Image format not working automatically when linking to Frame files
Mar 30, 2012 9:42 AM
I have a project in RoboHelp that has linked Frame files. I've fiddled with the settings until I can update and publish without having to make any changes to most of the RoboHelp project's files. However, there is a problem with the images. My group's standard is to center the images. All the settings are set for that. However, they are left-aligned in the generated CHM file, unless I double click one image in each topic to open the Image Properties box, make NO changes, and click OK to close the Image Properties box. I've checked the HTML code before and after doing this, and there is no change, but then all the images in each topic that I did this to will appear centered in the generated CHM file. Since I have about 100+ graphics in this project, it would be nice if I could get the settings to take effect without having to go through this exercise. Anyone know how to make RoboHelp recognize the settings without having to touch an image in each topic in the project?
    Mar 30, 2012 9:47 AM   in reply to JayHBar
    My first instinct would be to ask if the images are attached to some style - then maybe you could fiddle with the alignment in the CSS for that style. I don't currently have any images in any of my FM to RH projects, so I don't know if this works or not.
    Mar 30, 2012 9:57 AM   in reply to JayHBar
    So, it's messed up if you just generate help, but it's ok if you "pseudo-edit" a topic & then generate? If that's the case, I'd think I'd be looking at the CSS controlling how it looks when generated. The RH topic editor isn't 100% accurate on how something's going to look.
    Mar 30, 2012 10:27 AM   in reply to Jeff_Coatsworth
    It sounds like the CSS has some context-based settings that are formatting the image.
    If you view the CSS as a text file, you can search for the tag to see if there are multiple CSS entries at work. Try commenting out any that seem odd to see if that fixes your problem.
    (or, if that doesn't make sense, go buy lunch for your "web expert" and have them do the above!)
    Can you post the html for the image?
    -Matt
    @mattrsullivan
    Mar 30, 2012 11:28 AM   in reply to JayHBar
    hmm, so the <div> center looks to be overwritten by the <image> left
    I've forwarded to Adobe's RoboAsh (Ashish Gupta) but they're likely gone for the weekend.
    I've had luck fiddling with the Anchored Frame options in FM to get what I want. I can't recall what my settings were, but Below Current Line, and Centered/Left/Right always seem to have worked for me.
    -Matt
    @mattrsullivan
