QUICK OBSERVATIONS on PS CS6:
Mar 26, 2012 9:04 AM
  Latest reply: Pattie F, Apr 12, 2012 6:30 AM
    Apr 11, 2012 9:57 AM   in reply to Hudechrome
    Referring to the image I included in Post #8, notice the tonal value/color of the Histogram palette above the Navigator image.
    Now notice the color here.
    I can get to the same presentation as in Post 8 by doing the following:
    1) Open a Gray Scale Image
    2) Add the Curves 1 Layer
    3) Convert it to RGB. Do not Flatten. Notice the gray-green shift in the Histogram.
    4) On the History Palette go back one step to Curves 1 Layer. Note the Histogram is now white and it stays white from that point on.
    If you start with an RGB, the greenish-gray Histogram  shows up with color spikes visible.  Converting to Gray Scale kills the green-gray and the color spikes presenting only white. Converting again from Grayscale to RGB shows the Histogram as all white, no colors at all. Then things got really complicated. I could no longer open an image from Bridge. Instead I found a really bizarre presentation of an earlier image tiled randomly. I quit Photoshop and Bridge, then attempted to re open Photoshop. It would not open. Checking Processes, I found several instances of Photoshop running. I killed them all then Photoshop opened fine.
    Apr 11, 2012 10:01 AM   in reply to Noel Carboni
    Right, just add it to all the other stuff that slows down the work flow. Working with curves in any case is a slow, careful procedure, now it's really slow. Unfortunately, this seems to be the tenor of the times. Don't bother us, deal with it!
    Apr 11, 2012 10:02 AM   in reply to Hudechrome
    Just in case, here's system info:
    Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
    Operating System: Windows 7 64-bit
    Version: 6.1 Service Pack 1
    System architecture: AMD CPU Family:15, Model:5, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3
    Physical processor count: 4
    Processor speed: 2800 MHz
    Built-in memory: 12287 MB
    Free memory: 9430 MB
    Memory available to Photoshop: 11001 MB
    Memory used by Photoshop: 73 %
    Image tile size: 132K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Normal
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    Video Card Vendor: ATI Technologies Inc.
    Video Card Renderer: ATI Radeon HD 5670
    Display: 2
    Display Bounds:=  top: 0, left: 1920, bottom: 1024, right: 3200
    Display: 1
    Display Bounds:=  top: 0, left: 0, bottom: 1200, right: 1920
    Video Card Number: 1
    Video Card: ATI Radeon HD 5670
    OpenCL Unavailable
    Driver Version: 8.951.0.0
    Driver Date: 20120308000000.000000-000
    Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,ati umd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdv a,atiumd6a.cap,atitmm64.dll
    Video Mode: 1920 x 1200 x 4294967296 colors
    Video Card Caption: ATI Radeon HD 5670
    Video Card Memory: 512 MB
    Video Rect Texture Size: 16384
    Serial number: Tryout Version
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
    Temporary file path: C:\Users\HUDECH~1\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      I:\, 170.1G, 126.4G free
      G:\, 20.4G, 18.7G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
    Additional Plug-ins folder: not set
    Installed components:
       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
       ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
       adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
       AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
       AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
       AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
       AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1642
       AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
       adobe_caps.dll   Adobe CAPS   5,0,10,0
       AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
       ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
       aif_core.dll   AIF   3.0   62.490293
       aif_ocl.dll   AIF   3.0   62.490293
       aif_ogl.dll   AIF   3.0   62.490293
       amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
       ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
       Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
       BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
       boost_date_time.dll   DVA Product   6.0.0
       boost_signals.dll   DVA Product   6.0.0
       boost_system.dll   DVA Product   6.0.0
       boost_threads.dll   DVA Product   6.0.0
       cg.dll   NVIDIA Cg Runtime   3.0.00007
       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
       CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
       CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
       data_flow.dll   AIF   3.0   62.490293
       dvaaudiodevice.dll   DVA Product   6.0.0
       dvacore.dll   DVA Product   6.0.0
       dvamarshal.dll   DVA Product   6.0.0
       dvamediatypes.dll   DVA Product   6.0.0
       dvaplayer.dll   DVA Product   6.0.0
       dvatransport.dll   DVA Product   6.0.0
       dvaunittesting.dll   DVA Product   6.0.0
       dynamiclink.dll   DVA Product   6.0.0
       ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
       FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
       filter_graph.dll   AIF   3.0   62.490293
       hydra_filters.dll   AIF   3.0   62.490293
       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       image_compiler.dll   AIF   3.0   62.490293
       image_flow.dll   AIF   3.0   62.490293
       image_runtime.dll   AIF   3.0   62.490293
       JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
       LogSession.dll   LogSession   2.1.2.1640
       mediacoreif.dll   DVA Product   6.0.0
       MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       pdfsettings.dll   Adobe PDFSettings   1.04
       Photoshop.dll   Adobe Photoshop CS6   CS6
       Plugin.dll   Adobe Photoshop CS6   CS6
       PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
       PSArt.dll   Adobe Photoshop CS6   CS6
       PSViews.dll   Adobe Photoshop CS6   CS6
       SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
       ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
       tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       TfFontMgr.dll   FontMgr   9.3.0.113
       TfKernel.dll   Kernel   9.3.0.113
       TFKGEOM.dll   Kernel Geom   9.3.0.113
       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
       updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
       WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
       wu3d.dll   U3D Writer   9.3.0.113
    Required plug-ins:
       3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Accented Edges 13.0
       Adaptive Wide Angle 13.0
       ADM 3.11x01
       Angled Strokes 13.0
       Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Bas Relief 13.0
       BMP 13.0
       Camera Raw 7.0
       Chalk & Charcoal 13.0
       Charcoal 13.0
       Chrome 13.0
       Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Color Halftone 13.0
       Colored Pencil 13.0
       CompuServe GIF 13.0
       Conté Crayon 13.0
       Craquelure 13.0
       Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Crop and Straighten Photos Filter 13.0
       Crosshatch 13.0
       Crystallize 13.0
       Cutout 13.0
       Dark Strokes 13.0
       De-Interlace 13.0
       Dicom 13.0
       Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Diffuse Glow 13.0
       Displace 13.0
       Dry Brush 13.0
       Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Embed Watermark 4.0
       Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Extrude 13.0
       FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Fibers 13.0
       Film Grain 13.0
       Filter Gallery 13.0
       Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Fresco 13.0
       Glass 13.0
       Glowing Edges 13.0
       Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Grain 13.0
       Graphic Pen 13.0
       Halftone Pattern 13.0
       HDRMergeUI 13.0
       IFF Format 13.0
       Ink Outlines 13.0
       JPEG 2000 13.0
       Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Lens Blur 13.0
       Lens Correction 13.0
       Lens Flare 13.0
       Liquify 13.0
       Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Mezzotint 13.0
       Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Mosaic Tiles 13.0
       Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Neon Glow 13.0
       Note Paper 13.0
       NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Ocean Ripple 13.0
       Oil Paint 13.0
       OpenEXR 13.0
       Paint Daubs 13.0
       Palette Knife 13.0
       Patchwork 13.0
       Paths to Illustrator 13.0
       PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Photocopy 13.0
       Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Pinch 13.0
       Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Plaster 13.0
       Plastic Wrap 13.0
       PNG 13.0
       Pointillize 13.0
       Polar Coordinates 13.0
       Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Poster Edges 13.0
       Radial Blur 13.0
       Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Read Watermark 4.0
       Reticulation 13.0
       Ripple 13.0
       Rough Pastels 13.0
       Save for Web 13.0
       ScriptingSupport 13.0
       Shear 13.0
       Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Smart Blur 13.0
       Smudge Stick 13.0
       Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Spatter 13.0
       Spherize 13.0
       Sponge 13.0
       Sprayed Strokes 13.0
       Stained Glass 13.0
       Stamp 13.0
       Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Sumi-e 13.0
       Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Targa 13.0
       Texturizer 13.0
       Tiles 13.0
       Torn Edges 13.0
       Twirl 13.0
       U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Underpainting 13.0
       Vanishing Point 13.0
       Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Water Paper 13.0
       Watercolor 13.0
       Wave 13.0
       Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       Wind 13.0
       Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
       ZigZag 13.0
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash:
       Mini Bridge
       Kuler
    Installed TWAIN devices: NONE
  • Noel Carboni
    Dec 23, 2006
    Apr 11, 2012 12:10 PM   in reply to Hudechrome
    I can confirm there's something funky going on in the Histogram display.  It actually went black on me when I switched to grayscale in testing what you described.  Then when I went back to RGB it just stayed very light gray, without showing the three color channels  and how they fail to overlap.
    Update:  Note the value of the Channel: field in the Expanded View of the Histogram dialog.  Note that it's "Colors" when you open an RGB document and see the greenish-gray display, and "RGB" when you see the light gray display.  It really should go back to Colors.
    -Noel
    Apr 11, 2012 12:25 PM   in reply to Noel Carboni
    Yeah, I just saw the black display myself and was prepared to post a triptych of three displays, confirming the blakc.
    I'll check the Expanded view.
    Apr 11, 2012 12:53 PM   in reply to Hudechrome
    Checked the Expanded View and I get the same. When going back to RGB in History, you do have the choice of Colors in the drop down. It is consistent because if you pick RGB instead of Colors from the drop down, the White RGB comes up.
    Also, try this. Open the drop down in Expanded View and turn off "Channels in Color". The black display now turns white and visa versa when reversing "Show Channels in Color".
    There is a method to their madness. Madness, I say! It is pure madness!
    Maybe I need to go back to my dark.... NAH!  I get funny smells on my hands, especially after handling onions, then fixer!
    Apr 11, 2012 1:33 PM   in reply to Hudechrome
    Hi Lawrence and Noel,
    I'm looking into this now. Thanks for digging around and reporting!
    regards,
    steve
    Apr 11, 2012 1:43 PM   in reply to SG...
    Hey, great to hear, Steve! Thanks.
    Apr 11, 2012 1:56 PM   in reply to jmarquez85
    I just wanted to chime in and say I find the grayscale image version of the Properties panel version of the Curves editor a bit hard to read, too. The white curve plot is just too similar in luminance to the histogram to easily differentiate the two in the areas where they cross. The brighter histogram also increases the contrast between the histogram and the gridlines, too much for my taste. At that level, I think the grid lines start to become a bit distracting.
    I'd very much perfer if the panel used the same color scheme for grayscale images as it does for the luminance setting for RGB images (i.e. darker histogram). I'm testing this on a hardware-calibrated wide-gamut Eizo monitor, so I don't think the problem is a display issue.
    Apr 12, 2012 6:30 AM   in reply to Trevor.Dennis
    To Trevor:  clicking Return key (mac) or Enter key (win) will make the crop modal.
    Or you can euse arrow keys to nudge the image under the crop box.
    I came across a situation with the crop tool today.  I had used it non destructively and come out of Crop.  I later wanted to adjust the position of the image within the frame, so hit the 'c' key, but was unable to move the image within the fram unless I first nudged a handle.  Is there a workaround?  I just tried it again, and I don't actually have to nudge a handle. Just click on one.  That's no hardship.   Is there a hot key though?
