Buttons panel gone and nowhere to be found
Apr 5, 2012 9:44 AM
Tags: #cs4 #buttons #indesign #troubleshooting #interactivity
Hi all,
For some reason my Indesign CS4 does not show the buttons panel anymore. Window > Interactive only shows Bookmarks, Hyperlinks and Page Transitions as options. I've tried all workspaces (even interactivity) and the option to show the buttons panel does not appear. Futhermore, there's also no option to create a new button. Object > Interactive is gone as well.
What is going on here?
    Apr 5, 2012 10:18 AM   in reply to MacBryce
    You can check to see if the visibility was turned off for these items. Edit > Menus (at the bottom) > Menu Customization
    Apr 5, 2012 10:38 AM   in reply to MacBryce
    Have you thrashed/replaced your prefs? (Reminder: check the thread/link at the top of discussion page for detailed instructions for replacing prefs if needed)
    Apr 5, 2012 12:43 PM   in reply to MacBryce
    If you contextually select a frame, is the interactive options available in this popup menu?
    Apr 5, 2012 1:17 PM   in reply to MacBryce
    At first I thought the contextual menu shows everything regardless of your workspace. But that is not the case, the contextual menus works in conjunction with the workspace. With that said, have you  tried the Advanced Workspace, which shows all menu items? If so and still no go, then my thoughts would be re-install, but I would wait and see if anyone else has thoughts.
    Apr 5, 2012 1:27 PM   in reply to Jeffrey_Smith
    the defualt plugin to work with button panel is ButtonUI.apln on windows ,The OS is not mentioned on the thread ,
    You can check for that plugin in the adobe Indesign folder in program files folder (windows) or application folder(mac) ,
    If not found , just re-install , (no need to uninstall)
