Prangne
BrowserLab - issue from DW CS5
Mar 29, 2012 7:33 PM
Tags: #browserlab
I know this has been in another post - -but the successful solution wasn't revealed.
Would appreciate Carey passing on the wisdom
Thanks.
    Mar 30, 2012 10:32 AM   in reply to Prangne
    Hi Prangne,
    I'll contact you via a PM here on the forums.
    Mark
    Apr 3, 2012 3:56 PM   in reply to Mark Rausch
    I sent the PM to you on the 30th but haven't heard a response back. Have you received it, do you still have the same issue?
    Apr 4, 2012 10:31 AM   in reply to Prangne
    Hi Prangne,
    I've sent you instructions and a link in a PM to help you find and edit that file. Follow those instructions and then close and reopen DW and find and click on the CS Live menu button... do you see a normal menu, or does it contain an error message? If you see a normal menu, try your test again with BrowserLab. If you see an error message, take a screenshot of it and post it here please, there's another step I can have you try.
    FYI, this is not a moot point, we're not dropping support for this integration, at least in existing copies of CS5 & 5.5. Do you know where you read that? If you can point me to it that would be great.
    Mark
    Aug 14, 2012 6:32 AM   in reply to Mark Rausch
    Why don't you guys simply post the solution?
    That'd be great^^
    Thanks in advance
    Aug 15, 2012 1:44 PM   in reply to ssklnd
    We've determined that there are two possible causes to this issue:
    - The software is not properly activated.
    - You (or an administrator) have disabled Internet access for Adobe online services.
    To check if access to Adobe online services have been disabled on your computer, see this article: Disable access to Adobe CS service extensions
    If that is not the issue, then the cause has to do with activation. Te resolve the issue, perform the steps in the solution of this article: http://helpx.adobe.com/x-productkb/policy-pricing/activation-network-i ssues.html
