pdgmtf
Text appears jagged, unless zoomed into 100 percent.
Apr 4, 2012 7:29 AM
I am having the same or similar problem as Steve [Edit: branched from Indesign 5.5 displays text with ragged edge.]. I have done my best to research this but I cannot figure it out. I am using a Macbook Pro, 15 inch (late2011) with the normal display. I have Leapord 10.7.3. My InDesign is 7.5.2.
The text appears jagged, unless zoomed into 100 percent. Here is a screen shot of the problem at 300 percent:
And here is the exact same file when I zoom into 100 percent:
here is the same text zoomed even more:
The typeface is Baskerville. It prints properly, no jagged edges.
I have tried all the display and text options
Any ideas?
Thanks. Also, do you guys think I should I post a new topic?
Message was edited by: John Hawkinson
Branched from an earlier discussion.
Replies 1 2 Previous Next
    Apr 4, 2012 2:27 AM   in reply to pdgmtf
    Definitely looks like a problem with the display. We've been told for years that we have WYSIWYG displays, but it isn't really true. What you see is CLOSE to what you get depending on the ability of the pixels to display it smoothly.
    Glyphs with round bottoms typically extend slightly below the baseline, and it looks like at some your 100% zoom level the choice is being made to use an extra pixel on the screen rather than lose the bottoms (but look at the G in Good, which looks like the other way). As you zoom in you have more screen pixels to work with for any given part of the text so it gets better, though it wouldn't surprise me if it got wonky at some odd non-incremental zooms like 237%.
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 6:06 AM   in reply to pdgmtf
    'mtf (is that "modulation transfer function"?!):
    I'm slightly confused...your first capture appears to be smaller than the 100% capture, did you resize the image before uploading it? Normally the 300% image should be 3 times bigger than the 100%. Or did you really mean 30%?
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 6:27 AM   in reply to pdgmtf
    I believe Peter is suggesting you have hit the physical limit of the display.
    I'm not yet convinced, but I remain confused about your images.
    You're saying your first photo, the smallest one called Jagged300.png, is really at 100%.
    And the second photo, called notJagged.png that you described as 100% is really 300%.
    And the third photo, Screen+Shot+2012-04-03+at+7.23.21+PM.png, is some unspecified zoom factor?
    I am not seeing jaggedness in the 2nd and 3rd photos. Are you?
    Are you saying the screenshots are not faithful reproductions of the problem? That would be very interesting.
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 6:46 AM   in reply to pdgmtf
    OK, I see the problem now!
    (As an aside, in the unlikely event that you have to explain this to anybody else electronically in the future, circling the problematic letters might be a useful technique).
    In particular, when you say 'ragged', it is that the baselines are uneven, but not that the edges of the letterforms themselves are fuzzy.
    I can't quite tell at first glance whether the letters are smaller, or just shifted up.
    Anyhow, I agree this is weird.
    What's the precise font, font size, and leading? Any other special character or paragraph attributes?
    Can you reproduce this in a blank document with the same text, or is it somehow document-specific?
    To look at it differnetly, what's the minimum we need to try to reproduce this effect on our own systems?
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 7:25 AM   in reply to pdgmtf
    OK, I can easily reproduce this under OS X 10.7.2 with Baskerville Regular (Truetype / Baskerville; 7.0d4e2; 2011-03-16), but not with Minion Pro (OpenType PostScript / 2.108;ADBE;MinionPro-Medium;ADOBE).
    I suspect there's not going to be an easy fix and that this is indeed a bug. Anyone else?
    Sorry if I was not clearly communicating. I guess the original post was not having the same problem, it appeared that way.
    Yeah, I think it's different. I'll try branching off this discussion to a seperate thread, let's see how that works...
    Apr 4, 2012 7:53 AM   in reply to pdgmtf
    I'm with Peter on this one. I get the same "distortion" with some fonts, which would explain that the outline information for the font at a given zoom factor is just displaying differently based on the pixel size of the screen. The Baskerville TrueType version is obviously "built" differently than the OpenType font that John is describing. I certainly wouldn't worry about it; back in the days of OS8 and OS9 and Quark XPress, a user had to simply accept the jaggies onscreen, knowing that the output would be correct.
    Just a thought...
    Cheers!
    Mikey
    Apr 4, 2012 9:07 AM   in reply to pdgmtf
    I have the Bitstream 1.01 Baskerville BT OpenType version installed.
    This is at 100% zoom. Personally, I think it is a font display issue as long as it prints fine.
    Take care, Mike
    Apr 4, 2012 9:22 AM   in reply to pdgmtf
    Are you set for View > Display Performance > High Quailty Display?
  • John Hawkinson
    Jun 25, 2009
    Send me a link to the other thread if you would.
    It's linked from the top of the post, but the older thread was  Indesign 5.5 displays text with ragged edge, and the new thread (this one) is Text appears jagged, unless zoomed into 100 percent.
    There may be some confusion about what is meant by "the display." When Peter wrote earlier, "Definitely looks like a problem with the display," I thought he meant either a hardware limit or a fundamental limit. But now I guess he just meant "the part of the software the displays the font on the screen."
    Well, I think the reason to "worry" is primarily that it's ugly and looks bad and is hard to work in. I don't think anyone is concerned that it might print like this (though that'd be a pretty severe calamity!). It's also disconcerting when the on-screen display doesn't match the printed product; if it is off in one place, then you never know where else it will be off. This means you lose confidence in your display, and even sometimes notice real problems that you dismiss as being artifacts when they aren't. That's really unfortunate.
    So I think it behooves us to get to the bottom of it and report it.
    Surely it's not as simple as "all Truetype fonts do this, OpenType do not"?
    Apr 4, 2012 9:35 AM   in reply to John Hawkinson
    I'm not sure what I meant, other than it is an anomaly in how the type is being presented.  Whether that's a hardware or software limitation, or a combination, I couldn't say. And I would guess it looks different on Macs than it does on my Windows system due to differences in type rendering technology.
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 9:38 AM   in reply to Peter Spier
    Well...does it? Inquiring minds want to know!
    Apr 4, 2012 9:58 AM   in reply to John Hawkinson
    I actually saw this a lot in the PageMaker era - on both Windows and Mac platforms. It was just a fact of life, one that I assumed came down to rendering of different font formats, whether or not there were bitmaps of the font installed, and so on. Haven't seen it in years - but I've not looked for it. Much like font greeking, it's something that I have trained myself to ignore, and to zoom in a bit if I need to see what is going on.
    Apr 4, 2012 10:03 AM   in reply to John Hawkinson
    Considering that there must be at least a half dozen different fonts called Baskerville on my system, and I have no idea which one the OP is using (and his is probably a mac font and not testable here)Untitled-1.png, this isn't much of a test, but here's how Baskerville (TT) Regular (Top) and Baskerville (T1) Normal (bottom) look here at 100% on my 27 " monitor at 1920 x 1200.
    There's perhaps an anomaly in the capita C i circled, but hard to say.
    Apr 4, 2012 10:05 AM   in reply to pdgmtf
    just a quick one: in you mac system preferences: under appearence: is "use LCD font smoothing when available" checked...
    G
    Apr 4, 2012 11:23 AM   in reply to pdgmtf
    Not a good reply, but some versions of some fonts just do not display well. I apologize if this is mentioned further up but I was too lazy to reread the thread. Does your page print properly or export to PDF? If so, I would say it is the font itself. If not, then it is an ID issue.
    Sorry that's the best I have to offer. You are not alone, but usually it is a display issue regarding hinting in the font, or other mysterious font issues.
    Take care, Mike
    Apr 4, 2012 1:39 PM   in reply to pdgmtf
    I think the issue would still be one of display if the print is good, regardless of what is producing the display (ID or Acrobat). A good test would be to put the PDF on a computer without your font and view it in Acrobat (assuming the font is embedded of course). What that could tell you is whether it is a more universal issue with the font, or your system.
    I cannot remember the font, but I had one that on my computer looked like crap both on-screen in PM and in a PDF. Printed great. Looking at that PDF on another persons computer (the service bureau in this case) it looked good. We then threw it on one of the Windows computers and while it didn't look as crispy as the Mac, it was far better than on my computer.
    Take care, Mike
    Apr 4, 2012 2:30 PM   in reply to pdgmtf
    pdgmtf wrote:
    The font is Baskerville Regular. I dont know what other way to describe it there might be.
    Take a look a tthe font properties and tell us the foundry, format, and version number. That's the only way to comapre apples to apples.
  • John Hawkinson
    Jun 25, 2009
    Apr 4, 2012 2:33 PM   in reply to Peter Spier
    Given by yours truly in post #9! Baskerville Regular (Truetype / Baskerville; 7.0d4e2; 2011-03-16).
    Apr 4, 2012 3:00 PM   in reply to John Hawkinson
    Doesn't mean that's the same font as the OP, and you left out the foundry. I hate to tell you how many fonts there are out there named Baskerville...
    My TT version is 2.0 from monotype with a 1995 date, ID reports the T1 version as 1.0 with no foundry listed, and windows refuses to tell me anything-- it opens the tt version instead when I try to view it, but it has a 1990 modification date.
    Apr 4, 2012 3:02 PM   in reply to pdgmtf
    Try right-cliking on the font in Finder and Get Info.  If that doesn't work, try Find Font in ID and click the More Info button.
    Apr 6, 2012 5:25 AM   in reply to pdgmtf
    Hi all! I am having the exact same problem. I'm using InDesign 5 with Baskerville font under Mac OS 10.7.3. The only way I can solve this problem now is to create outline (Types > Create Outlines) of the problematic texts. Still, this solution is very inconvenience. I'll very appreciate a better solution for this problem.
    Apr 6, 2012 6:19 AM   in reply to np1404
    There is no problem, as far as I can see.
    The text looks weird when displayed at a very small size. That's not a surprise; in fact, thinking about it, it's surprising that a 7 pixel capital 'R' can still be recognized as "Baskerville"!
    Fonts are designed at a large size, and every time you see it display at any size smaller than 1,000 pixels (at least!) some of the features you are seeing will be artefacts due to displaying it smaller than the designed size.
    In other words, why complain that the baseline is not straight when there are lots of other "problems" with those very same characters!? (I can see large rectangular chunks, a.k.a. "pixels", which I'm sure are not in the original design. I can also clearly see all sorts of shades of gray, and I am fairly sure this text color is set to "Black". And so on ...)
    When drawing a large character on a coarse screen with a *very* low number of pixels, rounding is inevitable. The less pixels you have, the more "rounding" will be making bad mistakes; and because a single pixel on this size accounts for 1/6th of the total character size, the effect is exagerrated. Compare it to the largest zoomed-in image above; in that image the pixels are also rounded to the nearest "whole" value. For that you suddenly decide that a 1-pixel difference is not important?
    It's all just a screen artefact. The proof is given by the OP himself: "It prints properly, no jagged edges." Of course not -- the printer's resolution is high enough for all rounding to be practically invisible.
    Apr 6, 2012 6:20 AM   in reply to [Jongware]
    .. In the Baskerville case I'm pretty sure the problem is exagerrated because of bad hinting in the font itself. You see how all of the dropped characters have a curve at the lower bottom? That's Bad Hinting.
    Apr 6, 2012 9:34 AM   in reply to [Jongware]
    I booted up the ol' mirror-door G4 to look at this again. My suspicion is that it is entirely font-dependent. My old Baskervilles show this behavior, in both InDesign CS2 and PageMaker 6.5. That means: in both OS 9 and OS X! A bunch of other older fonts display this behavior as well.
    If this bugs you, stop using those fonts. There are (as has already been observed in this thread) many other cuts of Baskerville.
    Apr 6, 2012 9:37 AM   in reply to pdgmtf
    The problem is the baseline of letters changes in different zooms. Despite the fact the file is not changing at all. ...
    The issue is when you have two letters right next to each other, there is no reason that they cannot share the horizontal pixel line. If there is a reason, it should be modified so that what I see on screen represents the file as best as possible. ...
    ...What we are looking for on this thread is suggestions and to find more out about who and why the problem is happening.
    The "suggestions" are what the problems are. The font has bad hinting. You do not have the issue with every font, that is clear. Fonts are little computer applications. Gone are bitmap fonts that had a better correlation on-screen for the OS they were designed for. Instead, modern fonts, even badly designed ones, are little run-time applications. Use a better designed version of Baskerville. It likely will not exhibit the issue for on-screen display--which is what hinting affects. That the font is designed well enough not to exhibit the issue in print says the version you are using is designed well enough for what you are creating. But if the on-screen bugs you enough, try a different version of the font.
    Take care, Mike
1 2 Previous Next
Actions
