Eldrarak82
"This operation is not permitted" when saving PDF through a plugin
Mar 26, 2012 3:52 PM
Not sure what I am doing wrong. It appears as though I've followed the PDF Reference and documentation correctly, but I am getting this error when my plugin trys to save my PDF file to a new location (dont want to overwrite the original).
Here is the sample code. I hope what I am doing wrong is easy to fix.
PDDocClose(currentPDDoc);
ASPathName filePathName = ASFileSysCreatePathName(NULL, ASAtomFromString("CString"), replacedSavePath.c_str(), 0);
PDDocSave(currentPDDoc, PDSaveIncremental | PDSaveLinearized, filePathName, ASGetDefaultFileSys(), NULL, NULL);
    Mar 27, 2012 1:55 AM   in reply to Eldrarak82
    The first thing I notice is that you have closed the currentPDDoc before you try and save it. I think you need to save it before you close it.
    I also not that you are saving linearized, this means that you need to make sure that any 'acquire' functions that you have called have been release, for example
    PDDocAcquirePage() or PDBeadAcquirePage(). - see documentation for more information.
    Hope this helps
    Malcolm
    Mar 27, 2012 6:26 AM   in reply to Eldrarak82
    You can do an incremental save when you save to a new location - there is
    nothing to add the new information to. You need to call the function with
    PDSaveFull.
    You may not have acquired any objects explicitly, but chances are that if
    your plugin is doing anything useful, you have acquired something through
    some of the methods you called. Make sure that you know what the side
    effects of every API function you call are, and then release whatever is
    still acquired before you save the document.
    Karl Heinz Kremer
    PDF Acrobatics Without a Net
    khk@khk.net
    http://www.khkonsulting.com
