Publish an audio-only stream (HLS)
Apr 5, 2012 5:51 AM
Tags: #application #live #hls #ios #apple #fmle #http #stream #4.5.1 #requirements #audio-only
the documentation says this:
"To serve streams over a cellular network, one of the streams must be audio-only. For more information, see HTTP Live Streaming Overview.
To publish an audio-only stream, enter the following in the Flash Media Encoder Stream field:
livestream%i?adbe-live-event=liveevent&adbe-audio-stream-name=livestream1_audio_only&adbe-audio-stream-src=livestream1
If the encoder specifies individual query strings for each stream, use individual stream names instead of the variable %i:
livestream1?adbe-live-event=liveevent&adbe-audio-stream-name=livestream1_audio_only
livestream2?adbe-live-event=liveevent&adbe-audio-stream-name=livestream2_audio_only
To generate a set-level variant playlist when using an audio-only stream, specify the audio codec of the audio-only stream. Specify the audio and the video codec of the streams that contain audio and video. For more information about using the Set-level F4M/M3U8 File Generator, see Publish and play live multi-bitrate streams over HTTP.
Does this mean that using one FMLE encoder (with the installed AAC plugin) i can stream BOTH audio+video AND audio only stream via HLS to iOS clients?
If yes, how to connect to a+v stream and how to connect audio only stream in iOS  ? (To be more precise - i would need two m3u8 files, how do i create them in the provided generator)
What about the need to provide multiple bitrates (for the audio), surely 64 isn't enough - multiple encoder machines or multiple encoder instances?
    Apr 5, 2012 6:16 AM   in reply to nnmk
    yes
    In this case, ios can play a+v stream using m3u8 url
    http://server/hls-live/livepkgr/_definst/liveevent/livestream1.m3u8
    and audio-only stream using m3u8 url
    http://server/hls-live/livepkgr/_definst_/liveevent/livestream1_audio_ only.m3u8
    Using the generator you can create a variant playlist where you can specify multiple bitrate a+v streams m3u8 url (that you already know) and audio only stream m3u8 url. This tool is just a serialiser of all the information that you provide to it. It doesn't generate individual streams m3u8 urls on it's own. This variant playlist can be hosted somewhere. When player request this variant playlist, it identifes all the bitrate and corresponding m3u8 urls. Player will then play the m3u8 url that hasbitrate just less than to its input bandwidth.
    Probably I couldn't get your question clearly. Let me know if it helps.
    Apr 5, 2012 6:49 AM   in reply to nnmk
    You are right. You don't need to provide multiple bitrate audio in the variant playlist. So while specifying on FMLE
    set adbe-audio-stream-src to such a  a+v stream that that audio bitrate of 64 kbps.
    This will create 4 streams for you on FMS
    livestream1, livestream2, livestream3, livestream1_audio_only
    On encoders other than FMLE, where it is not supported to publish multiple streams with a single publish option, you may publish
    1. livestream1?adbe-live-event=liveevent&adbe-audio-stream-name=livestre am1_audio_only
    2. livestream2?adbe-live-event=liveevent
    3. livestream3?adbe-live-event=liveevent
    This will create 4 streams for you on the FMS
    Yes, there is no point publishing audio only live stream corresponding to each a+v stream. Apple spec mandates only one audio only stream of 64kbps in variant playlist
    Apr 6, 2012 5:38 AM   in reply to nnmk
    Hi nnmk,
    Though I am no expert in FMLE, but just try
    livestream%i?adbe-live-event=liveevent&adbe-audio-stream-name=livestream%i_audio_only&adbe-audio-stream-src=livestream%i
    I assume, FMLE will replace all %i to numbers (not just %i in actual stream name)
