Cannot open Nikon D4 NEF files
Mar 29, 2012 11:51 PM
Cannot open Nikon D4 NEF files in Photoshop CS5 and Camera Raw 6.6 … any suggestions?
    Mar 30, 2012 2:38 AM   in reply to RiverThames
    Use 6.7RC.
    6.6, as you've found out, doesn't support the D4 as this camera wasn't released when ACR 6.6 came out.
    M
    Mar 30, 2012 8:57 AM   in reply to RiverThames
    I understand that the full release of CS6 will support the D4 (and D800). It's just a bit of a blip that ACR 6.7RC of ACR supports them, whilst ACR 7.0 (CS6 beta) currently doesn't.
    (You say "everybody", but it was just me! )
    M
    Jun 11, 2012 8:53 AM   in reply to Mollysnoot
    This seems idiotic. If I recently purchased CS5.5 suite and am stuck with Photoshop CS5.1, is there any way out for me? I have no plans to acquire CS6.0, only three months into my upgrade from CS4 to CS5.1
    Jun 11, 2012 3:47 PM   in reply to SingralliSeenu
    Use ACR6.7 available here, not idiotic at all!!
    Jun 11, 2012 4:10 PM   in reply to Geoff the kiwi
    Geoff, I did install 6.7 RC , blew the Camera Raw directory
    under appdata and still face the same problem
    Was chatting live with Adobe tech support for about 44 minutes
    this morning and the only thing they finally were able
    to recommend was to re-install CS5.1. I  yet
    to try that out, will let you know if I was being
    idiotic after all.
    Jun 11, 2012 4:12 PM   in reply to SingralliSeenu
    Ok, I meant to type 45 minutes and didn't pull that
    44 from Netherlands ;-)
    Jun 11, 2012 4:24 PM   in reply to SingralliSeenu
    Did you install ACR6.7 manually or via the Updater?
    I would also try removing the Preference file before reinstalling.
    Jun 12, 2012 1:15 AM   in reply to SingralliSeenu
    ACR 6.7 is now available as a full release - has been for several weeks - so I'd install that rather than the release candidate. It should automatically install via PS, but if not, use the check for updates menu option to kick start it. Your ACR will then be able to read D4 files (I assume that's what you have, although you don't say in your post above).
    M
    Jun 12, 2012 7:58 AM   in reply to Mollysnoot
    I am now officially perplexed. Tried all of the following
    a) Cleaned up appdata/Adobe/Camera RAW => tried opening the RAW file, (each time a different one so I don't use the same XMP)
    b) Removed the Photoshop preferences file   =>  ""
    c) Removed Registry entry for Camera RAW =>  ""
    d) Uninstalled CS5.5 and re-installed (as suggested by Adobe Customer service folks) => ""
    DIDNT WORK. YES, I USED UPDATE FEATURE IN PHOTOSHOP TO GET LATEST CAMERA RAW, NOT RC
    e) Installed CS6, went straight for updates and it did install Camera RAW 7.1.
    Tried to open the file, same old message.
    And, I also downloaded Lightroom 4.1. Couldn't import the files. Went straight for the update, nope, it said I don't need any.
    It's now been 48 hours into this problem and never been more frustrated.
    Jun 12, 2012 8:09 AM   in reply to SingralliSeenu
    Hmmm. Well there may be an issue with your machine, or perhaps even with the raw files themselves.
    What error message are you getting? You've not actually clarified (you say "same old message"...). What camera are you using (again, you've not clarified, but I would have to assume D4; still be useful for you to clarify though)? What system - Windows, Mac - and spec? With a bit more detail and clarity someone may be able to help you out here.
    M
    Jun 12, 2012 8:16 AM   in reply to Mollysnoot
    I am using a Windows 7 machine.  Core i7, About a dozen gigs of RAM...if it matters.
    With the latest CS6/ RAW 7.1, I get the message "Photoshop cannot open this file"..
    "If you are attempting to open a raw file from a digital camera, make sure you have the latest Camera Raw updated....
    I did shoot with a Nikon D4.
    Jun 12, 2012 11:12 AM   in reply to SingralliSeenu
    The files are not taken in 16:9 by any chance?
    Jun 12, 2012 11:57 AM   in reply to Geoff the kiwi
    Aaargh. Honestly, I'm not sure. The rental folks
    gave me the camera without a manual, and given
    two six hour shoots over the weekend, I confess
    I didn't check that. Just went on using the camera
    as if it  were a D3.  Except pushing the ISO to
    to 128000 and beyond.
    Is there a reason you ask that question, and if I can
    confirm from my EXIF, what are my alternatives
    P.S: I confirmed with a downloaded trial copy
    of CaptureNX2 that I  am actually able to
    open these files now. I don't really like to deal
    with this extra step of converting to TIF via
    CaptureNX2 and then processing in Photoshop
    Jun 12, 2012 12:13 PM   in reply to SingralliSeenu
    There was an error with files shot in that format, I don't recall right now if the fix has been implemented yet although I thought it was.
    Perhaps you could let me have a file to see if I can open one.
    Jun 12, 2012 12:30 PM   in reply to Geoff the kiwi
    The 16:9 D4/D800 NEF import issue as posted at the below link is showing status of 'Acknowledged,' but not 'Solved.'
    http://feedback.photoshop.com/photoshop_family/topics/nikon_d800_nef_f ile_cannot_be_imported_with_lightroom_4
    Jun 13, 2012 7:26 AM   in reply to SingralliSeenu
    Another discovery. CaptureNX2 opens up my
    .NEF format files as if they are JPG ! So even CaptureNX2
    cannot read the embedded RAW. Spoke with
    Nikon guys and they claim Nikon Transfer only writes
    bit by bit and doesn't do any file manipulation
    Now I doubt the claim :-((
