Gerrit DeWitt
CS6 Installation on Lion 10.7.3 Fails - ASU Quit Unexpectedly
Mar 22, 2012 1:20 PM
I'm going to post this again, because Adobe needs to be aware of the problem.  Installation on 10.7.3 for Photoshop CS6 is now consistently failing with the following error:
Exit Code: 15
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 1 error(s), 1 warning(s)
ERROR: ASU has quit unexpectedly.
WARNING: User opted to Cancel the install
  • PECourtejoie
    Jan 11, 2006
    Mar 22, 2012 1:22 PM   in reply to Gerrit DeWitt
    Hello, Gerrit, I might have missed some of your other posts, but did you try to download the install package a second time to make sure that the copy you have is not corrupted, somehow?
    Mar 22, 2012 1:46 PM   in reply to Gerrit DeWitt
    yup can confirm also - will not install on mac osx lion - downloaded package twice - once in safari and once in firefox - same issue - restarted and attempted to install 4 times on both downloads same errors as mentioned above.
  • PECourtejoie
    Jan 11, 2006
    Mar 22, 2012 2:18 PM   in reply to Gerrit DeWitt
    Ok, sorry a new download did not fix it. In another thread, a user reported that using another decompression software fixed some issues, but I don't know what their platform was, or if you are facing the same issue.
    Mar 22, 2012 2:28 PM   in reply to Gerrit DeWitt
    rated as requested - can confirm I tried pretty much everything and no go - when I get home will try on my other identicle machine also and report back.
    Mar 22, 2012 3:40 PM   in reply to Gerrit DeWitt
    I just downloaded and installed the demo on my MacBook Pro 15"-2.2 Ghz Intel Core i7-OS X 10.7.3 with no problems.
    I opened a file and printed it on my Epson Stylus Pro 3880 and got a beutiful print looking the same as the one from CS5.
    Mar 22, 2012 7:00 PM   in reply to Gerrit DeWitt
    I too am using 10.7.3 and have had absolutely no problems.
    Mar 22, 2012 9:03 PM   in reply to Gerrit DeWitt
    I had similar installation problems, but in my case there were nothing in the logs. Only AAM running multiple times when checking  Activity Monitor. I tried reboot, download again and install a couple of times with the same result and then I decided to leave the machine for the night.
    I'm not sure, if the cause for all this was me trying to install Ps CS6 straight from Downloads folder, for this morning I copied the dmg to desktop and the installer run without any problems.
    Mar 23, 2012 7:24 AM   in reply to Gerrit DeWitt
    Well I went home and installed no problem on 10.6.3 without issue - came in to work and picked several of the imacs here and tried installing - all on 10.7.3 and same errors as yesterday - just simply will not install - no software updates for the current machines so up to date there - finally gonna give up until this is sorted out.
    Jul 18, 2012 12:37 AM   in reply to twsjonathan
    Hello @twsjonathan,
    We would like to look into the issue that you are observing on 10.7.3 machines. Can you join us in an Adobe Connect meeting from any of the affected machines? Do let us know of the time convenient to you.
    Thanks, Nitin
    Mar 24, 2012 4:25 AM   in reply to Gerrit DeWitt
    Hi Also Have Issue Installing CS6 with 10.7.3.
    In This first instance, Install simply Failed. I Removed all Files and Tied Again, this time the Installer Froze whowever all applications turned up in the App Folder, This Apps did not Open just bounced and froze. After Removing further files in App Support and .plist files Install Still failed but with the Initall Error Code.
    Exit Code: 15
    Any  Guesses?
    Mar 24, 2012 6:36 AM   in reply to MikaCu
    Experiencing identical problem as MikaCU on 10.7.3. Downloaded 4 times. Moved from Downloads to Desktop. Same end result. AAM running, no log created ... essentially just gets through the very starting initialization and then hangs (or AAM just sits there). Even left it overnight to no avail; AAM still running in the morning but no installation progress or discernable errors. Have attempted with other programs running and nothing running. Makes no difference.
    Mar 24, 2012 7:12 AM   in reply to dirketc123
    A couple of stray thoughts:
    Did you quit all other applications, even non-Adobe, before you attempted the install? Not doing so can cause problems.
    Also, what about your Permissions? When is the last time you repaired those? OS X 10.7.3 has done some strange things to my Permissions, and it is a battle that I continue to fight because I haven't figured out yet why it is happening.
    When I installed PS CS6 Beta, it was only two days after I last repaired Permissions, and I did not have any problems.
    Mar 24, 2012 11:39 AM   in reply to George_Thomas
    George_Thomas, yes, tried every which way. All apps closed. Some apps open. Repaired permissions. Everything. AAM just sits and sulks doing nothing. Will attempt another repair, but not expecting it to resolve.
    Mar 24, 2012 12:04 PM   in reply to dirketc123
    The desktop copy, is it the DMG or the content? Incase it is the DMG, try copying the content to a new folder on the desktop. Unmount the DMG, incase there are any. Quite Pdapp process and try running the installer fromt he new location. Incase this does not work, I would be happy to do a connect session to try and help. Just drop me a mail at harinder@adobe.com.
    Mar 25, 2012 11:30 AM   in reply to Harinder4
    Tried all suggestions (install from mounted dmg, moving dmg contents and unmounting/deleting dmg, etc.), but each time PDAPP just finishes first "progress bar" and then sits in the background. Repaired and verified more times than I wish to count. Nothing works.
    I'm 99% convinced of upgrading my MBP to an SSD anyway, so will retry PS6 on a clean Lion install.  I'm betting that will resolve.
    Mar 25, 2012 1:29 PM   in reply to dirketc123
    I found this that may be of help to you. It reads and analyzes Install log files for installs through 5.5 so may work for 6 also.
    http://www.adobe.com/support/loganalyzer/
    Mar 25, 2012 5:54 PM   in reply to Gerrit DeWitt
    Jul 18, 2012 2:04 AM   in reply to Gerrit DeWitt
    Hi @Lusky87 & @dirketc123, we can have a connect session to look into the issue. Let us know.
    Thanks, Nitin
    Mar 26, 2012 3:58 PM   in reply to Nitin_Bansal
    I am going to reinstall OSX on an SSD then retry later. Appreciate all the help, but rather not waste collectively time debugging what may potentially be a non-issue.
    George_Thomas - no log is created when I attempt to install.  Sounds exactly like MikaCu above ... except of course, that the "fix" didn't work in my case. AAM goes thru initial start-up (e.g. the first status bar), then minimizes into the Task Bar and does nothing further.  No logs, no activity, nearly no CPU or anything else utilized in Activity Monitor.
    Just posting the replies in case someone else is experiencing something similar.
    Users facing this issue - Please confirm the following:
    1.) Hardware configuration: Does the machine is Mac Pro or iMac? Other specifications.
    2.) Perform a complete reboot unselecting 'Reopen Windows when logging back in'. Immediately after reboot, try installing PS CS6. Does it works this time?
    3.) Other Adobe products already installed on system (like PS CS5.5 etc.)
    Thanks, Nitin
    Mar 29, 2012 3:14 PM   in reply to Nitin_Bansal
    An encountering the same issue.
    OS X version is 10.7.3 (11D50d). From System Information:
      Model Name:          MacBook
      Model Identifier:          MacBook5,1
      Processor Name:          Intel Core 2 Duo
      Processor Speed:          2.4 GHz
      Number of Processors:          1
      Total Number of Cores:          2
      L2 Cache:          3 MB
      Memory:          4 GB
      Bus Speed:          1.07 GHz
      Boot ROM Version:          MB51.007D.B03
      SMC Version (system):          1.32f8
    The error I receive is the same as the guys above (ERROR: ASU has quit unexpectedly, WARNING: User opted to Cancel the install). Nothing of interest was logged to Console aside from a lot of 'Object xxx of class xxx autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug.' messages.
    A clean reboot didn't help. The only other piece of Adobe software installed on this machine is AIR.
    Cheers,
    Rob
    Jul 18, 2012 12:38 AM   in reply to __eep
    Thanks Rob (@__eep) for the details. Can we have an Adobe Connect meeting from the same machine to look into the issue remotely? Do let us know, we can coordinate the meeting schedule.
    Thanks, Nitin
    Mar 31, 2012 1:55 PM   in reply to Gerrit DeWitt
    Hey Backagain.. so i just downloaded a fresh copy... It poped up at 2% telling me Ai CS3 was open.. closed that and boom.. its working! Try opening another App which it will prompt you to close.. seemed to work for me but could just be a fluke..
    Apr 2, 2012 6:40 AM   in reply to Gerrit DeWitt
    Same problem here. Mac mini mid 2011, 8GB Ram, core i7, OSX 10.7.3
    Downloaded new copy of installer results in same problem.
    No further CS version installed on system.
    No chance to try CS6
    Jul 18, 2012 12:36 AM   in reply to marccoular
    @marccoular, can we have an Adobe Connect meeting from the same machine to look into the issue remotely? Do let us know, we can coordinate the meeting schedule.
    Thanks, Nitin
    Apr 18, 2012 3:09 PM   in reply to Gerrit DeWitt
    Hi...
    Here is how to solve that problem on Mac Lion
    1) ShutDown you Mac
    2) Boot the Mac while holding down the shift key untill the Login Window appears
    3) Login and open the CS6 Disk Image
    4) Copy the contents of the disk image (Blue PS Icon) to the desktop
    5) Launch the installer from the desktop NOT the Disk Image
    6) In my case it installed just fine....
    7) Reboot the Mac so that the without the Shift key to re-enable the system extensions
    I had ALL the problems described in this here thread and NONE of the suggested workarounds were working for so I came up with this one
    Hope it helps
