ScriptUI get path to indesign install directory
Apr 2, 2012 2:08 PM
Does anyone know if there is a way to get a users path to their install directory?
I have script, that creates a new menu item when Indesign starts up.  the menu item is clicked, it opens another script.
Right now, I have the path to the second script hardcoded, which works fine:
     C:\Program Files (x86)\Adobe\Adobe InDesign CS5.5\Scripts\Scripts Panel\DM_Core\DM_RemoveMenu.vbs
but now I have to give this to other users, and I need to know if there is some way to get the installation path that they have to their indesign.
Ultimately, what I would like to get is this:
I have tried scriptsFolder but that doesn't take me to the right place.
Anyone have any ideas.
    Apr 2, 2012 2:50 PM   in reply to BigGunN
    Where did you get "scriptsFolder" from? Your current scripts' folder?
    Anyway, check how far you come with the standard list: http://jongware.mit.edu/idcs5js/pc_Folder.html
    These variables get filled by ID with the correct paths; for anywhere else, you're own your own. Make sure your path is valid under both Mac OS X and under Windoze, as there are a few differences.
  • John Hawkinson
    Jun 25, 2009
    Apr 2, 2012 10:07 PM   in reply to [Jongware]
    Note that the path to a script changes when run from the ESTK versus the Scripts Panel.
    Apr 3, 2012 2:07 AM   in reply to BigGunN
    This should get you what you want:
    function GetScriptsFolder (){
              var scriptsFolder = null;
              do{
              // On Mac this is a folder inside the app package
                        var appFolder = Folder.startup;
                        if (! appFolder.exists){break;}
                        scriptsFolder = Folder(appFolder + "/Scripts");
                        while (appFolder.exists && ! scriptsFolder.exists){
                                  appFolder = appFolder.parent;
                        if (! scriptsFolder.exists){
                                  break;
              while (false);
              return scriptsFolder;
    Harbs
    Apr 4, 2012 4:19 AM   in reply to BigGunN
    Can't you just use:
    Marijan (tomaxxi)
    Apr 4, 2012 5:43 AM   in reply to Marijan Tompa
    Only on Windows.
