645ms
Bit rate mode                            : Variable
Bit rate                                 : 72.0 Kbps
Maximum bit rate                         : 80.8 Kbps
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Sampling rate                            : 44.1 KHz
Compression mode                         : Lossy
Stream size                              : 296 KiB (21%)
Title                                    : IsoMedia File Produced by Google, 5-11-2011
General
Complete name                            : C:\Users\Jonathan\Pictures\Princess\DVD_Master_Assets\AllPrincessPart iesHiRes.mp4
Format                                   : MPEG-4
Codec ID                                 : isom
File size                                : 61.3 MiB
Duration                                 : 3mn 29s
Overall bit rate                         : 2 461 Kbps
Writing application                      : Lavf53.0.3
Video
Format                                   : AVC
Format profile                           : Main@L3.0
Codec ID                                 : avc1
Duration                                 : 3mn 28s
Bit rate                                 : 2 347 Kbps
Width                                    : 854 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 24.000 fps
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.239
Stream size                              : 58.5 MiB (95%)
Writing library                          : x264 core 115 r1995 c1e60b9
Encoding settings                        : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=30 / keyint_min=15 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 3mn 29s
Bit rate                                 : 110 Kbps
Maximum bit rate                         : 128 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Stream size                              : 2.73 MiB (4%)
    Mar 17, 2012 8:45 AM   in reply to reillc01
    1 - Do NOT download codecs unless you are 100% sure of what you are doing... you can mess up your system and have to format your hard drive and reinstall everything
    2 - Format : AVC
    Search the program help file for AVCHD
    I have CS5 so I am not 100% sure if CS4 will edit that codec well
    Convert AVCHD to HDV http://forums.adobe.com/thread/390605
    or use Cineform Neo Scene http://www.cineform.com/neoscene/
    Mar 17, 2012 8:54 AM   in reply to reillc01
    You should probably start with the right material.  Premiere Pro is a professional level editor designed to work with standardized camera formats.  Start with original material from a supported video camera, and things should fare better.
    Mar 17, 2012 10:26 AM   in reply to reillc01
    If those files are, in fact, AVCHD... click the links I provided in my last message and do some reading
    If you can't directly edit the files with CS4, you either need to convert to a codec that will edit, or use a tool like the 2nd link I posted
    Mar 18, 2012 8:59 AM   in reply to reillc01
    With PrPro CS 4, if you have not done so already, update the program to the latest. Full, native AVCHD was adeed at about the second, or third update, IIRC.
    Then, with a Custom/Desktop Preset, you should be able to match the other attributes of your Source Footage.
    I also agree with John T. Smith on downloading CODEC's. I only install ones that I need, when I need them, and always try to go to the "source," which will likely be a commercially available company, and buy the one(s) that I need. While there ARE good free CODEC's, such as Lagarith Lossless, or UT Lossless, I would rather buy the rest, than use some hacked, or reverse-engineered versions.
    As AVCHD is H.264 (one version of H.264), you should be able to get that, with an installation of the latest version of Apple's QT Player. However, some users feel that the commercially available H.264 CODEC from companies, such as Lead, or MainConcept, are better, and then they do not need to install QT Player.
