Hello, i'm creating a game with Director using Lingo. Basically its a game which has targets moving down the screen at random horizontal positions. Currently i have 5 target sprites with the script below attached to each of them. I want to make the same thing but only use 1 target sprite however i'm not sure how to go about this. I want targets randomly being created at a random intial vertical location then for them to go down the screen. You'll see what i mean in the link to the game below. Thanks any help is appreciated even some pseudocode on how i would go about solving this problem would be useful.
Thanks Graham.
Game link: http://www.andkon.com/arcade/adventureaction/targetmania/
Lingo script currently attached to 5 target sprites:
property pSprite, pVInitLoc, pHInitLoc, pEndLoc, pSpeed
on beginSprite me
pSprite=sprite(me.spritenum)
pVInitLoc=-50
pEndLoc=650
pSpeed=random(1,4)
pSprite.locV=pVInitLoc
pSprite.locH=(random(10)*50)-25
end
on exitFrame me
pSprite.locv=pSprite.locv+pSpeed
if pSprite.locV>pEndLoc then
pHInitLoc=(random(10)*50)-25
pSpeed=random(1,4)
pSprite.locH=pHInitLoc
end if
end
Coding and sprites are two different things. The game you link to uses way more than 5 sprites. Using many instances of a single script is efficient. It means you can make one change in one place, and it will affect all the targets.
Writing code that will simulate multiple sprites in a single sprite is not efficient. It's re-inventing the wheel.
Perhaps you could talk to your tutor about what s/he means by "efficient code", and revise your approach accordingly.
Ok will do. I have another question (I HATE LINGO lol). Is there any way to randomly make the sprites appear on the screen at different times rather than using the speed of the sprite to make it look like they are moving in randomly? I'm not to good at wording this stuff should be a wa i can show you lol. Thanks yet again.
you shouldn't use sprite behaviors for a game
sprite behaviors are similar to flash components, it's a tool for application design
more, 99% of simple games are totally procedural, no object class are requiered
so you'd better use an entry point in a global script ("movie"), then from it, call your engine hart in a static class ("parent")
another error: do not use exitFrame/prepareFrame/stepFrame events for a game routine.
use enterFrame instead, this event is called when cpu is free, between 2 render steps
Owen, I can agree with you about using enterFrame... in most cases. (It is perfectly fine to use stepFrame if no changes are made to sprite display or positions within the stepFrame event).
However, I cannot agree with your statements:
and
These statements make me think that you have not explored behaviors or object-oriented programming sufficiently, and that you do not understand the benefits of using these techniques. Perhaps you would like to elaborate on your opinion?
North America
Asia Pacific
