• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cffunction valitation error
Participant ,
Mar 28, 2012 Mar 28, 2012
I have a form where I  fill a customer-no. into an input field and get the customer name using databinding.
This works fine, but when I put non-numeric values into customer-no I get following error:
Error invoking CFC customer.cfc : The CUST_ID argument passed to the getcustomer function is not of type numeric. [Enable debugging by adding 'cfdebug' to your URL parameters to see more information]
The message is correct, but how can I avoid to run the getcustomer function when the value is not numeric?
Here is my code:
The form:
<cfinput type="text" name="customer_no" style="width:140;background-color:yellow" maxlength="10"  validate="integer" validateat="onblur"   message="Customer No. format is integer">
<cfinput type="text" name="customer_name" style="width:170" maxlength="200" bind="cfc:customer.getcustomer({customer_no})" readonly="yes">
customer.cfc:
<cfcomponent >
<cffunction name="getcustomer" access="remote" returntype="string" output="yes"  >
    <cfargument name="cust_id"   type="numeric"  required="true" >
                 <cfset  r_customer = "">
         <cfquery name = "select_customer" dataSource = "x">
        SELECT name
        FROM customer
        WHERE id =  <cfqueryparam   cfsqltype="cf_sql_numeric" value="#arguments.cust_id#" >
        </cfquery>
<cfreturn r_customer>
</cffunction>
</cfcomponent>
Views
917
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , Mar 28, 2012 Mar 28, 2012
Change the argument to type="any", then use isNumeric() inside your function. If it's not numeric, return an empty string.
Votes
Translate
Translate
Guide ,
Votes
Translate
Translate
Report
Report
Participant ,
Yes it works. Thank you very much!
Votes
Translate
Translate
Report
Report
Guide ,
Sometimes the simplest solutions are the best
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
That is a trick question! The attribute bind="cfc:customer.getcustomer({customer_no})" implies that the function will run automatically, whether or not customer_no is numeric.
Votes
Translate
Translate
Report
Report
Resources
Documentation
