I am trying to print a PS in illustrator CS4. The file is quite large, 388 MB. However, this is usually not a problem. I work at a sign company that produces casino signage, so the files from our client are quite large. Any suggestions as to why the program stalls when trying to print? Many times the program crashes all together. My operating system is Snow Lepoard (OS X 10.6.8), if it helps. I have read somewhere in one of these forums, that it may be caused by the fact that Illustrator is not made for 64 bit systems just yet, thus causing a slow down or even an unexpected quit. I have tried dumping preferences, as others on here have suggested. I have also went in & dumped the odd-ball PPD folders within the Library & then restarted. I have tried shutting down, then "safe-boot" open the system back up. I have also "Verified Disk" numerous times. All of these options don't seem to help at all. When it comes down to the file itself, Illustrator fails. I have even tried to created the file over again in a brand new document, as I figured that file must have been corrupt. No such luck. Anyone out there happen to have some other suggestions on what to do to get this to, at the least, print to a postscript? Currently the print screen doesn't even pop up.
Remove the following files and back them up
Hard Drive]/Library/Printers/PPDs/contents/Resources/en.lproj
[Hard Drive]/Library/Printers/PPDs/contents/Resources/Zh_CN.lproj
[Hard Drive]/Library/Printers/PPDs/contents/Resources/Ja.lproj
[Hard Drive]/Library/Printers/PPDs/contents/Resources/ko.lproj
[Hard Drive]/Library/Printers/PPDs/contents/Resources/Zh_TW.lproj
You do not mention the printer itself. Are you processing via a Postscript RIP? I sense you may be running low on system real estate ( i.e., scratch disk memory and / or RAM ). Try closing all other apps, well all apps and restart. Then just open Illustrator and see if the file will open and print. All of this deleting of system resources is not necessary yet. How much disk space do you have available for scratch?
I am trying to print via Postscript RIP. The .PS file will then be put on the server for our printer in another department to pull down. He brings up the PS file into his WASATCH RIP software.
I have 177.85 GB available – that is not the issue. I have also tried closing all programs & only have the one open. I have even done what you have suggested, John. No dice. ![]()
These are the details to the most current crash that happened about 10 mins ago...... I had shut off a layer & then tried to print. It crashed.
| Process: | Adobe Illustrator [1685] |
| Path: | /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator |
| Identifier: | com.adobe.illustrator |
| Version: | 367 (14.0.0) |
| Code Type: | X86 (Native) |
Parent Process: launchd [130]
| Date/Time: | 2012-04-05 09:56:16.373 -0500 |
| OS Version: | Mac OS X 10.6.8 (10K549) |
Report Version: 6
| Interval Since Last Report: | 84649 sec |
| Crashes Since Last Report: | 8 |
Per-App Interval Since Last Report: 78248 sec
Per-App Crashes Since Last Report: 8
| Anonymous UUID: | 4927D96A-08FA-473E-A069-6BF9A894DCD4 |
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000cca20
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
| 0 com.apple.QD | 0x08263704 BBFastDoubleSrcCopy + 405 | |
| 1 com.apple.QD | 0x082a6210 Stretch + 3515 | |
| 2 com.apple.QD | 0x0826a27a OneSrcOneDst + 59 | |
| 3 com.apple.QD | 0x0826aeb8 CommonBits + 1316 | |
| 4 com.apple.QD | 0x0826c490 StdBits + 878 | |
| 5 com.apple.QD | 0x0826abee CommonBits + 602 | |
| 6 com.apple.QD | 0x0826b717 CopyBits + 780 | |
| 7 com.adobe.coretech.adm | 0x14965975 0x14900000 + 416117 | |
| 8 com.adobe.coretech.adm | 0x1491c212 0x14900000 + 115218 | |
| 9 com.adobe.coretech.adm | 0x14920a8a 0x14900000 + 133770 | |
| 10 ...e.illustrator.plugins.Print | 0x12ae61bb 0x12ab6000 + 197051 | |
| 11 ...e.illustrator.plugins.Print | 0x12ae6ab8 0x12ab6000 + 199352 | |
| 12 com.adobe.coretech.adm | 0x14908e43 0x14900000 + 36419 | |
| 13 com.adobe.coretech.adm | 0x1496326c 0x14900000 + 406124 | |
| 14 com.adobe.coretech.adm | 0x14959efd 0x14900000 + 368381 | |
| 15 com.adobe.coretech.adm | 0x1491a7cf 0x14900000 + 108495 | |
| 16 com.adobe.coretech.adm | 0x14908e43 0x14900000 + 36419 | |
| 17 com.adobe.coretech.adm | 0x14958fa5 0x14900000 + 364453 | |
| 18 com.adobe.coretech.adm | 0x1495e42e 0x14900000 + 386094 | |
| 19 com.apple.HIToolbox | 0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 | |
| 20 com.apple.HIToolbox | 0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 | |
| 21 com.apple.HIToolbox | 0x055887f3 SendEventToEventTarget + 52 | |
| 22 com.apple.HIToolbox | 0x055990f9 SendEvent(unsigned long, WindowData*, OpaqueRgnHandle*) + 203 | |
| 23 com.apple.HIToolbox | 0x05598f84 PaintWindow(WindowData*, OpaqueRgnHandle*, PaintReason, bool) + 495 | |
| 24 com.apple.HIToolbox | 0x0558bdd8 WindowData::PrepareForVisibility() + 236 | |
| 25 com.apple.HIToolbox | 0x0558b338 _ShowHideWindows + 291 | |
| 26 com.apple.HIToolbox | 0x0558b212 ShowHide + 38 | |
| 27 com.adobe.coretech.adm | 0x1497b4bf 0x14900000 + 505023 | |
| 28 com.adobe.coretech.adm | 0x1495dc99 0x14900000 + 384153 | |
| 29 com.adobe.coretech.adm | 0x14919ebe 0x14900000 + 106174 | |
| 30 ...e.illustrator.plugins.Print | 0x12ae2206 0x12ab6000 + 180742 | |
| 31 com.adobe.coretech.adm | 0x14908d85 0x14900000 + 36229 | |
| 32 com.adobe.coretech.adm | 0x1491162f 0x14900000 + 71215 | |
| 33 com.adobe.coretech.adm | 0x149127fb 0x14900000 + 75771 | |
| 34 com.adobe.coretech.adm | 0x1495a871 0x14900000 + 370801 | |
| 35 com.adobe.coretech.adm | 0x14918c53 0x14900000 + 101459 | |
| 36 ...e.illustrator.plugins.Print | 0x12abfbc8 0x12ab6000 + 39880 | |
| 37 ...e.illustrator.plugins.Print | 0x12ab78ff 0x12ab6000 + 6399 | |
| 38 ...e.illustrator.plugins.Print | 0x12abdfee 0x12ab6000 + 32750 | |
| 39 ...e.illustrator.plugins.Print | 0x12ae89ee PluginMain + 422 | |
| 40 com.adobe.illustrator | 0x006a93ff 0x1000 + 6980607 | |
| 41 com.adobe.illustrator | 0x006a89c6 0x1000 + 6977990 | |
| 42 com.adobe.illustrator | 0x00586d75 0x1000 + 5791093 | |
| 43 com.adobe.illustrator | 0x00160725 0x1000 + 1439525 | |
| 44 com.adobe.illustrator | 0x003f2ac2 0x1000 + 4135618 | |
| 45 com.adobe.illustrator | 0x004d43e5 0x1000 + 5059557 | |
| 46 com.adobe.illustrator | 0x000fedbe 0x1000 + 1039806 | |
| 47 com.apple.HIToolbox | 0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 | |
| 48 com.apple.HIToolbox | 0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 | |
| 49 com.apple.HIToolbox | 0x055887f3 SendEventToEventTarget + 52 | |
| 50 com.apple.HIToolbox | 0x055b4e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448 | |
| 51 com.apple.HIToolbox | 0x05711ed6 ProcessHICommand + 68 | |
| 52 com.adobe.illustrator | 0x000feb75 0x1000 + 1039221 | |
| 53 com.apple.HIToolbox | 0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 | |
| 54 com.apple.HIToolbox | 0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 | |
| 55 com.apple.HIToolbox | 0x055887f3 SendEventToEventTarget + 52 | |
| 56 com.adobe.illustrator | 0x00080d3e 0x1000 + 523582 | |
| 57 com.apple.HIToolbox | 0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 | |
| 58 com.apple.HIToolbox | 0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 | |
| 59 com.apple.HIToolbox | 0x05565d55 SendEventToEventTargetWithOptions + 58 | |
| 60 com.apple.HIToolbox | 0x0559aa24 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006 | |
| 61 com.apple.HIToolbox | 0x05567080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 | |
| 62 com.apple.HIToolbox | 0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 | |
| 63 com.apple.HIToolbox | 0x055887f3 SendEventToEventTarget + 52 | |
| 64 com.apple.HIToolbox | 0x05711c17 ToolboxEventDispatcher + 86 | |
| 65 com.apple.HIToolbox | 0x05711d4f RunApplicationEventLoop + 243 | |
| 66 com.adobe.illustrator | 0x00080f83 0x1000 + 524163 | |
| 67 com.adobe.illustrator | 0x000d84ab 0x1000 + 881835 | |
| 68 com.adobe.illustrator | 0x000a2cd2 0x1000 + 662738 | |
| 69 com.adobe.illustrator | 0x00003672 0x1000 + 9842 | |
| 70 com.adobe.illustrator | 0x00003599 0x1000 + 9625 |
Thread 1: Dispatch queue: com.apple.libdispatch-manager
| 0 libSystem.B.dylib | 0x05335382 kevent + 10 | |
| 1 libSystem.B.dylib | 0x05335a9c _dispatch_mgr_invoke + 215 | |
| 2 libSystem.B.dylib | 0x05334f59 _dispatch_queue_invoke + 163 | |
| 3 libSystem.B.dylib | 0x05334cfe _dispatch_worker_thread2 + 240 | |
| 4 libSystem.B.dylib | 0x05334781 _pthread_wqthread + 390 | |
| 5 libSystem.B.dylib | 0x053345c6 start_wqthread + 30 |
Thread 2:
| 0 libSystem.B.dylib | 0x0530eb42 semaphore_wait_signal_trap + 10 | |
| 1 libSystem.B.dylib | 0x0533c6f8 _pthread_cond_wait + 1089 | |
| 2 libSystem.B.dylib | 0x0538505f pthread_cond_wait + 48 | |
| 3 com.adobe.amt.services | 0x047e2552 AMTConditionLock::LockWhenCondition(int) + 46 | |
| 4 com.adobe.amt.services | 0x047dd995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115 | |
| 5 com.adobe.amt.services | 0x047e25b0 AMTThread::Worker(void*) + 20 | |
| 6 libSystem.B.dylib | 0x0533c259 _pthread_start + 345 | |
| 7 libSystem.B.dylib | 0x0533c0de thread_start + 34 |
Thread 3:
| 0 libSystem.B.dylib | 0x0533caa2 __semwait_signal + 10 | |
| 1 libSystem.B.dylib | 0x0533c75e _pthread_cond_wait + 1191 | |
| 2 libSystem.B.dylib | 0x0533e3f8 pthread_cond_wait$UNIX2003 + 73 | |
| 3 ...ple.CoreServices.CarbonCore | 0x05f8e21e TSWaitOnCondition + 126 | |
| 4 ...ple.CoreServices.CarbonCore | 0x05f79b68 TSWaitOnConditionTimedRelative + 202 | |
| 5 ...ple.CoreServices.CarbonCore | 0x05f75533 MPWaitOnQueue + 250 | |
| 6 AdobeACE | 0x0132038d 0x12ef000 + 201613 | |
| 7 AdobeACE | 0x0131fd85 0x12ef000 + 200069 | |
| 8 ...ple.CoreServices.CarbonCore | 0x05f5954a PrivateMPEntryPoint + 68 | |
| 9 libSystem.B.dylib | 0x0533c259 _pthread_start + 345 | |
| 10 libSystem.B.dylib | 0x0533c0de thread_start + 34 |
Thread 4:
Thread 5:
Thread 6:
| 0 libSystem.B.dylib | 0x0530eafa mach_msg_trap + 10 | |
| 1 libSystem.B.dylib | 0x0530f267 mach_msg + 68 | |
| 2 ...ia.Flash Player.authplaylib | 0x1872363e ExternalPlayer_Initialize + 1865604 | |
| 3 libSystem.B.dylib | 0x0533c259 _pthread_start + 345 | |
| 4 libSystem.B.dylib | 0x0533c0de thread_start + 34 |
Thread 7:
| 3 ...ia.Flash Player.authplaylib | 0x1854fba6 0x18268000 + 3046310 | |
| 4 ...ia.Flash Player.authplaylib | 0x18571f81 ExternalPlayer_Initialize + 90311 | |
| 5 ...ia.Flash Player.authplaylib | 0x1854ff98 0x18268000 + 3047320 | |
Thread 8:
Thread 9:
Thread 10:
Thread 11:
| 0 libSystem.B.dylib | 0x0530ec0e mach_wait_until + 10 | |
| 1 libSystem.B.dylib | 0x05396429 nanosleep + 345 | |
| 2 ...r.plugins.Scripting Support | 0x14dc589d PluginMain + 458031 | |
| 3 ...r.plugins.Scripting Support | 0x14dc58fd PluginMain + 458127 | |
| 4 ...r.plugins.Scripting Support | 0x14dc9402 PluginMain + 473236 | |
| 5 ...r.plugins.Scripting Support | 0x14dc5bbf PluginMain + 458833 | |
Thread 12:
| 0 libSystem.B.dylib | 0x0530eb36 semaphore_wait_trap + 10 | |
| 1 com.adobe.illustrator | 0x00af8512 AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 471694 | |
| 2 com.adobe.illustrator | 0x00526ec1 0x1000 + 5398209 | |
| 3 com.adobe.illustrator | 0x0052713b 0x1000 + 5398843 | |
| 4 ...ple.CoreServices.CarbonCore | 0x05f5954a PrivateMPEntryPoint + 68 | |
| 5 libSystem.B.dylib | 0x0533c259 _pthread_start + 345 | |
| 6 libSystem.B.dylib | 0x0533c0de thread_start + 34 |
Thread 13:
Thread 14:
| 0 libSystem.B.dylib | 0x0530eb4e semaphore_timedwait_trap + 10 | |
| 1 ...ple.CoreServices.CarbonCore | 0x05f8b942 MPWaitOnSemaphore + 125 | |
| 2 MultiProcessor Support | 0x130c6eff 0x13097000 + 196351 | |
| 3 ...ple.CoreServices.CarbonCore | 0x05f5954a PrivateMPEntryPoint + 68 | |
| 4 libSystem.B.dylib | 0x0533c259 _pthread_start + 345 | |
| 5 libSystem.B.dylib | 0x0533c0de thread_start + 34 |
Thread 15:
Thread 16:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xff030303 ebx: 0x0000002e ecx: 0x00000000 edx: 0x000cca20
edi: 0xbfffc180 esi: 0x0000002e ebp: 0xbfffba18 esp: 0xbfffb9b0
ss: 0x0000001f efl: 0x00010286 eip: 0x08263704 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x000cca20
Binary Images:
| 0x1000 - 0xe8eff3 +com.adobe.illustrator 367 (14.0.0) <F586A10F-F480-4783-A20B-C006B6321F47> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator |
0x1190000 - 0x11a0fff com.apple.carbonframeworktemplate 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/Alcid.framework/Versions/A/Alcid
0x11a7000 - 0x11b5fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x11ba000 - 0x11baff7 com.apple.Carbon 150 (152) <BFDDA394-0F01-A3A3-A226-ED3A45975A56> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x11bd000 - 0x11d8ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFSettings.framework/Versio ns/A/AdobePDFSettings
0x11f2000 - 0x1242fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <F625B836-9616-46B7-B681-F9AC11D0DA71> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPor t
0x12db000 - 0x12dc027 +SPBasic ??? (???) <B1DC5A08-15C4-49F9-9DF1-6A94E0AD3448> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBa sic
0x12e0000 - 0x12e6ff7 +com.adobe.coretech.adobesplashkit AdobeSplashKit version 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSplashKit.framework/Versions /A/AdobeSplashKit
0x12ef000 - 0x13fcfff +AdobeACE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeACE.framework/Versions/A/Ado beACE
0x141a000 - 0x1931fef +AdobeAGM ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/Ado beAGM
0x1aaa000 - 0x1aeafef +AdobeARE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeARE.framework/Versions/A/Ado beARE
0x1af4000 - 0x1b18ff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Ve rsions/A/AdobeAXE8SharedExpat
0x1b2b000 - 0x1b45fff +AdobeBIB ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/Ado beBIB
0x1b50000 - 0x1b71ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/ A/AdobeBIBUtils
0x1b7e000 - 0x1e1afef +AdobeCoolType ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeCoolType.framework/Versions/ A/AdobeCoolType
0x1ea5000 - 0x1f73fff +AdobeExtendScript 3.7.0 (compatibility 3.7.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeExtendScript.framework/Versi ons/A/AdobeExtendScript
0x1fea000 - 0x20d2fdf +AdobePDFPort ??? (???) <F54A25D1-5E7A-472E-83D1-10D187434C85> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A /AdobePDFPort
0x2117000 - 0x270ffdf +AdobePDFL ??? (???) <8EC2ABBA-52D2-4230-B327-A6827FB2D33A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/Ad obePDFL
0x2853000 - 0x28f4fd7 +AdobeScCore 3.7.0 (compatibility 3.7.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/ AdobeScCore
0x2950000 - 0x29fefd7 +AdobeSVGExport ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSVGExport.framework/Versions /A/AdobeSVGExport
0x2a30000 - 0x2cd9fe2 +AdobeSVGRE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/A dobeSVGRE
0x2dc3000 - 0x2e23fc7 +AdobeXMP ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/Ado beXMP
0x2e32000 - 0x2f07fdd +FileInfo ??? (???) <F0932F89-FC98-4BA9-B4F2-C58D0E71D3C1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/FileInfo.framework/Versions/A/Fil eInfo
0x2f38000 - 0x2f38ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x2f3b000 - 0x2fbdfd7 +AdobeXMPFiles ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/ A/AdobeXMPFiles
0x2fd4000 - 0x30a323b +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUInternationalization.framework /Versions/3.6/libicui18n.dylib.36.0
0x314c000 - 0x3220db7 +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6 /libicuuc.dylib.36.0
0x3281000 - 0x3c3157f +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUData.framework/Versions/3.6/li bicudata.dylib.36.0
0x3c34000 - 0x3ffefef +AdobeMPS ??? (???) <277E01A3-CAC3-4FA9-A591-4BC0A5BC125A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/Ado beMPS
0x408d000 - 0x4243ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtlib.framework/Versions/A/amtli b
0x427a000 - 0x43072cb +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUConverter.framework/Versions/3 .6/libicucnv.dylib.36.0
0x4334000 - 0x470e01f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Version s/3/AdobeLinguistic
0x47c2000 - 0x4863fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/ amtservices
0x4941000 - 0x4e3ffc3 +AdobeOwlCanvas ??? (???) <DC1EE447-FCDB-43C8-B6D2-A5454291C85D> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions /A/AdobeOwlCanvas
0x4f88000 - 0x5018fc3 +WRServices ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/WRServices.framework/Versions/A/W RServices
0x519a000 - 0x519effc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Vers ions/A/AdobeCrashReporter
0x51a4000 - 0x51c0fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogTransport.framework/Versions/A /LogTransport
0x51cb000 - 0x51faff7 +com.adobe.headlights.LogSessionFramework ??? (2.0.0.06112008) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogSession.framework/Versions/A/L ogSession
0x5222000 - 0x5233ffb +LogTransport2 ??? (???) <835B7B84-5A67-370B-AB39-8E448AA81FA0> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogTransport2.framework/Versions/ A/LogTransport2
0x523d000 - 0x5243fff +com.adobe.pip ??? (1.0.0.220) <2CA89939-DFA7-4686-8536-8A1F1107CAF1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePIP.framework/Versions/A/Ado bePIP
0x5249000 - 0x52b3fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x530e000 - 0x54b5ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x5537000 - 0x5541fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x5549000 - 0x554ffff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x5557000 - 0x555affb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x555f000 - 0x5883fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x59c3000 - 0x5a27ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x5a49000 - 0x5a5efff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x5a74000 - 0x5b22ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x5b4c000 - 0x5b8fff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x5bb8000 - 0x5bd4fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x5be4000 - 0x5be6ff7 com.apple.securityhi 4.0 (36638) <FC01BFC4-04DB-96F3-2412-A86CC4F94CB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x5beb000 - 0x5bf5ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x5bfe000 - 0x5bfeff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x5c06000 - 0x5c06ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x5c0e000 - 0x5c88fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x5cba000 - 0x5e35fe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x5f2d000 - 0x5f30fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x5f33000 - 0x6253ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x62c9000 - 0x6375fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x63da000 - 0x641efe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x6445000 - 0x6510fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x656f000 - 0x65effeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x6623000 - 0x6656ff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x666e000 - 0x670bfe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x674a000 - 0x6770ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x6786000 - 0x67e3ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x6803000 - 0x6985fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
0x69e7000 - 0x69f0ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x69fa000 - 0x6a0efe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x6a17000 - 0x6a24ff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x6a2d000 - 0x6adafe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x6aee000 - 0x6afaff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x6afe000 - 0x6b44ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x6b51000 - 0x6db7ff7 com.apple.security 6.1.2 (55002) <A476227B-409D-A457-7D4D-A631A0B4AFDB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x6e94000 - 0x6f4dfe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x6f5b000 - 0x6f98ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x6fb5000 - 0x6fddff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
0x6fe8000 - 0x70e9fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
0x710d000 - 0x737efef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x748c000 - 0x7c7b557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7d43000 - 0x7f05feb com.apple.ImageIO.framework 3.0.5 (3.0.5) <051752C3-8C25-CF4A-9BFB-C7B6D20E58E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x7f64000 - 0x7fc5fe7 com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x7ffd000 - 0x8098fe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x80bf000 - 0x817bfff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x81b2000 - 0x8205ff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x8230000 - 0x8241ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x824e000 - 0x82f6ffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x8323000 - 0x8337ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x8345000 - 0x8345ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x8348000 - 0x8391fe7 libTIFF.dylib ??? (???) <4A3EF156-D4FE-95E2-FA05-7BD76FF27CEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x839c000 - 0x83a0ff7 libGIF.dylib ??? (???) <3B4E6D0B-89EB-251F-3693-5187254D5BE2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x83a5000 - 0x83c0ff7 libPng.dylib ??? (???) <05445692-8AF7-CAB6-EBF5-1F7B3A906CCB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x83c8000 - 0x83caff7 libRadiance.dylib ??? (???) <41E5C5F4-A4C6-0416-08D0-422C88088558> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x83ce000 - 0x83f2ff7 libJPEG.dylib ??? (???) <7EBC924F-B2EE-68B0-4EA0-F99EF54F0306> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x83f9000 - 0x84d9fe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x84e7000 - 0x84e7ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x84ea000 - 0x852cff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x8535000 - 0x85a4ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x85ad000 - 0x89c3ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x8a05000 - 0x8e3aff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x8fc0000 - 0x90c2fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x9116000 - 0x9117ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x911b000 - 0x91d3feb libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9263000 - 0x929dff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
0x92aa000 - 0x92cafe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x92d4000 - 0x9318ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9337000 - 0x96a2ff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9772000 - 0x984cfff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x9897000 - 0x99d4fe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x9a44000 - 0x9a94ff7 com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x9aac000 - 0x9abeff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x9acb000 - 0x9aeaff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9b01000 - 0x9b0fff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9b17000 - 0x9b48ff7 libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x9b50000 - 0x9b71fe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9b7a000 - 0x9b7eff7 IOSurface ??? (???) <F9E6DFC1-8DD9-7C7E-CA85-B80735586E05> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9b86000 - 0x9bc9ff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x9bd7000 - 0x9be2ff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x9bf1000 - 0x9cfdfe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x9d1c000 - 0x9d1fff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x9d24000 - 0x9d28ff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x9d2d000 - 0x9d2eff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9d33000 - 0x9d33ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9d36000 - 0x9db8ffb SecurityFoundation ??? (???) <BFE377A4-C830-3ECA-E69F-8A8094CDA0A6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x9def000 - 0x9df4ff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x9dfc000 - 0x9e02fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9e09000 - 0x9e21ff7 com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9e32000 - 0x9e7ffeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x9e9b000 - 0x9ebdfef com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x9ec7000 - 0x9ed7ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x9ede000 - 0xa7c1ff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0xac5d000 - 0xad8bfe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0xadef000 - 0xadefff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0xadf3000 - 0xb0edfef com.apple.QuickTime 7.6.6 (1789) <38255AA2-8087-5AE0-CA4B-1DDE611540B1> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0xb199000 - 0xb393fcf +AdobeOwl ??? (???) <F209A9B2-9606-4182-93D8-84B349CFBE48> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/Ado beOwl
0xb40e000 - 0xb502ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0xb510000 - 0xb550ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0xb569000 - 0xb61efe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
0xb664000 - 0xb66bff7 com.apple.agl 3.0.12 (AGL-3.0.12) <37255DC6-9FD1-45CC-AC80-A84FD2B5450A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0xc418000 - 0xc419ff7 ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0xc430000 - 0xc43efe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <B408E41B-D90F-4A04-DB72-D61C8C52BFBC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0xc481000 - 0xc484ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0xc49b000 - 0xc49bfff +com.adobe.illustrator.plugins.PlugInRes Localizer version 14.0.0 (14.0.0) <CFE61490-698E-4FAE-988C-C238AC6CAAF8> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Resources/en_US/PlugInRes.aip/Contents/MacOS /PlugInRes
0xc4a3000 - 0xc4b5ff7 libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <EA696A00-4054-6F65-0F86-7901EAB5969F> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0xc5f1000 - 0xc5f3ff7 com.apple.printingprivate.framework.PrintingPrivate 6.1 (15.2) <1A6E0614-420C-1E2B-43DA-722639B1FBCB> /System/Library/PrivateFrameworks/PrintingPrivate.framework/PrintingP rivate
0xc60e000 - 0xc61bffb +com.adobe.illustrator.plugins.Navigator Adobe Navigator Plugin version 14.0.0 (14.0.0) <EEF23D08-D8F5-4F7D-96AC-D9E422E78B90> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Navigator.aip/Contents/Ma cOS/Navigator
0xc6c1000 - 0xc708fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/adobe_caps.framework/Versions/A/a dobe_caps
0xc718000 - 0xc725ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0xc733000 - 0xc733ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0xc7b1000 - 0xc7b2fff +com.adobe.illustrator.plugins.ASLib ASLib version 14.0.0 (14.0.0) <F08F7B7D-86A2-462E-AB7B-B706FEE4B955> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ASLib.aip/Contents/MacOS/ ASLib
0xc7e1000 - 0xc7ecff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x1159e000 - 0x115c0fc7 +com.adobe.illustrator.plugins.TracingUI TracingUI version 14.0.0 (14.0.0) <406A33F8-F301-4540-9A22-A01E2CA0CBE1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/TracingUI.aip/Contents/Ma cOS/TracingUI
0x115c8000 - 0x115d3ff7 +com.adobe.illustrator.plugins.Find Find version 14.0.0 (14.0.0) <DE59DC7B-5D9B-4483-83B9-67D8682B4CD1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Find.aip/Contents/MacOS/Find
0x115ee000 - 0x115f5fff +com.adobe.illustrator.plugins.Action Action version 14.0.0 (14.0.0) <C884784D-9646-47C7-917D-2F6B65521B57> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Action.aip/Contents/MacOS /Action
0x115f9000 - 0x115fcfff +com.adobe.illustrator.plugins.GeometryS Geometry Suite version 14.0.0 (14.0.0) <B30D9BE4-9735-4704-AD8A-467E7C25B9A9> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Geometry.aip/Contents/Mac OS/GeometryS
0x117c0000 - 0x117f3fff libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libTrueTypeScaler.dylib
0x12200000 - 0x122d1fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated .dylib
0x1286f000 - 0x12878fff +com.adobe.illustrator.plugins.FrameworkServer Framework Server version 14.0.0 (14.0.0) <04B2DA5B-B84C-487C-A70E-76163D14D08F> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/FrameworkServer.aip/Contents/MacOS/ FrameworkServer
0x1287c000 - 0x12882ff7 +com.adobe.illustrator.plugins.ArtConverters ArtConverters version 14.0.0 (14.0.0) <0EA7F2D8-904D-4AFC-A177-8569F3E2286A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ArtConverters.aip/Contents/MacOS/Ar tConverters
0x12886000 - 0x128affff +com.adobe.illustrator.plugins.BRSPencilTool Pencil Tool version 14.0.0 (14.0.0) <EF43DD3A-A797-450D-9FF7-4EFD246811A5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/BRSPencilTool.aip/Contents/MacOS/BR SPencilTool
0x128b5000 - 0x128b6ff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x128bb000 - 0x128fcfd0 +com.adobe.illustrator.plugins.SVGFilterEffect SVG Filter Effect version 14.0.0 (14.0.0) <1EE0CFC5-C24B-45D2-8354-84A81D3894F4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Conte nts/MacOS/SVGFilterEffect
0x12913000 - 0x12973fd2 +com.adobe.illustrator.plugins.CharParaStyles CharParaStyles version 14.0.0 (14.0.0) <077E031D-6226-44B2-AF1E-A5DA6320CF91> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/CharParaStyles.aip/Conten ts/MacOS/CharParaStyles
0x12ab6000 - 0x12af2fef +com.adobe.illustrator.plugins.Print Print version 14.0.0 (14.0.0) <0D612170-363B-4D37-9BC2-8A8638A9BC19> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Print.aip/Contents/MacOS/ Print
0x12b8b000 - 0x12b9bff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x12ba6000 - 0x12bacff7 libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
0x12d5c000 - 0x12d75033 +com.adobe.illustrator.plugins.FindReplaceUI FindReplaceUI version 14.0.0 (14.0.0) <223D8BC9-8098-45A4-BD15-17AB5C6C2E0D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Text Filters.localized/FindReplaceUI.aip/Contents/MacOS/FindReplaceUI
0x12d7c000 - 0x12d90fc7 +com.adobe.illustrator.plugins.Flare Flare version 14.0.0 (14.0.0) <0C996E6A-8A83-441C-ABB4-EE621B25CA3F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Flare.aip/Contents/MacOS/Flare
0x12d96000 - 0x12da5fd3 +com.adobe.illustrator.plugins.Flatten Transparency Flatten Transparency version 14.0.0 (14.0.0) <66929E97-D63A-46F2-9ADC-F8C10995DFC3> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/Flatten Transparency.aip/Contents/MacOS/Flatten Transparency
0x12dac000 - 0x12dc1fef +com.adobe.illustrator.plugins.Rasterize Rasterize version 14.0.0 (14.0.0) <20A55512-33F0-4669-BE49-F3ED9E2C1CC5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/Rasterize.aip/Contents/MacOS/Raster ize
0x12dc5000 - 0x12dc6fff +com.adobe.illustrator.plugins.MPSCommon MPSCommon version 14.0.0 (14.0.0) <4CBB7829-A13E-41B3-9273-2223506DE716> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSCommon.aip/Contents/MacOS/MPSCommon
0x12e5a000 - 0x12e83fe3 com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
0x12e94000 - 0x12eadfcb +com.adobe.illustrator.plugins.AssetMgmt Asset Management version 14.0.0 (14.0.0) <27CE4290-30DD-477C-9DD4-D46D6022D8D5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AssetMgmt.aip/Contents/Ma cOS/AssetMgmt
0x12f26000 - 0x12f29fef +com.adobe.illustrator.plugins.KnifeTool Knife Tool version 14.0.0 (14.0.0) <79C5F1A2-6CF0-4A1D-9B50-7BE467DD80A6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/KnifeTool.aip/Contents/MacOS/K nifeTool
0x12f2d000 - 0x12f6eff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x12f7d000 - 0x12fb8ffb libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libFontRegistry.dylib
0x12fd3000 - 0x12ffbfcb +com.adobe.illustrator.plugins.FOConversionSuite FOConversionSuite version 14.0.0 (14.0.0) <D2E6328E-B072-4F58-A8F4-191C1E7A3111> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/FOConversionSuite.aip/Contents/MacO S/FOConversionSuite
0x1300b000 - 0x1300ffeb +com.adobe.illustrator.plugins.ToolSelector Tool Selector version 14.0.0 (14.0.0) <72429655-649D-4EFF-A0AF-DE2BE54FFDC6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ToolSelector.aip/Contents /MacOS/ToolSelector
0x13013000 - 0x13059fe0 +com.adobe.illustrator.plugins.JPEG JPEGFormat version 14.0.0 (14.0.0) <2278DB92-A7A8-4D59-9754-237467F6179C> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/JPEG.aip/Contents/MacOS/JPEG
0x13097000 - 0x130deff7 +MultiProcessor Support ??? (???) <F3BFBFC8-1EE7-419A-AAD4-EABD31CCECD1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/multiprocessor support.plugin/Contents/MacOS/MultiProcessor Support
0x132b2000 - 0x132bdff7 com.apple.CrashReporterSupport 10.6.7 (258) <8F3E7415-1FFF-0C20-2EAB-6A23B9728728> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
0x132d6000 - 0x132ebff0 +com.adobe.illustrator.plugins.ControlPalette ControlPalette version 14.0.0 (14.0.0) <65ADF72A-2398-43F7-9B05-52D7D592BA0E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Control Panel.aip/Contents/MacOS/ControlPalette
0x132f1000 - 0x132f6fef +com.adobe.illustrator.plugins.ShapeS Shape Construction Suite version 14.0.0 (14.0.0) <A8E06D3D-22EB-4391-A488-39435E80F204> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ShapeS.aip/Contents/MacOS/ShapeS
0x132fa000 - 0x132fbfff +com.adobe.illustrator.plugins.FlattenS Flatten Suite version 14.0.0 (14.0.0) <34B0A010-1099-474C-9B2B-4D923FB10287> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FlattenS.aip/Contents/Mac OS/FlattenS
0x14100000 - 0x14551fef com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x1479f000 - 0x147eefe6 +com.adobe.illustrator.plugins.Photoshop Adapter Photoshop Adapter version 14.0.0 (14.0.0) <897C80A3-5E5D-4156-8C80-38FE67F5F275> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Filters.localized/Photoshop Adapter.aip/Contents/MacOS/Photoshop Adapter
0x14900000 - 0x149d3fef +com.adobe.coretech.adm 3.10x04 (3.1) <369EAA04-C054-40EB-AC03-92CE99C7260C> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/AdobeADM.bundle/Contents/MacOS/Adob eADM
0x14af1000 - 0x14b25fc3 +com.adobe.illustrator.plugins.BrushManager Brush Manager version 14.0.0 (14.0.0) <45B1E4C5-0AEC-4C31-BF6E-ECC0888F9386> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/BrushManager.aip/Contents /MacOS/BrushManager
0x14b2e000 - 0x14bdcfc8 +com.adobe.illustrator.plugins.ColorHarmony ColorHarmony version 14.0.0 (14.0.0) <11C2EC2C-29D3-462D-B3A2-771D85D66917> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ColorHarmony.aip/Contents /MacOS/ColorHarmony
0x14bfa000 - 0x14c25ff0 +com.adobe.illustrator.plugins.KinsokuDlg KinsokuDlg version 14.0.0 (14.0.0) <0B0B227F-AA5B-46FB-A6B6-60AE2BFAD347> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/KinsokuDlg.aip/Contents/M acOS/KinsokuDlg
0x14c36000 - 0x14caefdb +com.adobe.illustrator.plugins.PaintStyle Paint Style Palettes version 14.0.0 (14.0.0) <FDFCF271-25E0-46B9-812C-EFB4E49B61A8> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Paint Style Panel.aip/Contents/MacOS/PaintStyle
0x14cba000 - 0x14f68fe7 +com.adobe.illustrator.plugins.Scripting Support Scripting Support version 14.0.0 (14.0.0) <00ED474E-DA84-421D-A0BA-AC17357B1FED> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ScriptingSupport.aip/Cont ents/MacOS/Scripting Support
0x1522c000 - 0x15405fff libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libType1Scaler.dylib
0x15537000 - 0x155b2fde +com.adobe.illustrator.plugins.SwatchLibraries Swatch Libraries version 14.0.0 (14.0.0) <CB45F4C6-5333-417D-8997-C124973041FE> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SwatchLibraries.aip/Conte nts/MacOS/SwatchLibraries
0x155c3000 - 0x155f1068 +com.adobe.illustrator.plugins.SymbolPalette Symbol Palette version 14.0.0 (14.0.0) <DD7DBC72-EF5E-4F52-A102-794BF21F2498> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Symbol Panel.aip/Contents/MacOS/SymbolPalette
0x155fa000 - 0x15613fef +com.adobe.illustrator.plugins.Workspaces Workspaces version 14.0.0 (14.0.0) <E065EBE1-AEF1-47B8-9933-EEB543767C5C> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Workspaces.aip/Contents/M acOS/Workspaces
0x1561a000 - 0x1562d04f +com.adobe.illustrator.plugins.Mojikumi MojiKumiUI version 14.0.0 (14.0.0) <E32A6710-064A-4731-8844-E63F5DC4094F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/Mojikumi.aip/Contents/MacOS/Mojikumi
0x15634000 - 0x1565bfe8 +com.adobe.illustrator.plugins.slicingAttributes Slicing version 14.0.0 (14.0.0) <3A3FCCB7-D888-4949-94FB-74EA1892F2DE> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/sliceAttributes.aip/Contents/MacOS/ slicingAttributes
0x15663000 - 0x1568ffff +com.adobe.illustrator.plugins.PathfinderS Pathfinder Suite version 14.0.0 (14.0.0) <D0D9CCD1-0AEC-4C46-9AA3-F7F97ACCDEF1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PathFinderS.aip/Contents/MacOS/Path finderS
0x15698000 - 0x1569fff3 +com.adobe.illustrator.plugins.ExpandS Expand Suite version 14.0.0 (14.0.0) <29196393-E41C-43EA-8C0C-6260FD7F61FC> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ExpandS.aip/Contents/MacOS/ExpandS
0x156a3000 - 0x156b3fff +com.adobe.illustrator.plugins.DocInfo Document Info version 14.0.0 (14.0.0) <4314802B-CE2E-4AF5-9460-5809DEFF7360> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/DocInfo.aip/Contents/MacO S/DocInfo
0x156ba000 - 0x156f2fef +com.adobe.illustrator.plugins.Snap Snap version 14.0.0 (14.0.0) <29FC35B5-A5D5-4F0C-B721-49E267315B13> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Snap.aip/Contents/MacOS/S nap
0x15702000 - 0x15712ff2 +com.adobe.illustrator.plugins.DropShadow Drop Shadow version 14.0.0 (14.0.0) <50DC2482-540D-4817-8D0E-158E626298DA> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/DropShadow.aip/Contents/MacOS/DropShadow
0x15718000 - 0x1571ffc0 +com.adobe.illustrator.plugins.ADMTP Tool Palette version 14.0.0 (14.0.0) <7E1766B5-2D51-4E83-B515-6F5149B134B2> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Tool Panel.aip/Contents/MacOS/ADMTP
0x15723000 - 0x15732ff3 +com.adobe.illustrator.plugins.Segment Tools Segment Tools version 14.0.0 (14.0.0) <5ADD1377-AC2A-43E7-A418-FA83F4E7DF2F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Segment Tools.aip/Contents/MacOS/Segment Tools
0x15737000 - 0x15754fda +com.adobe.illustrator.plugins.ScatterBrushTool Adobe Scatter Brush Tool version 14.0.0 (14.0.0) <8BEBD742-F42F-49C5-A3F0-FA1C5285A7DA> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ScatterBrushTool.aip/Contents/ MacOS/ScatterBrushTool
0x1575b000 - 0x1575ffef +com.adobe.illustrator.plugins.GlobalAdjust Reshape Tool version 14.0.0 (14.0.0) <D6B5A699-E443-4D3A-87AA-FC7D8E2CB319> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Reshape Tool.aip/Contents/MacOS/GlobalAdjust
0x15763000 - 0x15782fcb +com.adobe.illustrator.plugins.ParticlePaint Symbolism version 14.0.0 (14.0.0) <4A4D97AA-0B5C-4311-83FE-288839029DA7> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ParticleSystem.aip/Contents/Ma cOS/ParticlePaint
0x1578b000 - 0x15794fe7 +com.adobe.illustrator.plugins.Magic Wand Magic Wand version 14.0.0 (14.0.0) <93E02FBC-89CC-4486-B643-7F7B01E3C149> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Magic Wand.aip/Contents/MacOS/Magic Wand
0x15798000 - 0x157afff3 +com.adobe.illustrator.plugins.Liquify Liquify version 14.0.0 (14.0.0) <C16C9B41-5869-4A14-A5B7-8AC978B5FDFD> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Liquify.aip/Contents/MacOS/Liq uify
0x157b3000 - 0x157bafeb +com.adobe.illustrator.plugins.Lasso Lasso version 14.0.0 (14.0.0) <7C893464-927E-4EFC-B6FB-2F3E10F9A199> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Lasso.aip/Contents/MacOS/Lasso
0x157bf000 - 0x157f3fdf +com.adobe.illustrator.plugins.EraserTool EraserTool version 14.0.0 (14.0.0) <1744EECA-69F1-4C93-AA06-B89075F3EEBE> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/EraserTool.aip/Contents/MacOS/ EraserTool
0x157fb000 - 0x15823fec +com.adobe.illustrator.plugins.CalligBrushTool Calligraphic Brush Tool version 14.0.0 (14.0.0) <FA25241B-421C-49D6-BE9D-8BC1430E9828> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/CalligBrushTool.aip/Contents/M acOS/CalligBrushTool
0x1582a000 - 0x1583dff7 +com.adobe.illustrator.plugins.BoundingBox BoundingBox version 14.0.0 (14.0.0) <D05C0C30-D456-4E98-9BC4-92C2294FB49F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/BoundingBox.aip/Contents/MacOS /BoundingBox
0x15841000 - 0x1586cfd6 +com.adobe.illustrator.plugins.ArtBrushTool Art Brush Tool version 14.0.0 (14.0.0) <89FE2B11-D5DD-4DEA-966C-E1A85FB4CBAC> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ArtBrushTool.aip/Contents/MacO S/ArtBrushTool
0x15873000 - 0x1587effe +com.adobe.illustrator.plugins.ai-cut ai-cut version 13 . 0 . 0 . 0 (13 . 0 . 0 . 0) <F00FBE64-CF94-901F-6977-7B648B643B4F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ai-cut.aip/Contents/MacOS/ai-c ut
0x15888000 - 0x158e7fcf +com.adobe.illustrator.plugins.PhotoshopImport Photoshop Import version 14.0.0 (14.0.0) <861DD58E-6EA7-4715-B877-5C75B596C85A> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Formats.localized/PhotoshopImport.aip/Contents/MacOS/PhotoshopImport
0x158fe000 - 0x16630fff +com.adobe.psl AdobePSL 11.0.0.1724 (11.0.0.1724) <6BE27A60-E0F9-4483-8E57-2A7A5227D878> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Ado bePSL
0x16964000 - 0x16990fff +com.adobe.illustrator.plugins.ExpressView Support OS Express Views version 14.0.0 (14.0.0) <4D362918-5276-46B4-9825-5CAE899E9EE5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Filters.localized/ExpressView Support.aip/Contents/MacOS/ExpressView Support
0x1699b000 - 0x169e4ff4 +com.adobe.illustrator.plugins.MPSParser MPSParser version 14.0.0 (14.0.0) <67607461-914F-440E-8624-381CC2A0079E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSParser.aip/Contents/MacOS/MPSParser
0x16b00000 - 0x16b30fcc +com.adobe.illustrator.plugins.MPSExport MPSExport version 14.0.0 (14.0.0) <DD69AB2F-78AB-4225-9DCE-2141648F6E1E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSExport.aip/Contents/MacOS/MPSExport
0x16b40000 - 0x16b5eff4 +com.adobe.illustrator.plugins.Scribble Scribble version 14.0.0 (14.0.0) <66F69AF3-2A26-4B2A-88E8-64568F71EA80> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Scribble.aip/Contents/MacOS/Scribble
0x16b65000 - 0x16b71ff3 +com.adobe.illustrator.plugins.Pathfinder Pathfinder Plugin version 14.0.0 (14.0.0) <7288F843-177B-43CE-9876-AB66A84A2F69> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Pathfinder.aip/Contents/MacOS/Pathfinder
0x16b75000 - 0x16b8afc4 +com.adobe.illustrator.plugins.WelcomeScreen WelcomeScreenn version 14.0.0 (14.0.0) <780173AB-6EAA-4EF6-9D79-99CE78F0BF06> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/WelcomeScreen.aip/Content s/MacOS/WelcomeScreen
0x16b90000 - 0x16ba3fd7 +com.adobe.illustrator.plugins.TransparencyPalette Transparency Palette version 14.0.0 (14.0.0) <2FC5A6F7-E157-4BE3-9490-657B1198825D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Transparency Panel.aip/Contents/MacOS/TransparencyPalette
0x16ba7000 - 0x16bb8ff6 +com.adobe.illustrator.plugins.SeparationPreview Separation Preview version 14.0.0 (14.0.0) <F0B42349-86B6-489E-A1ED-62DAB50BB12F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SeparationPreview.aip/Con tents/MacOS/SeparationPreview
0x16bbf000 - 0x16bc4fff +com.adobe.illustrator.plugins.PathSuite PathConstruction Suite version 14.0.0 (14.0.0) <667209A1-821D-468E-B3F5-67ADCC0A5B59> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/PathSuite.aip/Contents/Ma cOS/PathSuite
0x16bc8000 - 0x16beefdf +com.adobe.illustrator.plugins.LiveBlends Live Blends version 14.0.0 (14.0.0) <5949CA4F-0265-4001-827A-FDF67CE6E1C4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/LiveBlends.aip/Contents/M acOS/LiveBlends
0x16bf3000 - 0x16c21fcf +com.adobe.illustrator.plugins.Layers Layers Palette version 14.0.0 (14.0.0) <F13985B8-7110-4AC4-A93B-30A650274B81> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Layers Panel.aip/Contents/MacOS/Layers
0x16c29000 - 0x16c3ffef +com.adobe.illustrator.plugins.KBSCPlugin Keyboard Shortcuts version 14.0.0 (14.0.0) <8BA6912E-AC74-4FCE-97FF-02BF2F81958D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Keyboard Shortcuts.aip/Contents/MacOS/KBSCPlugin
0x16c46000 - 0x16c4cfeb +com.adobe.illustrator.plugins.FileClipboardPref FileClipboardPref version 14.0.0 (14.0.0) <A968F7DC-F8B2-46A3-8C78-1D129B37588E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FileClipboardPref.aip/Con tents/MacOS/FileClipboardPref
0x16c50000 - 0x16cacfd2 +com.adobe.illustrator.plugins.ArtStyle Art Style version 14.0.0 (14.0.0) <DAA8C2E9-65A7-40ED-B8D5-FF78F297EDA6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ArtStyle.aip/Contents/Mac OS/ArtStyle
0x16cb8000 - 0x16cc7ff3 +com.adobe.illustrator.plugins.AppBarControlsPlugin NewPlugin version 14.0.0 (14.0.0) <C50066DB-5E97-4C95-AECB-BD0A1BBD2769> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AppBarControlsPlugin.aip/ Contents/MacOS/AppBarControlsPlugin
0x16ccd000 - 0x16cfdffb +com.adobe.illustrator.plugins.AltGlyphPal AdobeAltGlyphPalette version 14.0.0 (14.0.0) <FC1467B2-2A62-408E-A38D-A1F8EC209A52> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AltGlyphPal.aip/Contents/ MacOS/AltGlyphPal
0x16d0e000 - 0x16d1fff6 +com.adobe.illustrator.plugins.Align AdobeAlignObjects version 14.0.0 (14.0.0) <1E8046C8-EAE8-445B-83F3-B2AF0F4D3452> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Align.aip/Contents/MacOS/ Align
0x16d24000 - 0x16d5bfff +com.adobe.illustrator.plugins.ActionPalette Action Palette version 14.0.0 (14.0.0) <49FF537C-26F4-450A-B7DE-59859F5A6DC0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Action Panel.aip/Contents/MacOS/ActionPalette
0x16d65000 - 0x16dfafc1 +com.adobe.illustrator.plugins.PDF Format PDF Format version 14.0.0 (14.0.0) <C88425A7-C3DA-493B-AC3E-48AB988A3CD4> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PDF Format.aip/Contents/MacOS/PDF Format
0x16e18000 - 0x16e67ff3 +FilterPort ??? (???) <7CF9F9BD-8C11-4F4C-A56F-D02923DA26C4> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/FilterPort.framework/Versions/A/F ilterPort
0x16f06000 - 0x16f49fef +ADMEveParserCarbon ??? (???) <E2B97059-2ECE-46E3-B0FA-E99EA7035CEC> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ADMEveParserCarbon.bundle/Contents/ MacOS/ADMEveParserCarbon
0x16f63000 - 0x16f6bfeb +com.adobe.illustrator.plugins.TextWrapDlg TextWrapDlg version 14.0.0 (14.0.0) <98A0EA55-C4D8-4204-9573-61592D2660A1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/TextWrapDlg.aip/Contents/MacOS/TextWrapDlg
0x16f6f000 - 0x16f7cfff +com.adobe.illustrator.plugins.Advanced Select Advanced Select version 14.0.0 (14.0.0) <C0673233-D6ED-4333-B8DC-1EDB6B9436B0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Advanced Select.aip/Contents/MacOS/Advanced Select
0x16f91000 - 0x16f95fff +com.adobe.illustrator.plugins.TypeCase Change Case version 14.0.0 (14.0.0) <7DF88FF2-4C03-499F-A390-0C4D9C17B27D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Text Filters.localized/TypeCase.aip/Contents/MacOS/TypeCase
0x16fa9000 - 0x16fb3ff7 com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x16fef000 - 0x16ffafdb +com.adobe.illustrator.plugins.TransformPalette Transform Palette version 14.0.0 (14.0.0) <18E00D0B-F2EB-4046-B764-7953DFBFD55E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Transform Panel.aip/Contents/MacOS/TransformPalette
0x17200000 - 0x17231fef +com.adobe.illustrator.plugins.VariablesPalette Variables Palette version 14.0.0 (14.0.0) <4E4DB42A-52B9-4A3E-AE56-4044DDF2B0C5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Variables Panel.aip/Contents/MacOS/VariablesPalette
0x17463000 - 0x174befe7 +com.adobe.illustrator.plugins.PDF Suite PDF Suite version 14.0.0 (14.0.0) <586E2428-342D-4C78-89F0-56A0FD10246A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/MacOS/PDF Suite
0x176ce000 - 0x176f5fd7 +com.adobe.illustrator.plugins.LinkPalette Links Palette version 14.0.0 (14.0.0) <0CAE26A1-C07B-422B-831E-679A59CB9EC0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Links Panel.aip/Contents/MacOS/LinkPalette
0x17a40000 - 0x17a71fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/registration.framework/Versions/A /registration
0x17aaa000 - 0x17b06ff2 +AdobeUpdater ??? (???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeUpdater.framework/Versions/A /AdobeUpdater
0x17b45000 - 0x17b78fc4 +com.adobe.illustrator.plugins.CropAreaTool CropAreaTool version 14.0.0 (14.0.0) <ACC7FD5D-26E1-463B-9688-2EE97ECCE728> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Crop Area Tool.aip/Contents/MacOS/CropAreaTool
0x18268000 - 0x1890afef +com.macromedia.Flash Player.authplaylib 10.0.2.31 (1.0.1d333) <E0851D48-16C9-4BDC-B3A7-7BAC9E7638F5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwl.framework/Resources/Auth PlayLib.bundle/Contents/MacOS/AuthPlayLib
0x1a500000 - 0x1a600fcf +com.adobe.versioncue ??? (4.0.0.344) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.0/VersionCue.framework/VersionCue
0x1a745000 - 0x1a770fc7 +com.adobe.illustrator.plugins.FlatteningPreview Flattening Preview version 14.0.0 (14.0.0) <743A204F-DFC7-4D1B-8370-08E7BD4556E2> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FlatteningPreview.aip/Con tents/MacOS/FlatteningPreview
0x1a780000 - 0x1a7d3fcc +com.adobe.illustrator.plugins.Deform Envelope and Warp version 14.0.0 (14.0.0) <907BD2FF-7D35-4774-8D10-2C5D8AD8BE56> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Envelope and Warp.aip/Contents/MacOS/Deform
0x1b000000 - 0x1b482fe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtlib.framework/Versions/A/Adobe LM_libFNP.dylib
0x1ca5e000 - 0x1cb3afe6 +com.adobe.illustrator.plugins.PlanetX Live Paint version 14.0.0 (14.0.0) <2A336A35-9CF2-41DF-852A-97C0CC9BB42F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Live Paint.aip/Contents/MacOS/PlanetX
0x1d3b0000 - 0x1d485fd8 +com.adobe.illustrator.plugins.SWFExport FlashFileFormat version 14.0.0 (14.0.0) <84ABF2FA-488F-4BED-9FD6-C0BD16364A80> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/SWFExport.aip/Contents/MacOS/SWFExport
0x1d4a7000 - 0x1d587ff7 +com.adobe.illustrator.plugins.SVG Format SVG Format version 14.0.0 (14.0.0) <3E3CB7B9-3AEA-459D-86F2-3022F43437A4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/MacOS/SVG Format
0x1d7eb000 - 0x1d874ff4 +com.adobe.illustrator.plugins.TracingSuite TracingSuite version 14.0.0 (14.0.0) <A48CF41E-B678-40D8-9FC2-69289C07B309> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/TracingSuite.aip/Contents /MacOS/TracingSuite
0x20000000 - 0x20098fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/Ad obeJP2K
0x5a100000 - 0x5a142ff7 com.apple.print.framework.Print.Private 6.4 (305.4) <97FD461E-ACFC-6F2B-9E48-5A22D1537422> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/ Current/Plugins/PrintCocoaUI.bundle/Contents/MacOS/PrintCocoaUI
0x5a156000 - 0x5a188fe7 com.apple.print.PrintingCocoaPDEs 6.4 (305.4) <CFF55F65-133F-A1DD-67A1-7D08C53FDFBF> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/ A/Plugins/PrintingCocoaPDEs.bundle/Contents/MacOS/PrintingCocoaPDEs
0x5a197000 - 0x5a39efeb com.apple.AddressBook.framework 5.0.4 (883) <E26855A0-8CEF-8C81-F963-A2BF9E47F5C8> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBo ok
0x5a471000 - 0x5a4a9ff7 com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x5a4b4000 - 0x5a52bff3 com.apple.backup.framework 1.2.2 (1.2.2) <D65F2FCA-15EB-C200-A08F-7DC4089DA6A2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x5a544000 - 0x5a584ff3 com.apple.securityinterface 4.0.1 (40418) <FED0C1B5-469E-ADFF-308E-C10B6A68AE45> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
0x5a5a5000 - 0x5a5dffe7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <C62A7753-99A2-6782-92E7-6628A6190A90> /usr/lib/libssl.0.9.8.dylib
0x5a87e000 - 0x5a8a8ff7 com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x5a8c1000 - 0x5a8f7fff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x64b00000 - 0x64b07ff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
0xb0000000 - 0xb0006ff8 com.apple.carbonframeworktemplate 1.3 (1.3.11) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ahclient.framework/Versions/A/ahc lient
0xb0b35000 - 0xb0b9afe3 +MMXCore ??? (???) <F9B1B4ED-E3A5-4629-B79D-6077319ED4DB> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/mmxcore.plugin/Contents/MacOS/MMXCore
0xba900000 - 0xba916ff7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <A6FD4184-1017-59F6-990E-785BDF6202BE> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7 libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <59936EB5-5FA4-EEEB-9858-E9BF50AB1776> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xfa100000 - 0xfa192fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: MacPro1,1, BootROM MP11.005C.B08, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 12 GB, SMC 1.7f10
Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
Memory Module: global_name
Network Service: Ethernet 1, Ethernet, en0
PCI Card: ATY,RadeonX1900, sppci_displaycontroller, Slot-1
Serial ATA Device: ST3500630AS P, 465.76 GB
Parallel ATA Device: ATAPI iHAP322 8
USB Device: U3 Cruzer Micro, 0x0781 (SanDisk Corporation), 0x5406, 0xfd200000 / 2
USB Device: Apple Optical USB Mouse, 0x05ac (Apple Inc.), 0x0306, 0x1d100000 / 2
USB Device: Generic USB K/B Hub, 0x05c7 (Qtronix Corp), 0x7002, 0x3d100000 / 2
USB Device: Generic USB K/B Hub, 0x05c7 (Qtronix Corp), 0x7001, 0x3d130000 / 3
FireWire Device: built-in_hub, Up to 800 Mb/sec
FireWire Device: d2 quadra (button), LaCie, Up to 800 Mb/sec
The Wasatch RIP processes .eps, .tiff; .ai; pdf; etc. files. I see no need to send it a Postscript code file. Why not Distill your original file into PDF and send that to the RIP? Or just do what most people on this forum do, save-as-pdf? I worked with Wasatch 5 to RIP files to a non-Postscript printer. I sent it .eps and .pdf files without a hitch. Please explain why it is you see a need to send Postscript to the RIP? How many layers? What color space are you using? When you say "print to a postscript"; what do you mean? Are you using the Print dialog? Print > Save PDF as Postscript?
We print RGB files to a rare photo processor called a LightJet. (I am not certain what the brand is at the moment, but they do not make these anymore.) The files get imaged (printed, or more so, "developed") onto translucent film to be backlit prints for lighted signs. Due to the photographic nature of the process, we bring in .eps files, from this particular client, pre-press (lay them out & nest them) in Illustrator, then go into the print dialoge box & save as a .ps file. The wasatch RIP software brings in the PS file, rips it & then converts the file to a .tif. This process allows for proper resolution/sizing/scaling/photo image quality, as our files sizes are 50" x 97" at maxium size. We nest the files together because the overall print will get stuck to acrylic or polycarbonate (plexiglass or lexan) & then gets lasered out on an industrial laser.
There are in upwards of 100 layers in these files, if not more. (Don't really have time to "count" them
When I worked for a newspaper office, we did the distiller thing. ..saved as a PDF, then Distilled the file, then dropped it into the rip. That process was on a MUCH smaller scale than what we deal with here. That process doesn't work well, when dealing with large signage files.
North America
Asia Pacific
