TCMulharin
Premiere Pro CS5.5 Crashes on launch. No splash screen.
Mar 18, 2012 3:07 PM
Tags: #no #crash #screen #splash
Whenever I try to open Premiere, it instantly crashes with a "Adobe Premiere Pro CS5.5 has stopped working" error. followed by "The application was unable to start correctly (0xc000001d)"
It has worked fine up until today.
Problem signature:
  Problem Event Name:          APPCRASH
  Application Name:          Adobe Premiere Pro.exe
  Application Version:          5.5.0.0
  Application Timestamp:          4d8a89e8
  Fault Module Name:          boost_threads.dll
  Fault Module Version:          5.5.0.233
  Fault Module Timestamp:          4d8a6f10
  Exception Code:          c000001d
  Exception Offset:          0000000000007585
  OS Version:          6.1.7600.2.0.0.256.48
  Locale ID:          1033
  Additional Information 1:          14b2
  Additional Information 2:          14b225d25347330b53642776663f7d56
  Additional Information 3:          98ef
  Additional Information 4:          98effda6d2df897a43445b56e0c85eb9
Any ideas?
    Mar 18, 2012 3:50 PM   in reply to TCMulharin
    So... what has changed?
    More information needed for someone to help
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    Mar 18, 2012 4:46 PM   in reply to John T Smith
    Begin by installing the 5.5.2 update, and then answer all of the questions in the first post that John linked to.
    You can install Premiere Pro updates by opening Bridge or any other CS5.5 application and choosing Help > Updates.
    Dec 11, 2012 1:52 AM   in reply to TCMulharin
    Hi!
    Did you find any solution?
    I´ve been working on a project two last days, the project have been freezed sometimes, but always been starting again after next startup. But now, it wont. I have updated to 5.5.2, but no change. I open the project, the timeline loads up, but then it shuts down.
    Premiere works with another project, but this project dont. Is it the project file? How can i save my timeline?
    Showing this error:
    Process:         Adobe Premiere Pro CS5.5 [1603]
    Path:            /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
    Identifier:      com.adobe.AdobePremierePro
    Version:         5.5.2 (5.5.2)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [172]
    Date/Time:       2012-12-11 10:41:17.230 +0100
    OS Version:      Mac OS X 10.7.5 (11G63)
    Report Version:  9
    Interval Since Last Report:          377926 sec
    Crashes Since Last Report:           11
    Per-App Interval Since Last Report:  34 sec
    Per-App Crashes Since Last Report:   1
    Anonymous UUID:                      F669E2C6-CA16-446E-8F89-B358489735AC
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_CRASH (SIGSEGV)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Application Specific Information:
    objc[1603]: garbage collection is OFF
    Dec 11, 2012 3:16 AM   in reply to caddy83
    The first thing to check is what is different about the project that works and the one that doesn't?  Is the source footage a different format or codec?  Do you have different, or more or less effects applied?
    What was the last thing you did in the bad project before you saved it?
    Please answer as many questions from the following link as you can.  You've already answered the first 3:
    Adobe Forums: FAQ: What information should I provide when asking a question on this forum?
    Jeff
