I have datagrid with paged data. When I click the AdvancedDataGrid column header, datagrid existing data will be sorted. This isn't right because I need to get sorted data from the server. I have tried to catch columnHeaderRelease and click methods to retrieve sorted columns.
If i want to disable internal sort, i need to call event.preventDefault(). This works but sorting icons wont work anymore.
I extended ArrayCollection to get sortFields and sort, and disabled datagrid refresh() method. Like this i can catch sortfields but somehow setter value is null with.
public class CustomSortCollection extends ArrayCollection
private var _sort:ISort;
public function CustomSortCollection(source:Array = null)
super();
this.source = source;
override public function get sort():ISort
return _sort;
override public function set sort(s:ISort):void
_sort = s;
if (!s)
return;
trace(s.fields.length);
var event:CustomSortCollectionEvent = new CustomSortCollectionEvent(CustomSortCollectionEvent.SORT);
event.fields = s.fields;
event.s = s;
this.dispatchEvent(event);
* Avoid the internal sorting implementation, with this it's possible
* to do a server side sort.
* @return true
override public function refresh():Boolean
return true;
public function superRefresh():Boolean
return super.refresh();
Any suggestions on this.
There really is not a good way to handle this with event intercepts, at least not that I've been able to find. The simplest soultion is to create a custom component that extends the spark DataGrid. The key is to override the 'columnHeaderGroup_clickHandler()' method so that it dispatches a custom event that triggers your server side sort. You will also need to create a class that wraps your actual results (whatever would normally be bound to dataprovider). It will also have some properties that are used by the datagrid to determine what visual changes it needs to make once your server side sort has returned the results. At a bare minimum I would include fields for sort direction, sort column, and the results collection. The idea is to have your service method return an instance of this 'PageableCollection' to the client which passes it along to your datagrid. The datagrid then sees the change to its instance of 'PageableCollection' and updates it's view.
Here is an example:
import spark.components.gridClasses.GridColumn;
import spark.events.GridEvent;
[Event(name="sortChanged", type="com.myproject.myevents.SortEvent")]
public class ExtendedDataGrid extends DataGrid
private var _pageable:PageableList;
public static const PAGEABLE_CHANGED:String="pageableChanged";
public function ExtendedDataGrid()
super();
override protected function columnHeaderGroup_clickHandler(event:GridEvent):void
const column:GridColumn=event.column;
initiateRemoteSort(column);
public function initiateRemoteSort(column:GridColumn):void
if (!enabled || !sortableColumns || !column || !column.sortable)
return;
clearSelection();
if (_pageable)
_pageable.sortAsc=!_pageable.sortAsc
_pageable.sortBy=column.dataField;
var sortEvent:SortEvent=new SortEvent(SortEvent.SORT_CHANGED, true, false, column.sortDescending, column.dataField);
dispatchEvent(sortEvent);
public static function findColumnByDataField(columns:IList, dataField:String):GridColumn
for (var i:int=0; i < columns.length; i++)
var col:GridColumn=GridColumn(columns.getItemAt(i));
if (col.dataField != null && col.dataField == dataField)
return col;
return null;
[Bindable("pageableChanged")]
public function get pageable():PageableList
return _pageable;
public function set pageable(value:PageableList):void
_pageable=value;
clearSelection();
this.dataProvider=value.values;
var col:GridColumn=findColumnByDataField(columns, value.sortBy);
if (col != null)
col.sortDescending=!value.sortAsc;
if (columnHeaderGroup)
const columnIndices:Vector.<int>=Vector.<int>([col.columnIndex]);
columnHeaderGroup.visibleSortIndicatorIndices=columnIndices;
dispatchEvent(new SortEvent(PAGEABLE_CHANGED, true, false, value.sortAsc, value.sortBy));
If you can consider a third party component, we've already implemented this : http://www.flexicious.com/Home/DemoFlex4
North America
Asia Pacific
