Why can I download and install CS6beta but the program refuses to be activated on the idiotic grounds that either I am not connected to the internet or my computer clock is not showing the right time? If in New Zealand we're not allowed to use the beta, why does Adobe not have the decency and courtesy of telling us so and why instead of feeding us with those stupid putoffs???
I had a note from PS Pattie ; I can't find it here. Anyhow, these were her questions and my answers:
Q:Did you download from this location? http://labs.adobe.com/technologies/photoshopcs6/
A: Yes
Q:Did you select TRY and enter your Adobe ID?
A: I was then asked to "Sign in". I pressed the sign and got the following reaction:
Please connect to the internet and retry. Either your computer is offline or the clock on your computer is set incorrectly, causing a connection error. An internet connection is required. Please connect to the internet or adjust your clock and try again. If this problem persist, please contact Customer Support. I did so and was told "This page is not available"
Q: Did you try to download again and install?
A: Yes, three times – each time 1.71GB. I tried many other devices; none worked.
gw
That's quite a comical suggestion. Have you ever experienced or known of any software that requires the publisher's time zone to be imitated for the program to activate? If that is needed for this Adobe piece of work, then I'm not interested in that production. I would find it quite demeaning to apply your suggestion, however simple it is to do so; Adobe's hubris is already at a peak; I would not want them to choke on it.
gw
You may not be aware but the there are vaiour software which gives the activation issue because of the system clock the reason being that the activation server and the computer is not in sync.
You can try the suggestion given or not it's your wish......but we are here to help people like you so that there problem can be sorted out but I dont think you need any help
and if you dont need help then its ok.
North America
Asia Pacific
