ISAPI_Rewrite - Coldfusion 9.0.1 and IIS 7.5
Apr 4, 2012 2:06 PM
I need to resolve canonical URLs :
non-www version should be redirected (301) to www (all pages)
IP address should be redirected to www.mywebsite.com
www.mywebsite.com/index.cfm should be redirected to www.mywebsite.com
I would really appreciate your help on this one as the following code (.htaccess file) redirects only non-www version to www
I'm not sure what to change/add to include all of the above rules.
RewriteEngine on
RewriteCond %{HTTPS} (on)?
RewriteCond %{HTTP:Host} ^(?!www\.)(.+)$ [NC]
RewriteCond %{REQUEST_URI} (.+)
RewriteRule .? http(?%1s)://www.%2%3 [R=301,L]
    Apr 4, 2012 2:10 PM   in reply to pirula08
    Well this has nothing to do with ColdFusion or IIS, but okay.
    Don't bother using ISAPI_Rewrite. IIS7 has its own built-in rewrite engine with a GUI, use that instead.
    Apr 4, 2012 2:22 PM   in reply to Owain North
    Technically its not built in but you can grab it from here: http://www.iis.net/download/URLRewrite
    They have a rule template for exactly what you want to do.
    Apr 4, 2012 2:25 PM   in reply to pirula08
    Well, yeah.  That will cramp your style.
    Apr 5, 2012 2:15 AM   in reply to pirula08
    Why would they recommend using isapi (an old technology) over URL Rewrite, which is a new technology? There's a GUI you can use through IIS, although I appreciate you can't use that on shared hosting. However, all the GUI does is creates an XML file (web.config) in your web root with the rules in.
    Use the GUI on your dev server and copy up the web.config with the rest of your files, job done.
    Apr 5, 2012 3:54 AM   in reply to pirula08
    Honestly I have no idea, as I said this is a ColdFusion forum not an IIS one so I can't help I'm afraid. Does it do what you expect it to?
