Pierce Ewards
Flash uninstaller - Strange activity
Apr 3, 2012 1:18 PM
Hello,
I noticed some unusual behavior with the latest flash uninstaller, can someone explain please?
I download the 32bit flash uninstaller for Windows.
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
When I double-click the uninstaller, a confirmation window appears asking whether I want to run the file.
I select run, then a 2nd confirmation window appears asking again if I want to run the file.
When I select run this time, I get a UAC prompt asking if I want to continue.
Why are there 2 request to run the uninstaller?
If I select run for the first prompt, but cancel the second prompt, the UI for the flash player uninstaller still appears.
I didn't go any further as this behavior was suspicious enough for me to stop. Instead I used a previously saved flash player uninstaller.
I'm wondering what would that second run prompt have executed if I had let it run?
Regards,
Pierce.
    Apr 3, 2012 1:25 PM   in reply to Pierce Ewards
    Just single click on the uninstaller and check , do you get the confirmation window.
    also turnoff the UAC and then check.
    Apr 3, 2012 2:20 PM   in reply to Manish-Sharma
    Moving this discussion to the Installing Flash Player forum.
    Apr 3, 2012 8:46 PM   in reply to Pierce Ewards
    What is your Windows version?
    What you describe I have seen happening when I accidentally triple-click an executable.
    Can you try again with a right-click, then Open (or Run)?
    Apr 4, 2012 7:53 PM   in reply to Pierce Ewards
    I do not know why this is happening; never seen this before.
    Can you try to let it run completely (by clicking OK every time it asks), then post the contents of the FlashInstall.log file (from C:\Windows\system32\Macromed\Flash) here in the forum?  Maybe we can see from that log file what is happening.
  • Chris Campbell
    May 4, 2010
    Apr 4, 2012 11:21 PM   in reply to Pat Willener
    Could you post the contents of your flashinstall.log so we can review it?
    Where do I find the Flash Player installation log on Windows?
    Chris
