ilovetoread247
Help With Button Coding
Apr 5, 2012 8:13 AM
Tags: #button #as2 #actionscript #2.0
I make dress up games in ActionScript 2, and am having a problem.
I want to make a button find all movieclip items with, say, "shirt" in their Instance Name, and move them to frame 2.  I know how to do this with one item, (on(release){
_root.shirt1.gotoAndStop(1);
and on previous games, I merely copied and pasted that several dozen times for every item.  However, on this game, I am trying to cut down on code, and learned how to use
for(var i:String in _root){
     if(i.indexOf("_drag") > -1){
          _root[i].onPress = function(){
(put in the code)
(put in the closing }s)
on the stage to make items drag and snap into place.  I have learned that this code cannot be used on buttons, which need static commands, I think?  I'm still very much a novice.
Any help would be appreciated!
  • kglad
    Jul 21, 2002
    Apr 5, 2012 8:47 AM   in reply to ilovetoread247
    what is it that, you think, doesn't work with buttons?
  • kglad
    Jul 21, 2002
    Apr 5, 2012 5:33 PM   in reply to ilovetoread247
    you should remove all code from objects.  so, whatever button has that code attached should be given an instance name (eg, btn) so you can use:
    btn.onRelease = function(){
              if(i.indexOf("shirt") > -1){
                   _root[i].gotoAndStop(2);
