I fear I already know the answer to this question, and since I was unable to find a current definite answer I figured I'd ask...
I was forced to use Word 2011 today, and the document had a table. I noticed I could adjust columns individually(it's not pretty, but it works). Is it true that Word can do something Indesign can't? Say it ain't so!
Can you adjust table columns individually without affecting the whole table? I know you can hold shift, while adjusting but that sill affects the entire column. I usually merge, split, split, merge, ect... rinse, repeat.
I'm on a Mac running CS5. Has this been addressed in 5.5?
Sorry, I actually meant resizing cells individually. Holding shift will move the whole column of cells at the same time.
The 'me' column is split in half. But when the column divider is shifted it moves everything else above and below. I'm pretty sure it can't be done, but I guess I was just being hopeful.
Well... hmm. Now that you mention it maybe I don't need to use tables. I'll have to see how that flies with the boss though. I usually only go the table route when I need to cram a lot of information on a single sheet of paper. It just seems to look neater in the end.
Michael Murphys 'form lines aside' technique using tabs and underlines is what I typically use when I'm making other forms and signature lines. It's pretty fantastic.
Of course I'm always open to other suggestions and techniques if you're referring to a different method.
Gridify is the indesign obsure feature , which is very useful to multiple text box and give the effect like table when the gutter value is low , and as they are the text box its easy to mange them.
http://indesignsecrets.com/forum/general-indesign-topics/gridify-gap
will be helpful for a start however ther video as well online
North America
Asia Pacific
