AI to Fireworks drop shadow problem
Mar 23, 2012 11:09 AM
Tags: #error #fireworks #shadow
I'm importing .AI files into Fireworks in order to export them as .pngs because the raster quality is better than out of .ai,
One of my files has a white box with a 100% black drop shadow on a grey background. In AI it looks fine, but when I open the file in Fireworks the shadow appears white, a bit like a glow.
The shadow is set to 'Multiply' and has worked in other files.
Any ideas why it's doing this? It's only on this file.
See below:
C
    Mar 23, 2012 12:23 PM   in reply to corriela
    I'm not surprised that something got lost in translation as I'm sure it takes considerable work to get the two applications to work smoothly together. In my older versions of these applications (FW8 and CS2), importing an AI file into an FW file results in a bitmap, not a vector object with effects.
    So can you select the vector object in FW and re-apply the drop shadow as a live Effect from the Filter menu of the Properties Inspector? If that's inconvenient, perhaps you could go back to AI, edit the Drop Shadow effect (from the Appearances panel) to adjust the blend mode to Normal. Then once it's imported into FW, set the blend mode to Multiply. Because it sounds like it might be an issue with translating the blend mode behavior. (I forgot to ask: Does the AI drop shadow appear as an effect in FW, or as another vector object?)
    I'm surprised that the quality of raster graphics is better in FW than AI. In a different post, I was suggesting to someone that they try doubling the size of their vector graphic and then outputting the graphic as a bitmap at half-size. This can sometimes smooth out a rough or aliased-looking vector object.
    ONE MORE IDEA: In Illustrator, you have the option of flattening effects like Drop Shadow by selecting the object and choosing Object > Expand Appearance. This might help in your case. And I believe that the Document Raster Effect Settings (under the Effects menu) will influence the quality of effects rendering—so setting it to Medium or High before flattening would be a good idea.
    Mar 26, 2012 9:45 AM   in reply to corriela
    Did you try changing the blend mode of the drop shadow in AI from Multiply to Normal? (As long as it doesn't change the appearance in AI, you might get better results upon importing to FW.)
    I have to admit I'm a bit lost here... If the shadow is being rasterized, that suggests that the vector itself has been flattened to a bitmap object upon being imported into FW. In that case, I can't imagine that exporting from FW would deliver better-looking results... but I'll leave that to you to determine. If the button and its shadow are fused into one bitmap object, I would again suggest that you could flatten the effect in AI by choosing Object > Expand Appearance.
    Interestingly, I'm just noticing that FW8's drop shadow effect does not offer a blend mode option.
    Were you aware of Illustrator's Pixel Preview capabilities (under the View menu)? With that view enabled, a Snap to Pixel option appears in the View menu as well. I don't know if it would help in your case, just thought I'd mention it.
    Mar 26, 2012 10:45 AM   in reply to corriela
    It's hard to know what's going on without seeing the files, and even then it could be a mystery—it's most likely a bug in FW. Or a quirk. I'm assuming you checked the blend modes of all the objects in the FW document (and also considered blend modes of objects and layers within AI)?
    It's too bad my Multiply-to-Normal suggestion had no effect. I was thinking that Multiply is a good choice when you want to preserve colors but that Normal would work just as well in this particular case, since it's a grey-on-grey blend.
    For curiosity's sake, you could try recreating the object from scratch in FW, with those exact color values, to see if the same results occur.
    Mar 27, 2012 1:31 PM   in reply to corriela
    Aha! In terms of pinpointing the problem, a crucial piece of information was the color or value of the drop shadows—in the first two of your examples, it's actually lighter than the background color.
    I made these graphics directly in FW8, using a feathered rectangle for the shadow so that I could apply a blend mode to it. They're based on your 2nd, 3rd, and 4th examples. The top shadow in each graphic is set to Normal at 100% opacity; the bottom shadow is set to Multiply at 100%.
    From this, I can tell that the Blend mode was getting lost in translation. In hindsight, it becomes more obvious: A single object can be assigned only one blend mode. If the button and its shadow were getting flattened into a single bitmap, then the blend mode attached to the drop shadow effect would naturally get jettisoned.
    That said, I don't know for sure if blend modes between AI and FW are compatible, but you could easily test for this with a simple document using just two objects, one blended into the other. For this case, though, I think the key would be expanding the appearance of the effect in AI, and possibly ungrouping it from the button object—whatever it takes for the two items to be imported as separate objects in FW. Then in FW, you could apply a separate blend mode to the shadow object, to restore its original intended appearance.
    Other thoughts: I don't have the latest versions of these applications, so I don't know... You might take a look at Preferences in AI and FW, to see if there are any Export or Import settings that could help with translating effects like this. Also, I have to admit, I don't usually use a lighter color for a drop shadow; I'd use a darker color instead and lower its opacity. However, there's nothing wrong with the way you're doing it as long as it works in the application(s), which it does.
    Mar 27, 2012 5:23 PM   in reply to corriela
    This is a bit off-topic, but it relates to how Illustrator and Fireworks sometimes handle rasterization of vector objects differently, and I thought you might find it interesting. (This was done using Illustrator CS2 and FW8; I can't say whether CS5 behaves the same way or not.)
    The basic question is this: Where does a 1-pixel stroke belong on a vector object that's aligned to a bitmap grid?
    In Illustrator, with Snap to Pixel enabled (in Pixel Preview mode), the vector itself is aligned to the bitmap grid, and a 1-pixel stroke is balanced across both sides of the vector—appearing in effect as a lighter, 2-pixel, anti-aliased stroke. The result looks very imprecise. You can fix this by setting the Keyboard Increment (in Preferences) to 0.5 pixels, turning Snap to Pixel off, and nudging the object a half pixel in each direction using your keyboard arrow keys: Now the stroke, not the vector, is aligned to the bitmap grid.
    Theoretically, you should be able to adjust stroke position to handle this issue; however, I found that setting the Stroke to "Inside" produced an unexpected bit of anti-aliasing on one side of my rectangle. (This type of problem may have been fixed in a newer version of Illustrator.*)
    In Fireworks, vector objects tend to snap to the pixel grid automatically, as do strokes. But how can FW do this? After all, the default stroke position is center-aligned, just as it is in Illustrator. Well, it turns out that the application is willing to bend the rules a bit: A 25-pixel square with a 1-pixel stroke applied to it still only occupies 25 pixels on the grid, because Fireworks moves the stroke to the inside of the object. It cheats. Once you bump up the stroke weight to 2 pixels, the stroke alignment reverts to center. At 3 pixels, the stroke remains center-aligned but becomes anti-aliased, too.
    So anyway... I hadn't really sat down with Illustrator's Pixel Preview mode before. Despite the issues above, I think it's kind of neat in that it's like a window into the world of Fireworks and pixel grids. (In Fireworks, by contrast, you don't have the option of seeing vectors rendered smoothly at any zoom level, as in Illustrator's standard view mode.) I can't recall whether Preferences can be saved in a Workspace, but View settings can at least be saved as part of a template file, and you could probably set up a de facto workspace for working with pixels in Illustrator in a relatively short amount of time. This could help you avoid surprises when using "Save for Web" (as described in the article to which you linked).
    *Later, I was able to fix the "stroke inside" rendering problem in Illustrator by setting the stroke to .99px instead of 1px.
