Removing empty XML tags & returns
Mar 26, 2012 8:08 PM
I have a XML feed from a web app (over which I have control as to how the XML is tagged etc) and the XML drops into an indd template, applies character, para, table and cell styles.
The issue I have is that if an XML tag is empty (and they often are), I can't search and replace for extra carriage returns as there's markers in there from the XML (I believe, correct me if I'm wrong).
If I select the invisible characters and paste them into the Find and Replace dialogue box, they show up as ~I (GREP) or ^I (normal), which is apparently an index marker.
Is there any way of getting rid of these via a script? If I try to search for those invisible characters, no changes get made, i.e. none are found.
Is there a GREP method that may work?
Thanks in advance.
    Mar 26, 2012 10:09 PM   in reply to Angusdog
    It is already discussed few months ago.See the thread http://forums.adobe.com/message/4139703#4139703, Any way I'm reposting it. Use the below script,
    var xpath ="//*";
    var root  = app.activeDocument.xmlElements[0];
    var node  = null;
        try {
            var proc  = app.xmlRuleProcessors.add([xpath]);
            var match = proc.startProcessingRuleSet(root);
            while(match!=undefined) {
                node = match.element;
                match = proc.findNextMatch();
                content=node.contents;
                    if(node)
                        app.select(node);
                var myText = app.selection[0];
                var content=myText.contents;
                    if(content.search(/^[\s\r\n]+$/)!=-1){
                        myText.untag();
            }//End of While
        } //End of Try
        catch(ex){
            alert(ex);
        finally {
        proc.endProcessingRuleSet();
        proc.remove();
    Green4ever
    Mar 27, 2012 9:17 PM   in reply to Angusdog
    You can use the script as is. The variable xpath holds a xpath expression. "//*"  will match any tag in any location. To know more about xpath see http://www.w3.org/TR/xpath/#section-Introduction and you can see some examples here: http://www.adp-gmbh.ch/xml/xpath.html. Remember that this is not a recomendation, it is just for reference only.
    Green4ever
