Block Eraser cursor area is ambiguous/inaccurate
Mar 22, 2012 3:11 PM
Tags: #watson
The block eraser used to make a hole exactly the size of its silhouette. Now it's completely ambiguous: the black outline of the block eraser is 15px square, and the gray outline around it is 17px square, yet it makes a 16px hole. Fix this, please!
#3145306
  • PECourtejoie
    Jan 11, 2006
    Mar 22, 2012 8:40 AM   in reply to KrisHunt
    Hi, Kris, is antialiasing on or off?
    Is it with the default brushes?
    Is your graphic display scaled by the OS?
    What kind of brush preview did you select?
    Mar 22, 2012 8:45 AM   in reply to KrisHunt
    Set on Pencil Mode or Brush Mode?
    Mar 22, 2012 8:51 AM   in reply to KrisHunt
    I'm not seeing anti aliasing on eraser in Block Mode.
    I've never used it before. Is there any way to change its size?
    Mar 22, 2012 8:56 AM   in reply to KrisHunt
    Not here. It is working like how you say it should. (Mac10.6.8)
    Mar 22, 2012 9:06 AM   in reply to KrisHunt
    You don't have to be a rude.... I'm trying to reproduce to help.
    Mar 22, 2012 10:09 AM   in reply to KrisHunt
    Hi Kris,
    I tried to recreate this but wasn't getting the behavior you described. I was testing on a Mac. I created two layers top with 50% grey fill and bottom with black. Using the eraser tool in Block mode at 100% view on the top layer it created a completely opaque cutout with no transparent pixels around the edges, for comparison I also set it to brush mode with a 20 pixel square brush right below it this did leave the transparent edge pixels as expected. I had the pixel grid on and zoomed to 1200% for the screen shot. What steps were you going through to reach this result? Were you on PC?
    -Dave
    Mar 22, 2012 10:23 AM   in reply to KrisHunt
    I think I understand, so your compliant is the appearance of the tool tool changed with CS6, so it appears to have this slightly tranparent edge now. Is that right?
  • Noel Carboni
    Dec 23, 2006
    Here's what it looks like in Photoshop CS5 on a Windows system:
    I've just installed the beta and can confirm the same problem.  Here's the same exercise as above done with CS6 and OpenGL Drawing disabled:
    -Noel
    Mar 22, 2012 10:21 AM   in reply to KrisHunt
    Block eraser works just fine for me.
  • Noel Carboni
    Dec 23, 2006
    Mar 22, 2012 10:34 AM   in reply to Noel Carboni
    Same problem with OpenGL enabled...
    -Noel
    Mar 22, 2012 10:44 AM   in reply to Noel Carboni
    I see a difference in the appearance of the tool between CS5 and CS6 but don't quite understand how this change has much impact on workflow. For me personally, I generally do not work much at 100% when doing pixel level work, I usually zoom way in to where I see the individual pixels.
    Mar 23, 2012 6:46 PM   in reply to KrisHunt
    Yes, the block eraser's erased size has not been changed.
    The cursor has been alterred however to include a white border outside the original black border.
    In CS5, the eraser block cursor was made up of one black line on the outside and one white line on the inside so it would be visible on both black and white backgrounds. When used, the eraser would erase pixels up to the black border.
    Like your image shows -> 16px for both cursors. The extra white border is not included in that 16px square.
    We'll investigate into this further.
    Mar 23, 2012 7:17 PM   in reply to Pete.Green
    Are you kidding me? Did you read the original post?
    Look, here is the same image I posted earlier; except now it's at actual size. Count the pixels yourself in your favorite image editor.
