So once again, I am trying to create seperate external SWFs for my site in order to drastically reduce load times and each SWF loads a different section of my portfolio. This code worked for the first external SWF:
var myLoader:Loader = new Loader();
var url:URLRequest = new URLRequest("flashfiles/bwphoto.swf");
myLoader.load(url);
bwanchor.addChild(myLoader);
But now on a different area in the timeline when I try to use it on a different movie clip with a different SWF and URL, it doesn't work. It gives me two errors:
1151: A conflict exists with definition myLoader in namespace internal
1151: A conflict exists with definition url in namespace internal
What do these mean? And does someone maybe just have a better code to unload and load multiple external SWFs? Keep in mind it can be just click to load, click again to unload because each SWF has its own navigation to change the image shown.
Thanks again for any help.
The errors seem to indicate that you are trying to declare the same variables again, namely 'myLoader' and 'url'.
var url:URLRequest ...
When you use "var" you are declaring a variable.
You cannot declare a variable more than once in a file. So either use new variable names, or do not use the "var" declaration for any other times you use those variables in the file. LAter in the timeline you could try using...
myLoader = new Loader();
url = new URLRequest("flashfiles/someother.swf");
When I delete the "var" I get two errors for each line:
1067: Implicit coercion of a value of type flash..display:Loader to an unrelated type Class.
1088: Illegal assignment to class Loader.
I think you have a general idea of what I am trying to do though, do you maybe have a code or a link that can refer me to the code I need? Also I'm trying to understand Action Script better in general. How would I go about using "new variable names?"
And I really appreciate the help so I apologize if I annoy you at any time.
I'd have to see what you did for the code to try to unravel the error messages.
As far as creating new variables, you just do.. that... instead of using "myLoader" and "url", you use new words...
var myOtherLoader:Loader = new Loader();
var anotherUrl:URLRequest = new URLRequest("flashfiles/bwphoto.swf");
North America
Asia Pacific
