This discussion is archived
Edward M OBrien 11 posts
Dec 17, 2009
Camera RAW 7
Mar 31, 2012 9:29 PM
I'm using the Beta version of CS6 and there is a CAMERA RAW 7 program that I would like to use in my Elements program. The RAW editor in Elements (current) always has the sliders in a pre-set configuration, not at zero. Using CS6 Beta, the Camera RAW (7) editor opens up with the sliders set at zero, a much better way to edit. Since I'm a bit overwhelmed by CS6, I've resorted to RAW editing with the Beta, closing it while saving the .DNG data, then opening up Elements and continuing from there. I'd love to have the RAW 7, but if someone can help with my issues with my version, that's cool too ! I've tried to vary the settings, nothing seems to do the trick. Thanks **
    Apr 1, 2012 7:17 AM   in reply to Edward M OBrien
    Photoshop CS6  (ACR 7) and Lightroom 4 have PV2012 as the default for RAW editing.  Photoshop CS5 with ACR 6.7RC will render a RAW file that was adjusted using PV2012 in either CS6 (ACR 7) or Lightroom 4, but you can't make adjustments using PV2012 in CS5, I expect the same is true in Elements if it has an ACR converter equivalent to the ACR 6.7RC in CS5.  You will have to wait until a new Elements is released that uses PV2012 for RAW conversion instead of PV2010.
    Apr 1, 2012 10:37 AM   in reply to Edward M OBrien
    Whenever ACR is released, there is an installer that works with whatever the current version of Elements is.  Elements is updated to a new version in or around the September timeframe.
    ACR 6.7 is in public beta and ACR 7 is also in public beta as part of CS6.  I would expect that ACR 6.7 will be finalized in the coming weeks and then an installer will be available for Elements.   I would expect CS6 and ACR 7 to be released in the coming months and an installer for ACR 7 be made available for Elements at that time.
    As already stated, ACR 6.7 does not have sliders available to make PV2012 adjustments, but understands how to render them if another Adobe product, like LR4 or CS6/ACR7, has created them.  ACR 7 will have the PV2012 adjustment sliders available to the user, so that is the one you’ll want to wait for to use Elements free of using PS-CS6.
    I would expect both ACR 6.7 and ACR 7 to be available before September so you should be able to use your current Elements with the updated ACR w/o buying a new copy of Elements.
