Gbar1
Correct syntax of tags / rolls error
Apr 3, 2012 1:35 AM
Tags: #accessibility #accessible_pdfs
I have created a PDF and performed the PAC PDF Accessibility checker and got an "X" on the "Correct syntax of tags / rolls".  The error seems to be occuring where I have a table on the page.  I am not a coder so I am having difficulty in understanding the error.  I have attached a screenshot.  Any help would be greatly appreciated.
    Apr 4, 2012 5:19 PM   in reply to Gbar1
    I'm a little bit ambivalent about PAC's tool.
    I've some reservations about how ISO 32000-1 has been interpreted when setting the tool's "rules".
    (What is considered correct syntax and what is considered proper role mapping are two examples.)
    Consequently, I do not use it as a "sole-source" for checking tagged PDF.
    With that said, the only way to fully validate proper element/tag syntax / semantics is by a "warm-body".
    From the screen capture it appears the problem is related to the Table structure. (?)
    A minor niggle- but "rolls" do not exist in ISO 32000-1's discussion.
    "Role Mapping" does.
    Example: The authoring application styles/paragraph tags are seen as the name of tags in the structure tree.
    So, Word's "Normal" style may be seen.
    However, ISO 32000-1 describes that such must be properly "Role Mapped" to one of the PDF elements (tags) defined in the Standard.
    The PDF producer would role map "Normal" to "Paragraph", <P>.
    Be well...
