jdeutsch1002
translate to java
Mar 20, 2012 8:15 AM
Tags: #acrobat #pro #7
Hello
I was wondering if someone would be able to help me convert this to javascript so that I can make this form I'm creating do the math within the text boxes. I know nothing about Java and have not found anysite that will do the translatting for me. If you have the time I would greatly appreciate it.
First formula:
text box 6 - text box 22 = text box 23
Second formula:
text box 23 - sum(text box 24 through 31) = text box 32
Again if this takes up to much of your time I will just continue on with the form and not have it do the calculations. Thanks for any help you can offer.
Jennifer
    Mar 20, 2012 8:18 AM   in reply to jdeutsch1002
    First formula (as the custom calc script of text box 23):
    event.value = +this.getField("text box 6").value - +this.getField("text box 22").value;
    Second formula (as the custom calc script of text box 32)::
    var sum = 0;
    for (var i=24; i<=31; i++)
         sum += +this.getField("text box "+i).value
    event.value = +this.getField("text box 23").value - sum;
    Mar 20, 2012 8:51 AM   in reply to jdeutsch1002
    Open the JS console (Ctrl+J) and check if there are any error messages.
    Mar 20, 2012 9:03 AM   in reply to jdeutsch1002
    It means there's no field called "text box 6". You must double-check that there's no extra space somewhere, and remember also that it's case-sensitive, so if it's called "Text box 6", it won't work.
