Transparent PNGs Have Dark Outline
Apr 5, 2012 11:44 AM
Whenever I use a PNGs with transparency in my documents, they show up with gross outlines around the edges.
It seems the places where the pixels are not 100% transparent do not get rendered correctly.
I tried switching "Transparency Blend Space", and it doesn't help; though the CYMK setting makes this problem more obvious.
Has anyone encounted this before?
Here's a link to one of my original PNGs that doesn't work properly in InDesign: http://zoffix.com/new/del/042-T2.png
Here is what the exported PDF with a problem looks like:
    Apr 5, 2012 12:10 PM   in reply to Zoffix222
    Resizing and resampling is causing this problem with PNG.
    You can:
    1. Save as .psd
    2. Use a script that would open image in Photoshop and resample to 100% and replace image in ID
    Apr 5, 2012 1:02 PM   in reply to Zoffix222
    How are you placing the image into ID? What PDF export profile are you using. Here is a closup of a PDF using your image. A light yellow rectangle is behind the image. Looks the same in ID.
    Apr 5, 2012 1:23 PM   in reply to MW Design
    Are you sure the frame is not filled with a yellow tint? I download the PNG, placed in ID, exported to PDF with no transparency issue (except outline).
  • Rob Day
    Oct 16, 2007
    Apr 5, 2012 4:25 PM   in reply to MW Design
    I think Jeffery is right—PNG can't handle downsampling as well as psd (try exporting the png as a interactive PDF). Converting to PSD solves both the ID preview and low res PDF export:
    PNG
    PSD
