Making a PDF Form secure for emailing
Apr 5, 2012 7:35 AM
Tags: #email #forms #xml #livecycle #form #submit #email_submit_button_pdf #livecycle_es2 #adobe_livecycle #adobe_livecycle_form #livecycle_designer #livecycle_form
I have created an enrollment form with LiveCyle.  The employer will send the application to a new employee for them to fill out and they would like it emailed back to them.  I tried the submit button but that doesn't work because while the information they input is received in a .xml file the electronic signature does not transfer which is required.  Can I set it up encrypted so that only the information that is input is encrypted?  I am VERY new to creating forms and using LiveCycle.  Thank you!
    Apr 5, 2012 7:52 AM   in reply to heastlund
    What Designer version do you have?
    You can sign, and / or encrypt the data with the email submit button in LC Designer 10.x
    However, it will encrypt the entire dataset, and not just the subset of the data.
    The other option is to send the PDF file, which will retain the digitial signature if that is required. If you chose to submit the PDF, however, the encrypt option will be greyed out, but you can still digitally sign the dataset, or sign the entire submission.
    Hope that helps.
    KJ
    Apr 5, 2012 8:41 AM   in reply to heastlund
    The way I think you are trying it in Reader won't give you want you need. If you want to hide the data in the XML email submission (from email submit button), you need the newer capabilities in Designer 10.x to encrypt the submission. The XML contents will look like this after it is encrypted:
    <?xml version="1.0" encoding="UTF-8"?>
    <xfa:data xmlns:xfa="http://www.xfa.org/schema/xfa-data/1.0/"
    ><EncryptedData xmlns="http://www.w3.org/2001/04/xmlenc#" Id="encrypteddata_2" Type="http://www.w3.org/2001/04/xmlenc#Element"
    ><EncryptionMethod Algorithm="http://www.w3.org/2001/04/xmlenc#aes256-cbc"
    /><KeyInfo xmlns="http://www.w3.org/2000/09/xmldsig#"
    ><EncryptedKey xmlns="http://www.w3.org/2001/04/xmlenc#"
    ><EncryptionMethod Algorithm="http://www.w3.org/2001/04/xmlenc#rsa-1_5"
    ><X509Data
    ><X509Certificate
    >MIICRTCCAa6gAwIBAgIKNvzDsAiaeyPYFDANBgkqhkiG9w0BAQUFADBTMREwDwYDVQQDE whKb2hu
    IERvZTEJMAcGA1UEChMAMQkwBwYDVQQLEwAxGzAZBgkqhkiG9w0BCQEWDGpkb2VAYWJjLm NvbTEL
    MAkGA1UEBhMCVVMwHhcNMTExMTAzMjA1MjAwWhcNMTYxMTAzMjA1MjAwWjBTMREwDwYDVQ QDEwhK
    b2huIERvZTEJMAcGA1UEChMAMQkwBwYDVQQLEwAxGzAZBgkqhkiG9w0BCQEWDGpkb2VAYW JjLmNv
    bTELMAkGA1UEBhMCVVMwgZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJAoGBAL12YAntp+1Zzs Npew5H
    +s5fwLjK3TdiFfMrJuV1jEG2xlvJPOvKujSeR+4iHlBTQbYxkZ5nvhkwQi9KDgeriuMjg/ TclkJP
    CD0h//4fnP4tQqTUAZ92r6nMRqFxviEhysETMQl01SGDUlmSjhvWJctPU+krq+wwuwVbPJ gU8Iu5
    AgMBAAGjIDAeMA8GCSqGSIb3LwEBCgQCBQAwCwYDVR0PBAQDAgSQMA0GCSqGSIb3DQEBBQ UAA4GB
    AK+TIhyZZtYtxrVz5lq/zl8mczRnUCsJcapXJhY/oJnN2izALPAYnA4eBr7LBbl1Hf12op +LJuoU
    j5FHhB+eQzKlhqkC/alFwmGdxCBYUfpZKWGBUuuW+00mTCStsmTIaSi/XS6K+Y5+0fqAJ4 8y56lb
    o/kjbxSjzHWszfeOzafF</X509Certificate
    ></X509Data
    ></KeyInfo
    ><CipherData
    ><CipherValue
    >ADk2Kxut+M84Pi4B1ZC9znKFCz2rAfHYZNZ76fWK/eRE5QMC0NhCnQ5gFfrOLU9Wl/5FO TZMwQab
    F1PjdKaVys0TjOR51HH1A6D/ZUf7baBQ1XnKRW5kQR8xePwwDaRoyBopF8+XeWA6d8yRXv yZdLJa
    Hju2/gUR/M2HArKCtso=</CipherValue
    ></CipherData
    ></EncryptedKey
    ></KeyInfo
    ><CipherData
    ><CipherValue
    >uiKSewcq2Of8cIk7hRnjFmOpTo+XxN6AZM5PyT+k2d1mUuBlbJWxCk37EFiwVHRH5n4oO QkuFFhv
    +jopOPQLbthkdhiDzWHmAJhstaPcbvA=</CipherValue
    ></CipherData
    ><EncryptionProperties
    ><EncryptionProperty xfa:processingRule="replacementContent"
    ><form1
    /></EncryptionProperty
    ></EncryptionProperties
    ></EncryptedData
    ><signatures
    ><Signature xmlns="http://www.w3.org/2000/09/xmldsig#" Id="datasignature_2"
    ><SignedInfo
    ><CanonicalizationMethod Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#WithComments"
    /><SignatureMethod Algorithm="http://www.w3.org/2000/09/xmldsig#rsa-sha1"
    /><Reference URI="#idbfea09cc-7f34-11e1-9c29-002710682eb5" Type="http://www.w3.org/2000/09/xmldsig#SignatureProperties"
    ><Transforms
    ><Transform Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#WithComments"
    /></Transforms
    ><DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1"
    /><DigestValue
    >O9E5XR6E+tkicSPa6HTZgkE9qhE=</DigestValue
    ></Reference
    ><Reference URI=""
    ><Transforms
    ><Transform Algorithm="http://www.w3.org/2002/06/xmldsig-filter2"
    ><XPath xmlns="http://www.w3.org/2002/06/xmldsig-filter2" xmlns:dsig="http://www.w3.org/2000/09/xmldsig#" Filter="intersect"
    >here()/ancestor::dsig:Signature[1]/../..//. |
    here()/ancestor::dsig:Signature[1]/../..//@* |
    here()/ancestor::dsig:Signature[1]/../..//namespace::*</XPath
    ></Transform
    ><Transform Algorithm="http://www.w3.org/2000/09/xmldsig#enveloped-signature"
    /><Transform Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#WithComments"
    /></Transforms
    /><DigestValue
    >v9suUKmCN2M3JeTTr2y5/L6ZY64=</DigestValue
    ></Reference
    ></SignedInfo
    ><SignatureValue
    >DYCW4mlxVOr+EmleCo56aohSGw93gtk2Wc5Rb7zlB8ukTSC9lozQM1rGLv4GykpQ+Ln+X hKCzVqv
    Z7jcISv2l+1rWWpBSyhve+szoWSoY90SEtPUwnJMwxeOy6fOyGx5MWCqVj6D308Pcu2dw7 r3UMqc
    i6rSWUezvsPjfCBrcW8=</SignatureValue
    ><KeyInfo
    ><X509Data
    ><X509Certificate
    ></X509Data
    ></KeyInfo
    ><Object
    ><SignatureProperties Id="idbfea09cc-7f34-11e1-9c29-002710682eb5"
    ><SignatureProperty Target="datasignature_2"
    ><PROP_Sig xmlns="http://ns.adobe.com/pdf/2006" type="cabinet"
    ><M type="text"
    >D:20120405113353-04'00'</M
    ><Name type="text"
    >John</Name
    ></PROP_Sig
    ></SignatureProperty
    ></SignatureProperties
    ></Object
    ></Signature
    ></signatures
    ></xfa:data
    In the Designer version you have (8.2), you only have the capability to sign the data or the entire form, which will not hide its values in the XML file that gets sent.
