clearbox 3 image viewer not working
Mar 24, 2012 10:12 AM
I put in clearbox three but when I click on the images they just open up in another page, not with the viewer.
site is cleverlycreated.com
The problem is on the home page at the bottom...
thanks
avery
    May 18, 2012 1:19 PM   in reply to averydean17
    This video helped me. He inlcudes files for you to download.
    http://youtu.be/3H4EgzFTj3s
    Feb 19, 2013 11:25 AM   in reply to averydean17
    hi i had trouble with this myself but i got it working in the end on my site as you can see here under the image tab http://ukppgwebstore.com/ppg-niviuk-link-11277-p.asp. i have looked at your code and you are missing a link to the java script file "clearbox.js" which you will need to upload to your site
    i pasted my link
    <script src="http://ukppgwebstore.com/ekmps/shops/ukppg/resources/Other/clearbox.js" type="text/javascript"></script>
    into your source code in dreamweaver and  it worked straight away. Below  is a section of your code to see how it looks now. try it for yourself with my link to get it working and then change the address to your clearbox.js script there are also links in the clearbox.js script you may need to change. if you need more help let me know and together we will make it work with all the files hosted from your own site its a great widget and worth the effort.
    here i have it working with video
    http://ukppgwebstore.com/kangook-paramotors-616-c.asp
    // EndWebWidget lightbox_gallery
            </script>
          </div>
        </div>
        <div id="line_3"></div>
        <div id="Rotator_Contain">
          <p>
    // BeginOAWidget_Instance_2648024: #OAWidget
          //     ClearBox Config File (JavaScript)
          var
          // CB layout:
          CB_MinWidth=300,                // minimum (only at images) or initial width of CB window
          CB_MinHeight=300,                // initial heigth of CB window
          CB_WinPadd=15,                    // padding of the CB window from sides of the browser
          CB_ImgBorder=3,                    // border size around the picture in CB window
          CB_ImgBorderColor='#FFF',            // border color around the picture in CB window
          CB_Padd=4,                    // padding around inside the CB window
