paulhart83
Android AIR App Random Error #2032: Stream Error (HTTPStatusEvent = 0)
Mar 27, 2012 10:39 AM
Tags: #air #error #android #stream #urlrequest #ssl
Hello
I am investigating an issue with failed requests and it's been difficult to narrow it down. When I put the URL into a browser I get a valid / expected response. However when I try to access the same URL using Actionscript 3 on my Android Devices (Nexus S and Xoom), I get stream error #2032 at random.
I am using URLRequest with a custom RequestListener class:
var loader:URLLoader = new URLLoader();
if(action == "zip") loader.dataFormat = URLLoaderDataFormat.BINARY;
var listener:RequestListener = new RequestListener(action, loader, endFunction, extra);
loader.addEventListener(Event.COMPLETE, listener.requestSuccessful);
loader.addEventListener(IOErrorEvent.IO_ERROR, listener.requestFailed);
loader.addEventListener(HTTPStatusEvent.HTTP_STATUS, onHTTPStatusChange);
var req:URLRequest = new URLRequest(Global.apiURL);
req.method = URLRequestMethod.POST;
req.data = new URLVariables(paramString);
loader.load(req);
return loader;
Note that it works on one of my routers but not the access point:
onHTTPStatusChange: 0
requestFailed: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: { ... }" errorID=2032]
Since it works on one router but not the other, I can't say that it's an issue with the app, phone, or our request URL.
Note that I am using SSL / https.
Is it a timeout issue?? This is really frustrating.
Thanks.
    Apr 4, 2012 10:31 AM   in reply to paulhart83
    Have you been able to solve this issue? I am also experiencing it currently.
    Update: Turns out in my case that adding an HTTPStatusEvent.HTTP_RESPONSE_STATUS event handler fixed the issue.
    Apr 4, 2012 11:42 AM   in reply to paulhart83
    I ran into this exact problem recently and it was because the date/time on the computer was more than 24 hours off, causing SSL to fail. It's an Air issue - worked fine in any browser and  in a Flex app running in the browser that uses SSL, but not in an Air app until the date/time was set correctly.
    Jun 12, 2012 6:17 PM   in reply to Brian Vaughn
    wtf, that ended up fixing it for me too.. what the hell?
    weirdest thing for me was that even though i was getting IOError... the Event returned in the IOError actually had the DATA in it from the server...
