antonpierhagen
Automatic authentication with a webservice in SAP
Apr 5, 2012 11:12 PM
hi all
I have a flex application which uses SOAP webservices from SAP to retrieve data.
Everytime one of the SOAP webservices is called the user have to enter a name plus password
I would like to make this automaticly. So that the user haven't got to fill this in. But Flex already filled it automaticcally.
But how do this work? How can you set this in Flex?
kind regards
Anton Pierhagen
    Apr 6, 2012 12:14 AM   in reply to antonpierhagen
    user has to enter only once their credentials.
    Apr 6, 2012 5:27 AM   in reply to antonpierhagen
    hi,
         I hope you embed you flex applicatios in .do file. when you try to load .do file SAP asks you login. it is not depends only on flex. if you load anything from SAP first it aks you login. For example if you load PDF file from SAP it asks you login. once you give your login credential you don't need to give login for the entire browser session.
    Apr 6, 2012 6:45 AM   in reply to antonpierhagen
    regarding flex you can use setCredetials method in webservice. But it is not related to flex app. SAP asks login before loading flex app i.e when it loads html file that containing flex. May be you can try it in SAP settings. I am not sure about that.
    To be frank, i never try this approach. Need some security around our app. So it is better to leave as it is.
