Quit crippling this wonderful app.....thought it was slower, but it is actually faster.
Apr 9, 2012 12:12 AM
  Latest reply: Interference.gt, Apr 19, 2012 1:55 AM
Replies 1 2 3 2 Previous Next
    Apr 3, 2012 6:20 PM   in reply to AtonMusic
    Well a forehead smacker, but far from dumb azz. A day without a forehead smack is a day without using Photoshop.
    Glad you figured it out. Now you realize, I will have to try it to find out what 250 px of outer glow looks like.
    Ted
    Apr 3, 2012 6:27 PM   in reply to AtonMusic
    A couple updates:
    First, I need to give credit to my colleague Mike Shaw for identifying what specifically was slowing down performance in the file - I'll certainly sleep better tonight
    Second, I ran an action to try to reproduce the slowdown using tools and wasn't able to - my action ran the Dodge tool 50 times in a row on a single image without any degradation in performance for the entire run.  Note that I'm not using a tablet and there might be something about the data being passed there that's slowing down the app (just a WAG).  Ted, my email contact info is above so if you'd like to contact me directly I can help you create an action on your system that might help us figure out what's going on.
    Thanks again,
    Adam
  • Noel Carboni
    Dec 23, 2006
    Apr 3, 2012 6:32 PM   in reply to AtonMusic
    That's good news, AtonMusic.  Glad to hear it wasn't a bug!
    -Noel
    Apr 3, 2012 9:17 PM   in reply to AtonMusic
    Thanks Adam ...
    I will definitely send you an email. Tonight I only did 8 images, but on the last, I began to notice a slow down of the healing brush.
    Here is my system info:
    i7-2600K CPU @ 3.40 GHz
    Windows 7 Home Prem build 6.1.7601
    RAM: 16GB
    GPU: NVIDIA GTX 550 Ti with 1 GB
    NVIDIA Driver: 9.17.12.9610
    Wacom Intuous 4
    PS preferences:
    memory for PS 8703 GB (59%)
    This  memory table I created from the Windows Resource Monitor
    Stage:                    In Use          Modified          Standby          Free
    Fresh Start             2070MB      44MB               866MB          13394MB
    Start Bridge           2230            64                    1179               12863MB
    Launch ACR          2780            86                    1640               11800
    Open 1 smt Obj     5090           112                   1833               11333
    close 2 images      5775           112                   2628                 7841 - edited / closed 2 photos, , PS running, no active img
    close 1 image        6516           159                   3318                 6374 - PS running, no active image
    close 5 images      6732           247                   4543                 4843 - PS running, no active image
    close PS                2318           108                   4613                  9327 - PS closed, Br still running
    close Br                  2090           108                   4652                  9530
    Somehow during the process of launching PS & Br, editing 8 images, and closing PS & Br, free memory was reduced by
    just shy of 4GB. The troublesome part is that in use memory increased after each image was closed. Although it wasn't as bad tonight (with only 8 images) by the time I did 12 last night, the tools were noticably sluggish.
    Apr 3, 2012 9:45 PM   in reply to PixbyTed
    That's normal: photoshop reuses memory, and freeing memory all the time would make it much slower and more likely to have problems with address space fragmentation.
    Apr 4, 2012 7:07 AM   in reply to Chris Cox
    Thanks Chris. That makes sense.
    What happens if "in use memory" exceeds the amount I have set in PS preferences (in my case 8.7 GB)? Would that result in sluggish tools?
    I haven't watched it long enough to see if that happens when the tools get sliuggish.
    Ted
    Apr 4, 2012 9:10 AM   in reply to PixbyTed
    Photoshop's "in use" as measured by the OS includes things beyond Photoshop's control (OS buffers, display/UI buffers, the size of the loaded binaries, etc.).
    But Photoshop's measured memory use tries to take that into account, and limit actual allocated space to less than you specify in Photohop's preferences.
    Allocating the full amount would not make Photoshop sluggish.  But if you edit a document larger than RAM and hit the scratch disk a lot - then that could make Photoshop sluggish while it waits for disk IO.
    Apr 4, 2012 11:30 AM   in reply to Chris Cox
    I don't think it's writing to scratch disk frequently. The largest file I was working on last night was only about 760MB and 21 layers. The most "in use" memory reported by windows was 6.7GB and I have 8.7 allocated to PS out of 16GB total installed. But last night, I only noticed a slight increase in sluggishness as opposed to previously when I had opened and closed a dozen or more documents.
    What I will do today is just keep running the current instance until the tools become what I would call painfully sluggish - in other words when I would normally shut PS down and start a new instance. What statistics would be useful to you when I reach that state?
    Ted
    Apr 4, 2012 1:30 PM   in reply to PixbyTed
    The basic memory stats might be useful.
    Beyond that we need to figure out how to reproduce the problem so we can profile it and see where the time is going.
  • Noel Carboni
    Dec 23, 2006
    Apr 7, 2012 1:54 PM   in reply to AtonMusic
    Images attached to eMails don't get into the forum, Morten.
    -Noel
    Apr 8, 2012 4:51 PM   in reply to AtonMusic
    What Noel is trying to tell you is that no one can see the image you thought you had attached, not even Adam.
    Images attached to emails just disappear into cyberspace, nobody gets to see them even for an instant.
    Apr 8, 2012 4:54 PM   in reply to AtonMusic
    …and what I want to add is that, without seeing your screen shot, I don't know what you're referencing.  Everything looks fine under snow Leopard 10.6.8, if that helps.
    Apr 19, 2012 1:55 AM   in reply to AtonMusic
    I have just uninstalled it because I am too busy to deal with the performance issues. After using it for a while, my whole system becomes unusably slow - not just PS6. Also it won't quit completely. I'm used to Adobe programs taking forever to quit - especially Acrobat (???) but PS 6 would never quit --always had to be forced.
    For what its worth, I'm working mostly with very large documents - satellite imagery, from a few hundred MB to 2GB. If things calm down here I might try again.
Actions
