When I export my sequence, and review it in Quicktime Player, the footage skips and shakes throughout the whole movie.
I am using Premiere Pro CS5
My Sequence settings are:
DSLR
1920 x 1080
29.97 fps
48000 Hz - Stereo
(1.0)
No Fields (Progressive Scan)
I am exporting to a quicktime NTSC DV format
720x480, 29.97 fps, Lower, Quality 100
48000 Hz, stereo, 16bit
If someone could explain why this is happening and how to fix it that would be great. I not only would like a solution but Id like to educate myself on why this is happening so I know in the future.
Thanks for your time,
E
I believe 503 is the current CS5 build. Start by updating your application.
Nothing looks amiss in your settings. Although, if I were making a DVD from HD material (Are you?), I wouldn't use the DV codec.
You can export directly to DVD MPEG2 instead, and avoid a double-transcode.
But, that won't solve your skipping / shaking issue necessarily. Upgrading or trashing your prefs (hold option/alt while launching Pr) may help.
North America
Asia Pacific
