OLE - Object Linked Ed'ing - not updating between FM & Ph'shop
Apr 5, 2012 2:57 PM
Tags: #import #images #framemaker_9 #ole #windows_7_64bit
When I save changes into a graphic file in Photoshop, one that's already been imported by ref. into my FM file,
I'm not seeing the update in FM. In fact, I'm not seeing the change in Windows Explorer, either. From within
FM and Photoshop, when I do a "save as" to check the date-time stamp on the graphic file, I fall in to a time
loop.
Every time I save or change a file name, the Windows Explorer date-time stamp shows that the change was made
at 11:37 AM, this morning. I've re-booted several times and renamed a couple of different files, after re-booting, but
every time the new file shows up as having been saved at that same, identical moment -- 11:37 am.
When I re-open the same file in Win Paint, and do a "save as" the correct time is displayed in the Explorer
window.
...OK, that may not turn out to be a problem that points back to FM, or Adobe -- the files are saved on the
company network server, not my own hard drive, for one thing -- but I would really appreciate some help with
sorting this out. I work at a small company and I'm the only one using any kind of Adobe software, aside
from Acrobat. Our IT guy is pretty good but hasn't had to spend much time sorting out conflicts between
Adobe and Windows. (Assuming that could be the issue here, since it looks like the Windows side is still
updating correctly, but Adobe is not.)
I'm on a 64-bit Win 7 DELL with a reasonably fast processor and 12 GB of RAM.
My apps. are Photoshop CS4 from Tech Comm Suite 2 (Photoshop 11.0..2) and FM 9.0 p255.
    Apr 12, 2012 7:14 AM   in reply to Misha Ko
    It kind of sounded like a network issue...
    Apr 12, 2012 12:31 PM   in reply to Misha Ko
    Don't hold your breath for that one - that's why Adobe charges for support.
    Apr 13, 2012 5:11 AM   in reply to Misha Ko
    I think you'd be better off harnessing the power of Google for little things like that ;>)
