speaker10
Receiving Error 2048 - Resource will not load
Mar 30, 2012 3:35 PM
I recently upgarded my flash player to the most recent version.  I am using Windows XP Home addition 32-bit system.  Now when when the flash content tries to run I receve an Error 2048 and "failed to load the resource" and "can not access the resource file".  It apparently is not an installation proble.  Is there something on my system's security settings that is keeping the flash content from working?  How do I clear that up?
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 4:45 PM   in reply to speaker10
    Do you have a URL where I can see this occur?
    Chris
  • Chris Campbell
    May 4, 2010
    Apr 2, 2012 12:17 PM   in reply to speaker10
    I wasn't able to reproduce this using either Win 7 or XP and IE with Flash Player 11.2.  Could you try running through a clean install to see if that helps?
    How do I do a clean install of Flash Player?
  • Chris Campbell
    May 4, 2010
    Apr 3, 2012 2:48 PM   in reply to speaker10
    Great to hear, thank you for letting me know.
    Apr 16, 2012 4:58 AM   in reply to Chris Campbell
    Hi Chris,
    This is regarding error #2048 and #2032.One of my user got  error #2032 when he tried to access the application I have made.
    To understand the error i compiled a simple flex code and saved the swf file on his desktop and then tried  opening it through internet explorer but i received error #2048 in IE.
    I am not able to understand the cause of the error.the application is working fine everywhere else.I need to fix it at the earliest.
    The sample code which gave the error# 2048 is:
    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:flexiframe="http://code.google.com/p/flex-iframe/"
    layout="vertical"
    verticalAlign="top"
    xmlns:comp="components.*"
    xmlns:local="*"
    horizontalAlign="center"
    paddingTop="2" paddingLeft="2"
    paddingBottom="2"
    paddingRight="2"
    cornerRadius="1"
    alpha="1.0"
    borderStyle="solid"
    width="100%"
    creationComplete="loadData();">
    <mx:Script>
    <![CDATA[
    import flash.events.MouseEvent;
    import flash.net.navigateToURL;
    import flash.sampler.NewObjectSample;
    import mx.collections.ArrayCollection;
    import mx.collections.Sort;
    import mx.collections.SortField;
    import mx.controls.*;
    import mx.controls.DataGrid;
    import mx.controls.List;
    import mx.events.*;
    import mx.events.CloseEvent;
    import mx.events.DataGridEvent;
    import mx.events.IndexChangedEvent;
    import mx.events.ItemClickEvent;
    import mx.managers.PopUpManager;
    import mx.rpc.events.FaultEvent;
    import mx.rpc.events.ResultEvent;
    import mx.utils.ArrayUtil;
    import mx.utils.StringUtil;
    public function loadData():void
    Alert.show("it is in here");
    </mx:Script>
    <mx:VBox width="100%" height="100%" backgroundColor="#f8f8f8" horizontalAlign="center" paddingLeft="5" paddingRight="5" paddingBottom="10">
    <mx:Label width="100%" id="Title" textAlign="center" fontFamily="GE Inspira" fontSize="20" color="#666699" fontWeight="bold" text="Hello"></mx:Label>
    </mx:VBox>
    </mx:Application>
    Regards,
    Sneha
  • Chris Campbell
    May 4, 2010
    Apr 20, 2012 6:46 PM   in reply to UrgentHere
    Hi Sneha,
    Could you please open a new bug report on this over at bugbase.adobe.com?  Please post back with the URL so that others affected can add their comments and votes.
    You might also want to post on the Flash Professional forums?  This forum is primarily for end users, the Pro forums will get you in touch with a wider developer audience.
    Chris
    Nov 26, 2012 10:59 PM   in reply to speaker10
    Most of the peoples always upgrade with new technologies. You are unable to load your source file on your flash player this means your MOV file is corrupted and displaying you an error message 2048. Even I was in identical problem where was unable to run contents of flash on my flash player. Then I used good repair software which helped me to repair error message 2048. Now-a-days there are many repair software’s available in market reviewed by industry experts. One such software is Repair MOV file software. First you can make use of its free version and later if satisfied with results then can go for full form.
    shanky
