trouble Flash 11
Apr 6, 2012 1:44 AM
Tags: #adobe #flash #internet #windows_7 #explorer #player #11 #actionlist_not_found #64_bit
  Latest reply: Darkmoon2010, Apr 14, 2012 11:26 PM
    Apr 12, 2012 3:31 AM   in reply to Pat Willener
    Did all those steps (I even gave everyone full 0_0) still no luck. Removed and updated java and reader without issue.
    === Verbose logging started: 4/12/2012  05:25:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
    MSI (c) (F4:A0) [05:25:33:647]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (F4:64) [05:25:33:678]: Resetting cached policy values
    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'Debug' is 0
    MSI (c) (F4:64) [05:25:33:678]: ******* RunEngine:
               ******* Product: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
               ******* Action:
               ******* CommandLine: **********
    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
    MSI (c) (F4:64) [05:25:33:991]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (F4:64) [05:25:34:053]: Cloaking enabled.
    MSI (c) (F4:64) [05:25:34:053]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (F4:64) [05:25:34:069]: End dialog not enabled
    MSI (c) (F4:64) [05:25:34:069]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (c) (F4:64) [05:25:34:069]: Package we're running from ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (F4:64) [05:25:34:069]: MSCOREE not loaded loading copy from system32
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'TransformsAtSource' is 0
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisablePatch' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (F4:64) [05:25:34:084]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (F4:64) [05:25:34:084]: Transforms are not secure.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
    MSI (c) (F4:64) [05:25:34:084]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=4596
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (c) (F4:64) [05:25:34:084]: Product Code passed to Engine.Initialize:           ''
    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (F4:64) [05:25:34:084]: Product not registered: beginning first-time install
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (c) (F4:64) [05:25:34:084]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'SearchOrder' is 'nmu'
    MSI (c) (F4:64) [05:25:34:084]: Adding new sources is allowed.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:084]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (F4:64) [05:25:34:084]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableMsi' is 0
    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (F4:64) [05:25:34:084]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (F4:64) [05:25:34:084]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (c) (F4:64) [05:25:34:084]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:084]: TRANSFORMS property is now:
    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (c) (F4:A0) [05:25:34:100]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
    === Logging started: 4/12/2012  05:25:34 ===
    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 2205 2:  3: PatchPackage
    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'DisableRollback' is 0
    MSI (c) (F4:64) [05:25:34:100]: User policy value 'DisableRollback' is 0
    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (F4:64) [05:25:34:116]: Doing action: INSTALL
    Action 05:25:34: INSTALL.
    Action start 05:25:34: INSTALL.
    MSI (c) (F4:64) [05:25:34:116]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (F4:64) [05:25:34:116]: Running UISequence
    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (F4:64) [05:25:34:116]: Doing action: ISSetAllUsers
    Action 05:25:34: ISSetAllUsers.
    Action start 05:25:34: ISSetAllUsers.
    MSI (c) (F4:64) [05:25:34:147]: Creating MSIHANDLE (1) of type 790542 for thread 1380
    MSI (c) (F4:78) [05:25:34:147]: Invoking remote custom action. DLL: C:\Users\Ad~1\AppData\Local\Temp\MSIEDE8.tmp, Entrypoint: SetAllUsers
    MSI (c) (F4:DC) [05:25:34:147]: Cloaking enabled.
    MSI (c) (F4:DC) [05:25:34:147]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (F4:DC) [05:25:34:147]: Connected to service for CA interface.
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (2) of type 790531 for thread 2532
    InstallShield 05:25:34: Begin SetAllUsers()
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (2) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (3) of type 790541 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (4) of type 790531 for thread 2532
    InstallShield 05:25:34: Getting records from Upgrade table
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (4) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (5) of type 790540 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (6) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (7) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (7) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (8) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (8) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (6) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (9) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (10) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (10) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (11) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (11) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (9) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (12) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (13) of type 790531 for thread 2532
    InstallShield 05:25:34: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (13) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (14) of type 790531 for thread 2532
    InstallShield 05:25:34: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (14) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (12) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (15) of type 790531 for thread 2532
    InstallShield 05:25:34: End SetAllUsers()
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (15) of type 790531 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (5) of type 790540 for thread 2532
    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (3) of type 790541 for thread 2532
    MSI (c) (F4:78) [05:25:34:256]: Closing MSIHANDLE (1) of type 790542 for thread 1380
    Action ended 05:25:34: ISSetAllUsers. Return value 1.
    MSI (c) (F4:64) [05:25:34:256]: Doing action: AppSearch
    Action 05:25:34: AppSearch. Searching for installed applications
    Action start 05:25:34: AppSearch.
    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2205 2:  3: AppSearch
    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
    Action ended 05:25:34: AppSearch. Return value 0.
    MSI (c) (F4:64) [05:25:34:256]: Doing action: LaunchConditions
    Action 05:25:34: LaunchConditions. Evaluating launch conditions
    Action start 05:25:34: LaunchConditions.
    Action ended 05:25:34: LaunchConditions. Return value 1.
    MSI (c) (F4:64) [05:25:34:272]: Doing action: SetupInitialization
    Action 05:25:34: SetupInitialization.
    Action start 05:25:34: SetupInitialization.
    Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 05:25:34: SetupInitialization. Dialog created
    Action ended 05:25:34: SetupInitialization. Return value 1.
    MSI (c) (F4:64) [05:25:34:288]: Doing action: FindRelatedProducts
    Action 05:25:34: FindRelatedProducts. Searching for related applications
    Action start 05:25:34: FindRelatedProducts.
    Action ended 05:25:34: FindRelatedProducts. Return value 1.
    MSI (c) (F4:64) [05:25:34:288]: Skipping action: CCPSearch (condition is false)
    MSI (c) (F4:64) [05:25:34:288]: Skipping action: RMCCPSearch (condition is false)
    MSI (c) (F4:64) [05:25:34:288]: Doing action: ValidateProductID
    Action 05:25:34: ValidateProductID.
    Action start 05:25:34: ValidateProductID.
    Action ended 05:25:34: ValidateProductID. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostInitialize
    Action 05:25:34: CostInitialize. Computing space requirements
    Action start 05:25:34: CostInitialize.
    MSI (c) (F4:64) [05:25:34:303]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (c) (F4:64) [05:25:34:303]: Baseline: New baseline 11.2.202 from transaction.
    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorted order Native: Order 0.
    MSI (c) (F4:64) [05:25:34:303]: Baseline Data Table:
    MSI (c) (F4:64) [05:25:34:303]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (c) (F4:64) [05:25:34:303]: Baseline File Table:
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    Action ended 05:25:34: CostInitialize. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: FileCost
    Action 05:25:34: FileCost. Computing space requirements
    Action start 05:25:34: FileCost.
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Class
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Extension
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: TypeLib
    Action ended 05:25:34: FileCost. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: IsolateComponents
    Action 05:25:34: IsolateComponents.
    Action start 05:25:34: IsolateComponents.
    Action ended 05:25:34: IsolateComponents. Return value 0.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: setUserProfileNT
    Action 05:25:34: setUserProfileNT.
    Action start 05:25:34: setUserProfileNT.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
    Action ended 05:25:34: setUserProfileNT. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Skipping action: SetAllUsersProfileNT (condition is false)
    MSI (c) (F4:64) [05:25:34:303]: Doing action: setAllUsersProfile2K
    Action 05:25:34: setAllUsersProfile2K.
    Action start 05:25:34: setAllUsersProfile2K.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
    Action ended 05:25:34: setAllUsersProfile2K. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: ResolveSource
    Action 05:25:34: ResolveSource.
    Action start 05:25:34: ResolveSource.
    MSI (c) (F4:64) [05:25:34:303]: Resolving source.
    MSI (c) (F4:64) [05:25:34:303]: Resolving source to launched-from source.
    MSI (c) (F4:64) [05:25:34:303]: Setting launched-from source as last-used.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR ==> C:\Users\Admin\Desktop\
    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (c) (F4:64) [05:25:34:303]: Determining source type
    MSI (c) (F4:64) [05:25:34:303]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (c) (F4:64) [05:25:34:303]: Source path resolution complete. Dumping Directory table...
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action ended 05:25:34: ResolveSource. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostFinalize
    Action 05:25:34: CostFinalize. Computing space requirements
    Action start 05:25:34: CostFinalize.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Condition
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
    MSI (c) (F4:64) [05:25:34:303]: Target path resolution complete. Dumping Directory table...
    MSI (c) (F4:64) [05:25:34:303]: Note: target paths subject to change (via custom actions or browsing)
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 05:25:34: CostFinalize. Return value 1.
    MSI (c) (F4:64) [05:25:34:303]: Doing action: MigrateFeatureStates
    Action 05:25:34: MigrateFeatureStates. Migrating feature states from related applications
    Action start 05:25:34: MigrateFeatureStates.
    Action ended 05:25:34: MigrateFeatureStates. Return value 0.
    MSI (c) (F4:64) [05:25:34:303]: Skipping action: PatchWelcome (condition is false)
    MSI (c) (F4:64) [05:25:34:303]: Doing action: InstallWelcome
    Action 05:25:34: InstallWelcome.
    Action start 05:25:34: InstallWelcome.
    Action 05:25:34: InstallWelcome. Dialog created
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (F4:9C) [05:25:34:319]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: BindImage
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: ProgId
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: PublishComponent
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: SelfReg
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Extension
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Font
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Shortcut
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Class
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: TypeLib
    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2727 2:
    Action ended 05:25:36: InstallWelcome. Return value 1.
    MSI (c) (F4:64) [05:25:36:022]: Skipping action: SetupResume (condition is false)
    MSI (c) (F4:64) [05:25:36:022]: Skipping action: MaintenanceWelcome (condition is false)
    MSI (c) (F4:64) [05:25:36:022]: Doing action: SetupProgress
    Action 05:25:36: SetupProgress.
    Action start 05:25:36: SetupProgress.
    Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 05:25:36: SetupProgress. Dialog created
    Action ended 05:25:36: SetupProgress. Return value 1.
    MSI (c) (F4:64) [05:25:36:038]: Doing action: ExecuteAction
    Action 05:25:36: ExecuteAction.
    Action start 05:25:36: ExecuteAction.
    MSI (c) (F4:64) [05:25:36:053]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (c) (F4:64) [05:25:36:053]: Grabbed execution mutex.
    MSI (c) (F4:64) [05:25:36:053]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (F4:64) [05:25:36:053]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\" USERNAME="Viking" CLIENTPROCESSID="4596" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop"  ADDLOCAL=FlashPlayerAXInstaller
    MSI (s) (28:94) [05:25:36:069]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (s) (28:94) [05:25:36:069]: Grabbed execution mutex.
    MSI (s) (28:78) [05:25:36:069]: Resetting cached policy values
    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'Debug' is 0
    MSI (s) (28:78) [05:25:36:069]: ******* RunEngine:
               ******* Action: INSTALL
    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (28:78) [05:25:36:069]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (28:78) [05:25:36:084]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (28:78) [05:25:36:084]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
    MSI (s) (28:78) [05:25:36:084]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
    MSI (s) (28:78) [05:25:36:084]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
    MSI (s) (28:78) [05:25:46:319]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 390.
    MSI (s) (28:78) [05:25:46:319]: File will have security applied from OpCode.
    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
    MSI (s) (28:78) [05:25:46:538]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (s) (28:78) [05:25:46:538]: End dialog not enabled
    MSI (s) (28:78) [05:25:46:538]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    MSI (s) (28:78) [05:25:46:538]: Package we're running from ==> C:\Windows\Installer\1201d91.msi
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (28:78) [05:25:46:553]: MSCOREE not loaded loading copy from system32
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'TransformsSecure' is 0
    MSI (s) (28:78) [05:25:46:553]: User policy value 'TransformsAtSource' is 0
    MSI (s) (28:78) [05:25:46:553]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisablePatch' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableLUAPatching' is 0
    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (s) (28:78) [05:25:46:553]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (28:78) [05:25:46:553]: Transforms are not secure.
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
    MSI (s) (28:78) [05:25:46:553]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\ USERNAME=Viking CLIENTPROCESSID=4596 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (s) (28:78) [05:25:46:553]: Product Code passed to Engine.Initialize:           ''
    MSI (s) (28:78) [05:25:46:553]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (28:78) [05:25:46:553]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (28:78) [05:25:46:553]: Product not registered: beginning first-time install
    MSI (s) (28:78) [05:25:46:553]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
    MSI (s) (28:78) [05:25:46:553]: MSI_LUA: Credential prompt not required, user is an admin
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (s) (28:78) [05:25:46:553]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (s) (28:78) [05:25:46:553]: User policy value 'SearchOrder' is 'nmu'
    MSI (s) (28:78) [05:25:46:553]: Adding new sources is allowed.
    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (28:78) [05:25:46:569]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (28:78) [05:25:46:569]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableMsi' is 0
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:569]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:569]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (s) (28:78) [05:25:46:569]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'ffdbe6677a09a542b5e6559f7939deaf'.
    MSI (s) (28:78) [05:25:46:569]: RESTART MANAGER: Session opened.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:569]: Engine has iefSecondSequence set to true.
    MSI (s) (28:78) [05:25:46:569]: TRANSFORMS property is now:
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (s) (28:78) [05:25:46:616]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1201d91.msi'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (s) (28:78) [05:25:46:616]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: PatchPackage
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:46:616]: User policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
    MSI (s) (28:78) [05:25:46:616]: Doing action: INSTALL
    Action 05:25:46: INSTALL.
    Action start 05:25:46: INSTALL.
    MSI (s) (28:78) [05:25:46:616]: Running ExecuteSequence
    MSI (s) (28:78) [05:25:46:616]: Doing action: ISSetAllUsers
    Action 05:25:46: ISSetAllUsers.
    Action start 05:25:46: ISSetAllUsers.
    MSI (s) (28:78) [05:25:46:616]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 05:25:46: ISSetAllUsers. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Doing action: AppSearch
    Action 05:25:46: AppSearch. Searching for installed applications
    Action start 05:25:46: AppSearch.
    MSI (s) (28:78) [05:25:46:616]: Skipping AppSearch action: already done on client side
    Action ended 05:25:46: AppSearch. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Doing action: LaunchConditions
    Action 05:25:46: LaunchConditions. Evaluating launch conditions
    Action start 05:25:46: LaunchConditions.
    Action ended 05:25:46: LaunchConditions. Return value 1.
    MSI (s) (28:78) [05:25:46:616]: Doing action: FindRelatedProducts
    Action 05:25:46: FindRelatedProducts. Searching for related applications
    Action start 05:25:46: FindRelatedProducts.
    MSI (s) (28:78) [05:25:46:616]: Skipping FindRelatedProducts action: already done on client side
    Action ended 05:25:46: FindRelatedProducts. Return value 0.
    MSI (s) (28:78) [05:25:46:616]: Skipping action: CCPSearch (condition is false)
    MSI (s) (28:78) [05:25:46:616]: Skipping action: RMCCPSearch (condition is false)
    MSI (s) (28:78) [05:25:46:616]: Doing action: ValidateProductID
    Action 05:25:46: ValidateProductID.
    Action start 05:25:46: ValidateProductID.
    Action ended 05:25:46: ValidateProductID. Return value 1.
    MSI (s) (28:78) [05:25:46:616]: Doing action: CostInitialize
    Action 05:25:46: CostInitialize. Computing space requirements
    Action start 05:25:46: CostInitialize.
    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (s) (28:78) [05:25:46:616]: Baseline: New baseline 11.2.202 from transaction.
    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorted order Native: Order 0.
    MSI (s) (28:78) [05:25:46:616]: Baseline Data Table:
    MSI (s) (28:78) [05:25:46:616]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (s) (28:78) [05:25:46:616]: Baseline File Table:
    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: __MsiPatchFileList
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PatchPackage
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
    MSI (s) (28:78) [05:25:46:631]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
    Action ended 05:25:46: CostInitialize. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: FileCost
    Action 05:25:46: FileCost. Computing space requirements
    Action start 05:25:46: FileCost.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: TypeLib
    Action ended 05:25:46: FileCost. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: IsolateComponents
    Action 05:25:46: IsolateComponents.
    Action start 05:25:46: IsolateComponents.
    Action ended 05:25:46: IsolateComponents. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: CostFinalize
    Action 05:25:46: CostFinalize. Computing space requirements
    Action start 05:25:46: CostFinalize.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Condition
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (s) (28:78) [05:25:46:631]: Target path resolution complete. Dumping Directory table...
    MSI (s) (28:78) [05:25:46:631]: Note: target paths subject to change (via custom actions or browsing)
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 05:25:46: CostFinalize. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: SetARPINSTALLLOCATION
    Action 05:25:46: SetARPINSTALLLOCATION.
    Action start 05:25:46: SetARPINSTALLLOCATION.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 05:25:46: SetARPINSTALLLOCATION. Return value 1.
    MSI (s) (28:78) [05:25:46:631]: Doing action: SetODBCFolders
    Action 05:25:46: SetODBCFolders. Initializing ODBC directories
    Action start 05:25:46: SetODBCFolders.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    Action ended 05:25:46: SetODBCFolders. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: MigrateFeatureStates
    Action 05:25:46: MigrateFeatureStates. Migrating feature states from related applications
    Action start 05:25:46: MigrateFeatureStates.
    MSI (s) (28:78) [05:25:46:631]: Skipping MigrateFeatureStates action: already done on client side
    Action ended 05:25:46: MigrateFeatureStates. Return value 0.
    MSI (s) (28:78) [05:25:46:631]: Doing action: InstallValidate
    Action 05:25:46: InstallValidate. Validating install
    Action start 05:25:46: InstallValidate.
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'ffdbe6677a09a542b5e6559f7939deaf'.
    MSI (s) (28:78) [05:25:46:631]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (28:78) [05:25:46:631]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
    MSI (s) (28:78) [05:25:46:631]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (28:78) [05:25:46:631]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: BindImage
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2727 2:
    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: FilesInUse
    MSI (s) (28:78) [05:25:46:647]: Note: 1: 2727 2:
    Action ended 05:25:46: InstallValidate. Return value 1.
    MSI (s) (28:78) [05:25:46:647]: Doing action: RemoveExistingProducts
    Action 05:25:46: RemoveExistingProducts. Removing applications
    Action start 05:25:46: RemoveExistingProducts.
    Action ended 05:25:46: RemoveExistingProducts. Return value 1.
    MSI (s) (28:78) [05:25:46:663]: Doing action: InstallInitialize
    Action 05:25:46: InstallInitialize.
    Action start 05:25:46: InstallInitialize.
    MSI (s) (28:78) [05:25:46:663]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:663]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (28:78) [05:25:46:663]: BeginTransaction: Locking Server
    MSI (s) (28:78) [05:25:46:663]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
    Action ended 05:25:50: InstallInitialize. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Skipping action: CallExeUninstaller (condition is false)
    MSI (s) (28:78) [05:25:50:538]: Doing action: MakePropsAvailable
    Action 05:25:50: MakePropsAvailable.
    Action start 05:25:50: MakePropsAvailable.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 05:25:50: MakePropsAvailable. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Doing action: AllocateRegistrySpace
    Action 05:25:50: AllocateRegistrySpace. Allocating registry space
    Action start 05:25:50: AllocateRegistrySpace.
    Action ended 05:25:50: AllocateRegistrySpace. Return value 1.
    MSI (s) (28:78) [05:25:50:538]: Doing action: ProcessComponents
    Action 05:25:50: ProcessComponents. Updating component registration
    Action start 05:25:50: ProcessComponents.
    MSI (s) (28:78) [05:25:50:538]: Note: 1: 2205 2:  3: MsiPatchCertificate
    MSI (s) (28:78) [05:25:50:538]: LUA patching is disabled: missing MsiPatchCertificate table
    MSI (s) (28:78) [05:25:50:538]: Resolving source.
    MSI (s) (28:78) [05:25:50:538]: Resolving source to launched-from source.
    MSI (s) (28:78) [05:25:50:538]: Setting launched-from source as last-used.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR ==> C:\Users\Admin\Desktop\
    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (s) (28:78) [05:25:50:538]: Determining source type
    MSI (s) (28:78) [05:25:50:553]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (s) (28:78) [05:25:50:553]: Source path resolution complete. Dumping Directory table...
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action 05:25:50: GenerateScript. Generating script operations for action:
    GenerateScript: Updating component registration
    Action ended 05:25:50: ProcessComponents. Return value 1.
    MSI (s) (28:78) [05:25:50:553]: Doing action: UnpublishComponents
    Action 05:25:50: UnpublishComponents. Unpublishing Qualified Components
    Action start 05:25:50: UnpublishComponents.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnpublishComponents. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: MsiUnpublishAssemblies
    Action 05:25:50: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 05:25:50: MsiUnpublishAssemblies.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: MsiUnpublishAssemblies. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnpublishFeatures
    Action 05:25:50: UnpublishFeatures. Unpublishing product features
    Action start 05:25:50: UnpublishFeatures.
    Action ended 05:25:50: UnpublishFeatures. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: StopServices
    Action 05:25:50: StopServices. Stopping services
    Action start 05:25:50: StopServices.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: StopServices. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: DeleteServices
    Action 05:25:50: DeleteServices. Deleting services
    Action start 05:25:50: DeleteServices.
    Action ended 05:25:50: DeleteServices. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterComPlus
    Action 05:25:50: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 05:25:50: UnregisterComPlus.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: Complus
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
    Action ended 05:25:50: UnregisterComPlus. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: SelfUnregModules
    Action 05:25:50: SelfUnregModules. Unregistering modules
    Action start 05:25:50: SelfUnregModules.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
    Action ended 05:25:50: SelfUnregModules. Return value 1.
    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterTypeLibraries
    Action 05:25:50: UnregisterTypeLibraries. Unregistering type libraries
    Action start 05:25:50: UnregisterTypeLibraries.
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
    Action ended 05:25:50: UnregisterTypeLibraries. Return value 0.
    MSI (s) (28:78) [05:25:50:569]: Doing action: RemoveODBC
    Action 05:25:50: RemoveODBC. Removing ODBC components
    Action start 05:25:50: RemoveODBC.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager
    1: Removing ODBC components
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager64
    Action ended 05:25:50: RemoveODBC. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterFonts
    Action 05:25:50: UnregisterFonts. Unregistering fonts
    Action start 05:25:50: UnregisterFonts.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
    Action ended 05:25:50: UnregisterFonts. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: RemoveRegistryValues
    Action 05:25:50: RemoveRegistryValues. Removing system registry values
    Action start 05:25:50: RemoveRegistryValues.
    Action ended 05:25:50: RemoveRegistryValues. Return value 1.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterClassInfo
    Action 05:25:50: UnregisterClassInfo. Unregister class servers
    Action start 05:25:50: UnregisterClassInfo.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterClassInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterExtensionInfo
    Action 05:25:50: UnregisterExtensionInfo. Unregistering extension servers
    Action start 05:25:50: UnregisterExtensionInfo.
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterExtensionInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterProgIdInfo
    Action 05:25:50: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 05:25:50: UnregisterProgIdInfo.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterProgIdInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: UnregisterMIMEInfo
    Action 05:25:50: UnregisterMIMEInfo. Unregistering MIME info
    Action start 05:25:50: UnregisterMIMEInfo.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: MIME
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: UnregisterMIMEInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveIniValues
    Action 05:25:50: RemoveIniValues. Removing INI file entries
    Action start 05:25:50: RemoveIniValues.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
    Action ended 05:25:50: RemoveIniValues. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveShortcuts
    Action 05:25:50: RemoveShortcuts. Removing shortcuts
    Action start 05:25:50: RemoveShortcuts.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 05:25:50: RemoveShortcuts. Return value 0.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveEnvironmentStrings
    Action 05:25:50: RemoveEnvironmentStrings. Updating environment strings
    Action start 05:25:50: RemoveEnvironmentStrings.
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Environment
    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
    Action ended 05:25:50: RemoveEnvironmentStrings. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveDuplicateFiles
    Action 05:25:50: RemoveDuplicateFiles. Removing duplicated files
    Action start 05:25:50: RemoveDuplicateFiles.
    Action ended 05:25:50: RemoveDuplicateFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveFolders
    Action 05:25:50: RemoveFolders. Removing folders
    Action start 05:25:50: RemoveFolders.
    Action ended 05:25:50: RemoveFolders. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: CreateFolders
    Action 05:25:50: CreateFolders. Creating folders
    Action start 05:25:50: CreateFolders.
    CreateFolders: Folder: Creating folders
    Action ended 05:25:50: CreateFolders. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: MoveFiles
    Action 05:25:50: MoveFiles. Moving files
    Action start 05:25:50: MoveFiles.
    Action ended 05:25:50: MoveFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:600]: Doing action: InstallFiles
    Action 05:25:50: InstallFiles. Copying new files
    Action start 05:25:50: InstallFiles.
    MSI (s) (28:78) [05:25:50:616]: Dumping binary patch manager data...
    MSI (s) (28:78) [05:25:50:616]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
    InstallFiles: File: Copying new files,  Directory: ,  Size:
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiSFCBypass
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: PatchPackage
    Action ended 05:25:50: InstallFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: NewCustomAction1
    Action 05:25:50: NewCustomAction1.
    Action start 05:25:50: NewCustomAction1.
    NewCustomAction1:
    Action ended 05:25:50: NewCustomAction1. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: PatchFiles
    Action 05:25:50: PatchFiles. Patching files
    Action start 05:25:50: PatchFiles.
    Action ended 05:25:50: PatchFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: DuplicateFiles
    Action 05:25:50: DuplicateFiles. Creating duplicate files
    Action start 05:25:50: DuplicateFiles.
    Action ended 05:25:50: DuplicateFiles. Return value 1.
    MSI (s) (28:78) [05:25:50:616]: Doing action: BindImage
    Action 05:25:50: BindImage. Binding executables
    Action start 05:25:50: BindImage.
    Action ended 05:25:50: BindImage. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: CreateShortcuts
    Action 05:25:50: CreateShortcuts. Creating shortcuts
    Action start 05:25:50: CreateShortcuts.
    CreateShortcuts: Shortcut: Creating shortcuts
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: CreateShortcuts. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterClassInfo
    Action 05:25:50: RegisterClassInfo. Registering class servers
    Action start 05:25:50: RegisterClassInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Class
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterClassInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterExtensionInfo
    Action 05:25:50: RegisterExtensionInfo. Registering extension servers
    Action start 05:25:50: RegisterExtensionInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Extension
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterExtensionInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterProgIdInfo
    Action 05:25:50: RegisterProgIdInfo. Registering program identifiers
    Action start 05:25:50: RegisterProgIdInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterProgIdInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterMIMEInfo
    Action 05:25:50: RegisterMIMEInfo. Registering MIME info
    Action start 05:25:50: RegisterMIMEInfo.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: MIME
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 05:25:50: RegisterMIMEInfo. Return value 0.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteRegistryValues
    Action 05:25:50: WriteRegistryValues. Writing system registry values
    Action start 05:25:50: WriteRegistryValues.
    WriteRegistryValues: Key: Writing system registry values, Name: , Value:
    Action ended 05:25:50: WriteRegistryValues. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteIniValues
    Action 05:25:50: WriteIniValues. Writing INI file values
    Action start 05:25:50: WriteIniValues.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
    Action ended 05:25:50: WriteIniValues. Return value 1.
    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteEnvironmentStrings
    Action 05:25:50: WriteEnvironmentStrings. Updating environment strings
    Action start 05:25:50: WriteEnvironmentStrings.
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Environment
    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
    Action ended 05:25:50: WriteEnvironmentStrings. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterFonts
    Action 05:25:50: RegisterFonts. Registering fonts
    Action start 05:25:50: RegisterFonts.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Font
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
    Action ended 05:25:50: RegisterFonts. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallODBC
    Action 05:25:50: InstallODBC. Installing ODBC components
    Action start 05:25:50: InstallODBC.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager64
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`Fil eName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,` Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
    Action ended 05:25:50: InstallODBC. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterTypeLibraries
    Action 05:25:50: RegisterTypeLibraries. Registering type libraries
    Action start 05:25:50: RegisterTypeLibraries.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
    Action ended 05:25:50: RegisterTypeLibraries. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: SelfRegModules
    Action 05:25:50: SelfRegModules. Registering modules
    Action start 05:25:50: SelfRegModules.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Actio n`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
    Action ended 05:25:50: SelfRegModules. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterComPlus
    Action 05:25:50: RegisterComPlus. Registering COM+ Applications and Components
    Action start 05:25:50: RegisterComPlus.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Complus
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: RegisterComPlus. Return value 0.
    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallServices
    Action 05:25:50: InstallServices. Installing new services
    Action start 05:25:50: InstallServices.
    MSI (s) (28:78) [05:25:50:647]: Detected older ServiceInstall table schema
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceInstall
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`Erro rControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`Comp onentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: InstallServices. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: StartServices
    Action 05:25:50: StartServices. Starting services
    Action start 05:25:50: StartServices.
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 05:25:50: StartServices. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterUser
    Action 05:25:50: RegisterUser. Registering user
    Action start 05:25:50: RegisterUser.
    RegisterUser: Registering user
    Action ended 05:25:50: RegisterUser. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterProduct
    Action 05:25:50: RegisterProduct. Registering product
    Action start 05:25:50: RegisterProduct.
    RegisterProduct: Registering product
    MSI (s) (28:78) [05:25:50:647]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
    Action ended 05:25:50: RegisterProduct. Return value 1.
    MSI (s) (28:78) [05:25:50:647]: Doing action: PublishComponents
    Action 05:25:50: PublishComponents. Publishing qualified components
    Action start 05:25:50: PublishComponents.
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: PublishComponents. Return value 0.
    MSI (s) (28:78) [05:25:50:663]: Doing action: MsiPublishAssemblies
    Action 05:25:50: MsiPublishAssemblies. Publishing assembly information
    Action start 05:25:50: MsiPublishAssemblies.
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 05:25:50: MsiPublishAssemblies. Return value 0.
    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishFeatures
    Action 05:25:50: PublishFeatures. Publishing product features
    Action start 05:25:50: PublishFeatures.
    PublishFeatures: Feature: Publishing product features
    Action ended 05:25:50: PublishFeatures. Return value 1.
    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishProduct
    Action 05:25:50: PublishProduct. Publishing product information
    Action start 05:25:50: PublishProduct.
    1: Publishing product information
    Action ended 05:25:50: PublishProduct. Return value 1.
    MSI (s) (28:78) [05:25:50:663]: Skipping action: ScheduleReboot (condition is false)
    MSI (s) (28:78) [05:25:50:663]: Doing action: InstallFinalize
    Action 05:25:50: InstallFinalize.
    Action start 05:25:50: InstallFinalize.
    MSI (s) (28:78) [05:25:50:663]: Running Script: C:\Windows\Installer\MSI2E1D.tmp
    MSI (s) (28:78) [05:25:50:663]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
    MSI (s) (28:78) [05:25:50:663]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:50:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
    MSI (s) (28:78) [05:25:50:678]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1 033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVers ion=4,ScriptAttributes=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},Product Name=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language =1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPROD UCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,Inst anceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
    MSI (s) (28:78) [05:25:50:678]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=0,)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=1,)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    Action 5:25:50: ProcessComponents. Updating component registration
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633}, KeyPath=C:\Windows\system32\Macromed\Flash\,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F}, KeyPath=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk =1,SharedDllRefCount=1,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
    Action 5:25:50: RemoveODBC. Removing ODBC components
    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=0)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    Action 5:25:50: CreateFolders. Creating folders
    MSI (s) (28:78) [05:25:50:678]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
    CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    Action 5:25:50: InstallFiles. Copying new files
    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
    MSI (s) (28:78) [05:25:50:678]: Executing op: SetSourceFolder(Folder=1\Temp\)
    MSI (s) (28:78) [05:25:50:678]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileNa me=C:\Windows\Installer\1201d91.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (s) (28:78) [05:25:50:678]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=Install AX64.exe,DestName=InstallAX64.exe,Attributes=16384,FileSize=8767136,Pe rTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=11.2.202.228,Languag e=1033,InstallMode=58982400,,,,,,,)
    MSI (s) (28:78) [05:25:50:678]: File: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
    MSI (s) (28:78) [05:25:50:678]: Source for file 'InstallAX64.exe' is compressed
    InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Ad~1\AppData\Local\Temp\,  Size: 8767136
    MSI (s) (28:78) [05:25:50:772]: Executing op: CacheSizeFlush(,)
    MSI (s) (28:78) [05:25:50:772]: Executing op: ActionStart(Name=NewCustomAction1,,)
    Action 5:25:50: NewCustomAction1.
    MSI (s) (28:78) [05:25:50:772]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C :\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,Target=-install -msi,)
    CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
    MSI (s) (28:78) [05:25:53:788]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
    Info 2835.The control ErrorIcon was not found on dialog SetupError.
    Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
    MSI (s) (28:78) [05:25:58:694]: Product: Adobe Flash Player 11 ActiveX (x64) -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
    Action ended 05:25:58: InstallFinalize. Return value 3.
    MSI (s) (28:78) [05:25:58:694]: User policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:58:694]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:78) [05:25:58:694]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1 033,Platform=589824,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVers ion=4,ScriptAttributes=1)
    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
    MSI (s) (28:78) [05:25:58:694]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
    Action 5:25:58: Rollback. Rolling back action:
    Rollback: NewCustomAction1
    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=NewCustomAction1,,)
    MSI (s) (28:78) [05:25:58:694]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},Product Name=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language =1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPROD UCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,Inst anceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
    Rollback: Copying new files
    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    MSI (s) (28:78) [05:25:58:694]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
    MSI (s) (28:78) [05:25:58:694]: Executing op: FileRemove(,FileName=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe ,,)
    Rollback: Creating folders
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    MSI (s) (28:78) [05:25:58:709]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,Sec urityDescriptor=BinaryData,)
    Rollback: Removing ODBC components
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
    Rollback: Updating component registration
    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F },ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633 },ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
    MSI (s) (28:78) [05:25:58:709]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
    MSI (s) (28:78) [05:25:58:709]: Error in rollback skipped. Return: 5
    MSI (s) (28:78) [05:25:58:709]: Note: 1: 2318 2:
    MSI (s) (28:78) [05:25:58:709]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 390, szDescription: "".
    MSI (s) (28:78) [05:25:58:709]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
    MSI (s) (28:78) [05:25:58:709]: Unlocking Server
    MSI (s) (28:78) [05:25:59:350]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
    Action ended 05:25:59: INSTALL. Return value 3.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
    Property(S): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(S): ProductToBeRegistered = 1
    Property(S): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(S): SOURCEDIR = C:\Users\Admin\Desktop\
    Property(S): VersionNT = 601
    Property(S): TARGETDIR = E:\
    Property(S): ALLUSERSPROFILE = C:\ProgramData\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
    Property(S): MACROMED = C:\Windows\system32\Macromed\
    Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
    Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
    Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
    Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    Property(S): System64Folder = C:\Windows\system32\
    Property(S): CostingComplete = 1
    Property(S): SourceDir = C:\Users\Admin\Desktop\
    Property(S): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
    Property(S): USERPROFILE = C:\Users\Admin\
    Property(S): Preselected = 1
    Property(S): UILevel = 5
    Property(S): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(S): DATABASE = C:\Windows\Installer\1201d91.msi
    Property(S): Privileged = 1
    Property(S): MsiRunningElevated = 1
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
    Property(S): MsiNetAssemblySupport = 4.0.30319.1
    Property(S): Date = 4/12/2012
    Property(S): Time = 5:25:59
    Property(S): TTCSupport = 1
    Property(S): ColorBits = 32
    Property(S): TextInternalLeading = 3
    Property(S): TextHeight = 16
    Property(S): BorderSide = 1
    Property(S): BorderTop = 1
    Property(S): CaptionHeight = 22
    Property(S): ScreenY = 768
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): RestartManagerOption = CloseRestart
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): Display_IsBitmapDlg = 1
    Property(S): ScreenX = 1024
    Property(S): ProductName = Adobe Flash Player 11 ActiveX (x64)
    Property(S): ALLUSERS = 1
    Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
    Property(S): ARPNOMODIFY = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): ARPURLINFOABOUT = http://www.adobe.com
    Property(S): SystemLanguageID = 1033
    Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
    Property(S): DWUSINTERVAL = 30
    Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE 08FD9AC
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): ErrorDialog = SetupError
    Property(S): INSTALLLEVEL = 100
    Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): InstallChoice = AR
    Property(S): Manufacturer = Adobe Systems Incorporated
    Property(S): MsiLogging = voicewarmupx
    Property(S): NewProperty2 = 0
    Property(S): NewProperty3 = 0
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
    Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(S): ProductID = none
    Property(S): ProductLanguage = 1033
    Property(S): ProductVersion = 11.2.202.228
    Property(S): ProgressType0 = install
    Property(S): ProgressType1 = Installing
    Property(S): ProgressType2 = installed
    Property(S): ProgressType3 = installs
    Property(S): RebootYesNo = Yes
    Property(S): ReinstallModeText = omus
    Property(S): SHOWLAUNCHPROGRAM = 0
    Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
    Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
    Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
    Property(S): ARPINSTALLLOCATION = C:\Windows\system32\Macromed\Flash\
    Property(S): ComputerName = NSDQ01
    Property(S): UserLanguageID = 1033
    Property(S): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
    Property(S): LogonUser = Admin
    Property(S): AdminUser = 1
    Property(S): MsiTrueAdminUser = 1
    Property(S): VirtualMemory = 6406
    Property(S): PhysicalMemory = 4094
    Property(S): Intel = 6
    Property(S): Msix64 = 6
    Property(S): MsiAMD64 = 6
    Property(S): ShellAdvtSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): GPTSupport = 1
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): MyPicturesFolder = C:\Users\Admin\Pictures\
    Property(S): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): USERNAME = Viking
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): PersonalFolder = C:\Users\Admin\Documents\
    Property(S): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): FavoritesFolder = C:\Users\Admin\Favorites\
    Property(S): AppDataFolder = C:\Users\Admin\AppData\Roaming\
    Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
    Property(S): ProgramFiles64Folder = C:\Program Files\
    Property(S): ProgramFilesFolder = C:\Program Files (x86)\
    Property(S): RemoteAdminTS = 1
    Property(S): SystemFolder = C:\Windows\SysWOW64\
    Property(S): WindowsVolume = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): MsiNTProductType = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): ServicePackLevel = 1
    Property(S): WindowsBuild = 7601
    Property(S): VersionNT64 = 601
    Property(S): VersionMsi = 5.00
    Property(S): MsiSystemRebootPending = 1
    Property(S): ADDLOCAL = FlashPlayerAXInstaller
    Property(S): CURRENTDIRECTORY = C:\Users\Admin\Desktop
    Property(S): CLIENTUILEVEL = 0
    Property(S): CLIENTPROCESSID = 4596
    Property(S): VersionDatabase = 200
    Property(S): ACTION = INSTALL
    Property(S): EXECUTEACTION = INSTALL
    Property(S): ROOTDRIVE = E:\
    Property(S): SECONDSEQUENCE = 1
    Property(S): PackagecodeChanging = 1
    Property(S): ProductState = -1
    Property(S): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
    Property(S): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
    MSI (s) (28:78) [05:25:59:366]: MainEngineThread is returning 1603
    MSI (s) (28:94) [05:25:59:366]: RESTART MANAGER: Session closed.
    MSI (s) (28:94) [05:25:59:366]: User policy value 'DisableRollback' is 0
    MSI (s) (28:94) [05:25:59:366]: Machine policy value 'DisableRollback' is 0
    MSI (s) (28:94) [05:25:59:366]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (s) (28:94) [05:25:59:366]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
    MSI (s) (28:94) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (s) (28:94) [05:25:59:381]: Restoring environment variables
    MSI (c) (F4:64) [05:25:59:381]: Back from server. Return value: 1603
    MSI (c) (F4:64) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (c) (F4:64) [05:25:59:381]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
    Action ended 05:25:59: ExecuteAction. Return value 3.
    MSI (c) (F4:64) [05:25:59:381]: Doing action: SetupCompleteError
    Action 05:25:59: SetupCompleteError.
    Action start 05:25:59: SetupCompleteError.
    Action 05:25:59: SetupCompleteError. Dialog created
    Action ended 05:26:00: SetupCompleteError. Return value 2.
    Action ended 05:26:00: INSTALL. Return value 3.
    MSI (c) (F4:64) [05:26:00:694]: Destroying RemoteAPI object.
    MSI (c) (F4:DC) [05:26:00:709]: Custom Action Manager thread ending.
    Property(C): DiskPrompt = [1]
    Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
    Property(C): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(C): PrimaryVolumeSpaceRemaining = 0
    Property(C): PrimaryVolumeSpaceRequired = 0
    Property(C): PrimaryVolumeSpaceAvailable = 0
    Property(C): OutOfNoRbDiskSpace = 0
    Property(C): OutOfDiskSpace = 0
    Property(C): VersionNT = 601
    Property(C): TARGETDIR = E:\
    Property(C): ALLUSERSPROFILE = C:\ProgramData\
    Property(C): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
    Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
    Property(C): MACROMED = C:\Windows\system32\Macromed\
    Property(C): FLASH = C:\Windows\system32\Macromed\Flash\
    Property(C): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
    Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
    Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    Property(C): System64Folder = C:\Windows\system32\
    Property(C): CostingComplete = 1
    Property(C): ROOTDRIVE = E:\
    Property(C): SourceDir = C:\Users\Admin\Desktop\
    Property(C): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
    Property(C): USERPROFILE = C:\Users\Admin\
    Property(C): EXECUTEACTION = INSTALL
    Property(C): ACTION = INSTALL
    Property(C): UILevel = 5
    Property(C): VersionHandler = 5.00
    Property(C): SOURCEDIR = C:\Users\Admin\Desktop\
    Property(C): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(C): DATABASE = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
    Property(C): Privileged = 1
    Property(C): MsiRunningElevated = 1
    Property(C): RedirectedDllSupport = 2
    Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
    Property(C): MsiNetAssemblySupport = 4.0.30319.1
    Property(C): Date = 4/12/2012
    Property(C): Time = 05:26:00
    Property(C): TTCSupport = 1
    Property(C): ISCHECKFORPRODUCTUPDATES = 1
    Property(C): ApplicationUsers = AllUsers
    Property(C): AgreeToLicense = No
    Property(C): _IsMaintenance = Change
    Property(C): RestartManagerOption = CloseRestart
    Property(C): IS_SQLSERVER_USERNAME = sa
    Property(C): IS_SQLSERVER_AUTHENTICATION = 0
    Property(C): SetupType = Typical
    Property(C): _IsSetupTypeMin = Typical
    Property(C): Display_IsBitmapDlg = 1
    Property(C): ProductName = Adobe Flash Player 11 ActiveX (x64)
    Property(C): ALLUSERS = 1
    Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
    Property(C): ARPNOMODIFY = 1
    Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(C): ARPURLINFOABOUT = http://www.adobe.com
    Property(C): ColorBits = 32
    Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
    Property(C): DWUSINTERVAL = 30
    Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE 08FD9AC
    Property(C): DefaultUIFont = Tahoma8
    Property(C): DialogCaption = InstallShield for Windows Installer
    Property(C): DisplayNameCustom = Custom
    Property(C): DisplayNameMinimal = Minimal
    Property(C): DisplayNameTypical = Typical
    Property(C): ErrorDialog = SetupError
    Property(C): INSTALLLEVEL = 100
    Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
    Property(C): ISVROOT_PORT_NO = 0
    Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(C): InstallChoice = AR
    Property(C): Manufacturer = Adobe Systems Incorporated
    Property(C): MsiLogging = voicewarmupx
    Property(C): NewProperty2 = 0
    Property(C): NewProperty3 = 0
    Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
    Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
    Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
    Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(C): ProductID = none
    Property(C): ProductLanguage = 1033
    Property(C): ProductVersion = 11.2.202.228
    Property(C): ProgressType0 = install
    Property(C): ProgressType1 = Installing
    Property(C): ProgressType2 = installed
    Property(C): ProgressType3 = installs
    Property(C): RebootYesNo = Yes
    Property(C): ReinstallModeText = omus
    Property(C): SHOWLAUNCHPROGRAM = 0
    Property(C): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
    Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
    Property(C): TextInternalLeading = 3
    Property(C): TextHeight = 16
    Property(C): BorderSide = 1
    Property(C): BorderTop = 1
    Property(C): AdminUser = 1
    Property(C): CaptionHeight = 22
    Property(C): ScreenY = 1080
    Property(C): ScreenX = 1920
    Property(C): SystemLanguageID = 1033
    Property(C): ComputerName = NSDQ01
    Property(C): UserLanguageID = 1033
    Property(C): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
    Property(C): LogonUser = Admin
    Property(C): MsiTrueAdminUser = 1
    Property(C): VirtualMemory = 6439
    Property(C): PhysicalMemory = 4094
    Property(C): Intel = 6
    Property(C): Msix64 = 6
    Property(C): MsiAMD64 = 6
    Property(C): ShellAdvtSupport = 1
    Property(C): OLEAdvtSupport = 1
    Property(C): GPTSupport = 1
    Property(C): FontsFolder = C:\Windows\Fonts\
    Property(C): DesktopFolder = C:\Users\Public\Desktop\
    Property(C): USERNAME = Viking
    Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(C): MyPicturesFolder = C:\Users\Admin\Pictures\
    Property(C): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
    Property(C): CommonAppDataFolder = C:\ProgramData\
    Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(C): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(C): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
    Property(C): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(C): PersonalFolder = C:\Users\Admin\Documents\
    Property(C): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(C): FavoritesFolder = C:\Users\Admin\Favorites\
    Property(C): AppDataFolder = C:\Users\Admin\AppData\Roaming\
    Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
    Property(C): ProgramFiles64Folder = C:\Program Files\
    Property(C): ProgramFilesFolder = C:\Program Files (x86)\
    Property(C): RemoteAdminTS = 1
    Property(C): SystemFolder = C:\Windows\SysWOW64\
    Property(C): WindowsVolume = C:\
    Property(C): WindowsFolder = C:\Windows\
    Property(C): MsiNTProductType = 1
    Property(C): ServicePackLevelMinor = 0
    Property(C): ServicePackLevel = 1
    Property(C): WindowsBuild = 7601
    Property(C): VersionNT64 = 601
    Property(C): VersionMsi = 5.00
    Property(C): VersionDatabase = 200
    Property(C): MsiSystemRebootPending = 1
    Property(C): CLIENTPROCESSID = 4596
    Property(C): CLIENTUILEVEL = 0
    Property(C): CURRENTDIRECTORY = C:\Users\Admin\Desktop
    Property(C): PackagecodeChanging = 1
    Property(C): ProductState = -1
    Property(C): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
    Property(C): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
    === Logging stopped: 4/12/2012  05:26:00 ===
    MSI (c) (F4:64) [05:26:00:709]: Note: 1: 1708
    MSI (c) (F4:64) [05:26:00:709]: Product: Adobe Flash Player 11 ActiveX (x64) -- Installation operation failed.
    MSI (c) (F4:64) [05:26:00:709]: Windows Installer installed the product. Product Name: Adobe Flash Player 11 ActiveX (x64). Product Version: 11.2.202.228. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
    MSI (c) (F4:64) [05:26:00:709]: Grabbed execution mutex.
    MSI (c) (F4:64) [05:26:00:709]: Cleaning up uninstalled install packages, if any exist
    MSI (c) (F4:64) [05:26:00:709]: MainEngineThread is returning 1603
    === Verbose logging stopped: 4/12/2012  05:26:00 ===
  • Chris Campbell
    May 4, 2010
    Apr 12, 2012 1:08 PM   in reply to UnFlash
    Are you running the .msi or .exe?  If .msi, can you try the .exe instead?
    Apr 12, 2012 6:21 PM   in reply to Chris Campbell
    Chris, I did all three: MSI, MSI extracted EXE, and EXE. With a re-check or permissions and a Adobe clean up w/ reboot between. Running as admin. SW, reader, and java all removed and reinstalled without issue.
    Thnak you.
  • Chris Campbell
    May 4, 2010
    Apr 12, 2012 6:24 PM   in reply to UnFlash
    could you post the contents of your flashinstall.log?
    Where do I find the Flash Player installation log on Windows?
    Apr 12, 2012 7:46 PM   in reply to Chris Campbell
    Installed the EXE extracted from the MSI.
    32 BIT:
    =O====== M/11.2.202.228 2012-04-13+02-38-35.903 ========
    0000 [I] 00000010 "C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit\InstallAX64.exe"
    0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0005 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0007 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
    0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.e xe
    0009 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.d ll
    0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0011 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
    0012 [I] 00000018
    0013 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
    0014 [I] 00000011 1
    =X====== M/11.2.202.228 2012-04-13+02-40-02.410 ========
    And now 64 BIT:
    =O====== M/11.2.202.228 2012-04-13+02-38-44.262 ========
    0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
    0001 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\{962A8EE6-178E-4769-95EC-7ADB7C363 052}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1
    0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
    0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx
    0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.e xe
    0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.d ll
    0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0011 [W] 00001102
    0012 [W] 00001106
    0013 [W] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
    0014 [I] 00000018
    0015 [E] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
    =X====== M/11.2.202.228 2012-04-13+02-38-49.458 ========
    Thank you.
    Apr 12, 2012 8:14 PM   in reply to UnFlash
    There are obviously some permission problems (80070005).
    Can you try
    P.S. you got the names wrong: system32 is 64-bit, syswow64 is 32-bit.
    Apr 12, 2012 8:36 PM   in reply to Pat Willener
    Done and rebooted. @ PS Long day . Tried install, same results.
    Apr 12, 2012 8:42 PM   in reply to UnFlash
    =O====== M/11.2.202.228 2012-04-13+03-21-24.389 ========
    0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
    0001 [I] 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_64bit.exe" -force
    0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0005 [W] 00001018
    0006 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
    0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0008 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0009 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0010 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0011 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0012 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
    0013 [W] 00001021
    0014 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0016 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlay erCPLApp.cpl 2
    0017 [W] 00001048
    0018 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
    0019 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0021 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlay erCPLApp.cpl 2
    0022 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0025 [W] 00001018
    0026 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0027 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0028 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0029 [W] 00001019
    0030 [W] 00001020
    0031 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0032 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0033 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0034 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0035 [W] 00001021
    0036 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0038 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlay erCPLApp.cpl 2
    0039 [W] 00001048
    0040 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
    0041 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0042 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0043 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlay erCPLApp.cpl 2
    0044 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0045 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0046 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0047 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0048 [W] 00001036 Software\Opera Software/Plugin Path 2
    0049 [W] 00001036 Software\Opera Software/Plugin Path 2
    0050 [I] 00000011 1
    =X====== M/11.2.202.228 2012-04-13+03-21-29.170 ========
    =O====== M/11.2.202.228 2012-04-13+03-34-50.133 ========
    0000 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe" -install -msi
    0003 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0005 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
    0006 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.e xe
    0007 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.d ll
    0008 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0009 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
    0010 [I] 00000018
    0011 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
    =X====== M/11.2.202.228 2012-04-13+03-34-57.058 ========
    Next
    =O====== M/11.2.202.228 2012-04-13+03-21-19.202 ========
    0001 [I] 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_32bit.exe" -force
    0002 [E] 00001042
    =X====== M/11.2.202.228 2012-04-13+03-21-22.061 ========
    =O====== M/11.2.202.228 2012-04-13+03-21-27.717 ========
    0000 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\{5BB16666-101E-410A-B931-A384C4339 FEC}\InstallFlashPlayer.exe" -force  -uninstall
    0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0002 [W] 00001018
    0003 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
    0005 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0006 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0007 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0008 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0009 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
    0010 [W] 00001021
    0011 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0013 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlay erCPLApp.cpl 2
    0014 [W] 00001048
    0015 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0016 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0018 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlay erCPLApp.cpl 2
    0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0022 [W] 00001018
    0023 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0024 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0025 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0026 [W] 00001019
    0027 [W] 00001020
    0028 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0029 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0030 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0031 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0032 [W] 00001021
    0033 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0035 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlay erCPLApp.cpl 2
    0036 [W] 00001048
    0037 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0038 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0039 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0040 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlay erCPLApp.cpl 2
    0043 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0044 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0045 [W] 00001036 Software\Opera Software/Plugin Path 2
    0046 [W] 00001036 Software\Opera Software/Plugin Path 2
    =X====== M/11.2.202.228 2012-04-13+03-21-27.874 ========
    And
    === Verbose logging started: 4/12/2012  22:33:46  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
    MSI (c) (64:A0) [22:33:46:086]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (64:B0) [22:33:46:102]: Resetting cached policy values
    MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'Debug' is 0
    MSI (c) (64:B0) [22:33:46:102]: ******* RunEngine:
               ******* Product: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi
               ******* Action:
               ******* CommandLine: **********
    MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit.msi' against software restriction policy
    MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi has a digital signature
    MSI (c) (64:B0) [22:33:46:243]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (64:B0) [22:33:46:336]: Cloaking enabled.
    MSI (c) (64:B0) [22:33:46:336]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (64:B0) [22:33:46:336]: End dialog not enabled
    MSI (c) (64:B0) [22:33:46:336]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi
    MSI (c) (64:B0) [22:33:46:336]: Package we're running from ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi
    MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (64:B0) [22:33:46:383]: MSCOREE not loaded loading copy from system32
    MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (64:B0) [22:33:46:415]: User policy value 'TransformsAtSource' is 0
    MSI (c) (64:B0) [22:33:46:415]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisablePatch' is 0
    MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (64:B0) [22:33:46:430]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (64:B0) [22:33:46:430]: Transforms are not secure.
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
    MSI (c) (64:B0) [22:33:46:430]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download CLIENTUILEVEL=0 CLIENTPROCESSID=3940
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (c) (64:B0) [22:33:46:430]: Product Code passed to Engine.Initialize:           ''
    MSI (c) (64:B0) [22:33:46:430]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (64:B0) [22:33:46:430]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (c) (64:B0) [22:33:46:430]: Product not registered: beginning first-time install
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (c) (64:B0) [22:33:46:430]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (64:B0) [22:33:46:430]: User policy value 'SearchOrder' is 'nmu'
    MSI (c) (64:B0) [22:33:46:430]: Adding new sources is allowed.
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (c) (64:B0) [22:33:46:430]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (64:B0) [22:33:46:430]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableMsi' is 0
    MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (64:B0) [22:33:46:430]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (64:B0) [22:33:46:430]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (c) (64:B0) [22:33:46:430]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
    MSI (c) (64:B0) [22:33:46:430]: TRANSFORMS property is now:
    MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
    MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (64:B0) [22:33:46:446]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit.msi'.
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit.msi'.
    MSI (c) (64:B0) [22:33:46:446]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (c) (64:A0) [22:33:46:477]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
    === Logging started: 4/12/2012  22:33:46 ===
    MSI (c) (64:B0) [22:33:46:477]: Note: 1: 2205 2:  3: PatchPackage
    MSI (c) (64:B0) [22:33:46:477]: Machine policy value 'DisableRollback' is 0
    MSI (c) (64:B0) [22:33:46:477]: User policy value 'DisableRollback' is 0
    MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (64:B0) [22:33:46:477]: Doing action: INSTALL
    Action 22:33:46: INSTALL.
    Action start 22:33:46: INSTALL.
    MSI (c) (64:B0) [22:33:46:477]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (64:B0) [22:33:46:477]: Running UISequence
    MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (64:B0) [22:33:46:477]: Doing action: ISSetAllUsers
    Action 22:33:46: ISSetAllUsers.
    Action start 22:33:46: ISSetAllUsers.
    MSI (c) (64:B0) [22:33:46:524]: Creating MSIHANDLE (1) of type 790542 for thread 1968
    MSI (c) (64:2C) [22:33:46:540]: Invoking remote custom action. DLL: C:\Users\Admin\AppData\Local\Temp\MSI8A0F.tmp, Entrypoint: SetAllUsers
    MSI (c) (64:A8) [22:33:46:540]: Cloaking enabled.
    MSI (c) (64:A8) [22:33:46:540]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (64:A8) [22:33:46:540]: Connected to service for CA interface.
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (2) of type 790531 for thread 3748
    InstallShield 22:33:46: Begin SetAllUsers()
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (2) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (3) of type 790541 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (4) of type 790531 for thread 3748
    InstallShield 22:33:46: Getting records from Upgrade table
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (4) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (5) of type 790540 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (6) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (7) of type 790531 for thread 3748
    InstallShield 22:33:46: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (7) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (8) of type 790531 for thread 3748
    InstallShield 22:33:46: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (8) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (6) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (9) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (10) of type 790531 for thread 3748
    InstallShield 22:33:46: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (10) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (11) of type 790531 for thread 3748
    InstallShield 22:33:46: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (11) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (9) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (12) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (13) of type 790531 for thread 3748
    InstallShield 22:33:46: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (13) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (14) of type 790531 for thread 3748
    InstallShield 22:33:46: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (14) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (12) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (15) of type 790531 for thread 3748
    InstallShield 22:33:46: End SetAllUsers()
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (15) of type 790531 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (5) of type 790540 for thread 3748
    MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (3) of type 790541 for thread 3748
    MSI (c) (64:2C) [22:33:46:821]: Closing MSIHANDLE (1) of type 790542 for thread 1968
    Action ended 22:33:46: ISSetAllUsers. Return value 1.
    MSI (c) (64:B0) [22:33:46:821]: Doing action: AppSearch
    Action 22:33:46: AppSearch. Searching for installed applications
    Action start 22:33:46: AppSearch.
    MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2205 2:  3: AppSearch
    MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
    Action ended 22:33:46: AppSearch. Return value 0.
    MSI (c) (64:B0) [22:33:46:821]: Doing action: LaunchConditions
    Action 22:33:46: LaunchConditions. Evaluating launch conditions
    Action start 22:33:46: LaunchConditions.
    Action ended 22:33:46: LaunchConditions. Return value 1.
    MSI (c) (64:B0) [22:33:46:821]: Doing action: SetupInitialization
    Action 22:33:46: SetupInitialization.
    Action start 22:33:46: SetupInitialization.
    Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 22:33:46: SetupInitialization. Dialog created
    Action ended 22:33:46: SetupInitialization. Return value 1.
    MSI (c) (64:B0) [22:33:46:852]: Doing action: FindRelatedProducts
    Action 22:33:46: FindRelatedProducts. Searching for related applications
    Action start 22:33:46: FindRelatedProducts.
    Action ended 22:33:46: FindRelatedProducts. Return value 1.
    MSI (c) (64:B0) [22:33:46:852]: Skipping action: CCPSearch (condition is false)
    MSI (c) (64:B0) [22:33:46:852]: Skipping action: RMCCPSearch (condition is false)
    MSI (c) (64:B0) [22:33:46:852]: Doing action: ValidateProductID
    Action 22:33:46: ValidateProductID.
    Action start 22:33:46: ValidateProductID.
    Action ended 22:33:46: ValidateProductID. Return value 1.
    MSI (c) (64:B0) [22:33:46:852]: Doing action: CostInitialize
    Action 22:33:46: CostInitialize. Computing space requirements
    Action start 22:33:46: CostInitialize.
    MSI (c) (64:B0) [22:33:46:852]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (c) (64:B0) [22:33:46:852]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (c) (64:B0) [22:33:46:852]: Baseline: New baseline 11.2.202 from transaction.
    MSI (c) (64:B0) [22:33:46:899]: Baseline: Sorted order Native: Order 0.
    MSI (c) (64:B0) [22:33:46:899]: Baseline Data Table:
    MSI (c) (64:B0) [22:33:46:899]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (c) (64:B0) [22:33:46:899]: Baseline File Table:
    MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    Action ended 22:33:46: CostInitialize. Return value 1.
    MSI (c) (64:B0) [22:33:46:915]: Doing action: FileCost
    Action 22:33:46: FileCost. Computing space requirements
    Action start 22:33:46: FileCost.
    MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Class
    MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Extension
    MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: TypeLib
    Action ended 22:33:46: FileCost. Return value 1.
    MSI (c) (64:B0) [22:33:46:915]: Doing action: IsolateComponents
    Action 22:33:46: IsolateComponents.
    Action start 22:33:46: IsolateComponents.
    Action ended 22:33:46: IsolateComponents. Return value 0.
    MSI (c) (64:B0) [22:33:46:915]: Doing action: setUserProfileNT
    Action 22:33:46: setUserProfileNT.
    Action start 22:33:46: setUserProfileNT.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
    Action ended 22:33:46: setUserProfileNT. Return value 1.
    MSI (c) (64:B0) [22:33:46:930]: Skipping action: SetAllUsersProfileNT (condition is false)
    MSI (c) (64:B0) [22:33:46:930]: Doing action: setAllUsersProfile2K
    Action 22:33:46: setAllUsersProfile2K.
    Action start 22:33:46: setAllUsersProfile2K.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
    Action ended 22:33:46: setAllUsersProfile2K. Return value 1.
    MSI (c) (64:B0) [22:33:46:930]: Doing action: ResolveSource
    Action 22:33:46: ResolveSource.
    Action start 22:33:46: ResolveSource.
    MSI (c) (64:B0) [22:33:46:930]: Resolving source.
    MSI (c) (64:B0) [22:33:46:930]: Resolving source to launched-from source.
    MSI (c) (64:B0) [22:33:46:930]: Setting launched-from source as last-used.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
    MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (c) (64:B0) [22:33:46:930]: Determining source type
    MSI (c) (64:B0) [22:33:46:930]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (c) (64:B0) [22:33:46:930]: Source path resolution complete. Dumping Directory table...
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action ended 22:33:46: ResolveSource. Return value 1.
    MSI (c) (64:B0) [22:33:46:930]: Doing action: CostFinalize
    Action 22:33:46: CostFinalize. Computing space requirements
    Action start 22:33:46: CostFinalize.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: Condition
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
    MSI (c) (64:B0) [22:33:46:930]: Target path resolution complete. Dumping Directory table...
    MSI (c) (64:B0) [22:33:46:930]: Note: target paths subject to change (via custom actions or browsing)
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 22:33:46: CostFinalize. Return value 1.
    MSI (c) (64:B0) [22:33:46:930]: Doing action: MigrateFeatureStates
    Action 22:33:46: MigrateFeatureStates. Migrating feature states from related applications
    Action start 22:33:46: MigrateFeatureStates.
    Action ended 22:33:46: MigrateFeatureStates. Return value 0.
    MSI (c) (64:B0) [22:33:46:930]: Skipping action: PatchWelcome (condition is false)
    MSI (c) (64:B0) [22:33:46:930]: Doing action: InstallWelcome
    Action 22:33:46: InstallWelcome.
    Action start 22:33:46: InstallWelcome.
    Action 22:33:46: InstallWelcome. Dialog created
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (64:D8) [22:33:46:946]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: BindImage
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: ProgId
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: PublishComponent
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: SelfReg
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Extension
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Font
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Shortcut
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Class
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: TypeLib
    MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2727 2:
    Action ended 22:33:48: InstallWelcome. Return value 1.
    MSI (c) (64:B0) [22:33:48:430]: Skipping action: SetupResume (condition is false)
    MSI (c) (64:B0) [22:33:48:430]: Skipping action: MaintenanceWelcome (condition is false)
    MSI (c) (64:B0) [22:33:48:430]: Doing action: SetupProgress
    Action 22:33:48: SetupProgress.
    Action start 22:33:48: SetupProgress.
    Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    Action 22:33:48: SetupProgress. Dialog created
    Action ended 22:33:48: SetupProgress. Return value 1.
    MSI (c) (64:B0) [22:33:48:477]: Doing action: ExecuteAction
    Action 22:33:48: ExecuteAction.
    Action start 22:33:48: ExecuteAction.
    MSI (c) (64:B0) [22:33:48:477]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (c) (64:B0) [22:33:48:477]: Grabbed execution mutex.
    MSI (c) (64:B0) [22:33:48:477]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (64:B0) [22:33:48:477]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\__Download\" USERNAME="Jasper" CLIENTPROCESSID="3940" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop\__Download"  ADDLOCAL=FlashPlayerAXInstaller
    MSI (s) (F8:E8) [22:33:48:493]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi
    MSI (s) (F8:E8) [22:33:48:493]: Grabbed execution mutex.
    MSI (s) (F8:C8) [22:33:48:493]: Resetting cached policy values
    MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'Debug' is 0
    MSI (s) (F8:C8) [22:33:48:493]: ******* RunEngine:
               ******* Action: INSTALL
    MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109110000000000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109110000000000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109440090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109440090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109510090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109510090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109511090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109511090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109610090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109610090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109611090400100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109611090400100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109711090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109711090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109810090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109810090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109910090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109910090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
    MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
    MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
    MSI (s) (F8:C8) [22:33:48:508]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
    MSI (s) (F8:C8) [22:33:48:508]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
    MSI (s) (F8:C8) [22:33:48:508]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
    MSI (s) (F8:C8) [22:34:43:743]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 394.
    MSI (s) (F8:C8) [22:34:43:743]: File will have security applied from OpCode.
    MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit.msi' against software restriction policy
    MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi has a digital signature
    MSI (s) (F8:C8) [22:34:44:524]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (s) (F8:C8) [22:34:44:524]: End dialog not enabled
    MSI (s) (F8:C8) [22:34:44:524]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64 bit.msi
    MSI (s) (F8:C8) [22:34:44:524]: Package we're running from ==> C:\Windows\Installer\869bf.msi
    MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (F8:C8) [22:34:44:524]: MSCOREE not loaded loading copy from system32
    MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'TransformsSecure' is 0
    MSI (s) (F8:C8) [22:34:44:524]: User policy value 'TransformsAtSource' is 0
    MSI (s) (F8:C8) [22:34:44:524]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisablePatch' is 0
    MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableLUAPatching' is 0
    MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (s) (F8:C8) [22:34:44:524]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
    MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (F8:C8) [22:34:44:540]: Transforms are not secure.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
    MSI (s) (F8:C8) [22:34:44:540]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\__Download\ USERNAME=Jasper CLIENTPROCESSID=3940 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
    MSI (s) (F8:C8) [22:34:44:540]: Product Code passed to Engine.Initialize:           ''
    MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
    MSI (s) (F8:C8) [22:34:44:540]: Product not registered: beginning first-time install
    MSI (s) (F8:C8) [22:34:44:540]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
    MSI (s) (F8:C8) [22:34:44:540]: MSI_LUA: Credential prompt not required, user is an admin
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (s) (F8:C8) [22:34:44:540]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (s) (F8:C8) [22:34:44:540]: User policy value 'SearchOrder' is 'nmu'
    MSI (s) (F8:C8) [22:34:44:540]: Adding new sources is allowed.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:44:540]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (F8:C8) [22:34:44:540]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
    MSI (s) (F8:C8) [22:34:44:540]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableMsi' is 0
    MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (F8:C8) [22:34:44:540]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (F8:C8) [22:34:44:540]: Product installation will be elevated because user is admin and product is being installed per-machine.
    MSI (s) (F8:C8) [22:34:44:540]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
    MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'da7e3209e9117142ada46c8feb786c33'.
    MSI (s) (F8:C8) [22:34:44:540]: RESTART MANAGER: Session opened.
    MSI (s) (F8:C8) [22:34:44:540]: Engine has iefSecondSequence set to true.
    MSI (s) (F8:C8) [22:34:44:540]: TRANSFORMS property is now:
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
    MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
    MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
    MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
    MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
    MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
    MSI (s) (F8:C8) [22:34:44:586]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (s) (F8:C8) [22:34:44:602]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\869bf.msi'.
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_6 4bit.msi'.
    MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (s) (F8:C8) [22:34:44:602]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: PatchPackage
    MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'DisableRollback' is 0
    MSI (s) (F8:C8) [22:34:44:602]: User policy value 'DisableRollback' is 0
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: INSTALL
    Action 22:34:44: INSTALL.
    Action start 22:34:44: INSTALL.
    MSI (s) (F8:C8) [22:34:44:602]: Running ExecuteSequence
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: ISSetAllUsers
    Action 22:34:44: ISSetAllUsers.
    Action start 22:34:44: ISSetAllUsers.
    MSI (s) (F8:C8) [22:34:44:602]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 22:34:44: ISSetAllUsers. Return value 0.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: AppSearch
    Action 22:34:44: AppSearch. Searching for installed applications
    Action start 22:34:44: AppSearch.
    MSI (s) (F8:C8) [22:34:44:602]: Skipping AppSearch action: already done on client side
    Action ended 22:34:44: AppSearch. Return value 0.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: LaunchConditions
    Action 22:34:44: LaunchConditions. Evaluating launch conditions
    Action start 22:34:44: LaunchConditions.
    Action ended 22:34:44: LaunchConditions. Return value 1.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: FindRelatedProducts
    Action 22:34:44: FindRelatedProducts. Searching for related applications
    Action start 22:34:44: FindRelatedProducts.
    MSI (s) (F8:C8) [22:34:44:602]: Skipping FindRelatedProducts action: already done on client side
    Action ended 22:34:44: FindRelatedProducts. Return value 0.
    MSI (s) (F8:C8) [22:34:44:602]: Skipping action: CCPSearch (condition is false)
    MSI (s) (F8:C8) [22:34:44:602]: Skipping action: RMCCPSearch (condition is false)
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: ValidateProductID
    Action 22:34:44: ValidateProductID.
    Action start 22:34:44: ValidateProductID.
    Action ended 22:34:44: ValidateProductID. Return value 1.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostInitialize
    Action 22:34:44: CostInitialize. Computing space requirements
    Action start 22:34:44: CostInitialize.
    MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
    MSI (s) (F8:C8) [22:34:44:602]: Baseline: New baseline 11.2.202 from transaction.
    MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorted order Native: Order 0.
    MSI (s) (F8:C8) [22:34:44:602]: Baseline Data Table:
    MSI (s) (F8:C8) [22:34:44:602]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
    MSI (s) (F8:C8) [22:34:44:602]: Baseline File Table:
    MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: __MsiPatchFileList
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
    MSI (s) (F8:C8) [22:34:44:602]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
    Action ended 22:34:44: CostInitialize. Return value 1.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: FileCost
    Action 22:34:44: FileCost. Computing space requirements
    Action start 22:34:44: FileCost.
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Class
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Extension
    MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: TypeLib
    Action ended 22:34:44: FileCost. Return value 1.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: IsolateComponents
    Action 22:34:44: IsolateComponents.
    Action start 22:34:44: IsolateComponents.
    Action ended 22:34:44: IsolateComponents. Return value 0.
    MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostFinalize
    Action 22:34:44: CostFinalize. Computing space requirements
    Action start 22:34:44: CostFinalize.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Condition
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
    MSI (s) (F8:C8) [22:34:44:618]: Target path resolution complete. Dumping Directory table...
    MSI (s) (F8:C8) [22:34:44:618]: Note: target paths subject to change (via custom actions or browsing)
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TARGETDIR , Object: E:\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
    MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 22:34:44: CostFinalize. Return value 1.
    MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetARPINSTALLLOCATION
    Action 22:34:44: SetARPINSTALLLOCATION.
    Action start 22:34:44: SetARPINSTALLLOCATION.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 22:34:44: SetARPINSTALLLOCATION. Return value 1.
    MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetODBCFolders
    Action 22:34:44: SetODBCFolders. Initializing ODBC directories
    Action start 22:34:44: SetODBCFolders.
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
    Action ended 22:34:44: SetODBCFolders. Return value 0.
    MSI (s) (F8:C8) [22:34:44:618]: Doing action: MigrateFeatureStates
    Action 22:34:44: MigrateFeatureStates. Migrating feature states from related applications
    Action start 22:34:44: MigrateFeatureStates.
    MSI (s) (F8:C8) [22:34:44:618]: Skipping MigrateFeatureStates action: already done on client side
    Action ended 22:34:44: MigrateFeatureStates. Return value 0.
    MSI (s) (F8:C8) [22:34:44:618]: Doing action: InstallValidate
    Action 22:34:44: InstallValidate. Validating install
    Action start 22:34:44: InstallValidate.
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'da7e3209e9117142ada46c8feb786c33'.
    MSI (s) (F8:C8) [22:34:44:618]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (F8:C8) [22:34:44:618]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
    MSI (s) (F8:C8) [22:34:44:618]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (F8:C8) [22:34:44:618]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: BindImage
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Extension
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Font
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Class
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2727 2:
    MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: FilesInUse
    MSI (s) (F8:C8) [22:34:44:743]: Note: 1: 2727 2:
    Action ended 22:34:44: InstallValidate. Return value 1.
    MSI (s) (F8:C8) [22:34:44:743]: Doing action: RemoveExistingProducts
    Action 22:34:44: RemoveExistingProducts. Removing applications
    Action start 22:34:44: RemoveExistingProducts.
    Action ended 22:34:44: RemoveExistingProducts. Return value 1.
    MSI (s) (F8:C8) [22:34:44:743]: Doing action: InstallInitialize
    Action 22:34:44: InstallInitialize.
    Action start 22:34:44: InstallInitialize.
    MSI (s) (F8:C8) [22:34:44:743]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (F8:C8) [22:34:44:743]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (F8:C8) [22:34:44:743]: BeginTransaction: Locking Server
    MSI (s) (F8:C8) [22:34:44:743]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
    Action ended 22:34:48: InstallInitialize. Return value 1.
    MSI (s) (F8:C8) [22:34:48:727]: Skipping action: CallExeUninstaller (condition is false)
    MSI (s) (F8:C8) [22:34:48:727]: Doing action: MakePropsAvailable
    Action 22:34:48: MakePropsAvailable.
    Action start 22:34:48: MakePropsAvailable.
    MSI (s) (F8:C8) [22:34:48:727]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
    Action ended 22:34:48: MakePropsAvailable. Return value 1.
    MSI (s) (F8:C8) [22:34:48:743]: Doing action: AllocateRegistrySpace
    Action 22:34:48: AllocateRegistrySpace. Allocating registry space
    Action start 22:34:48: AllocateRegistrySpace.
    Action ended 22:34:48: AllocateRegistrySpace. Return value 1.
    MSI (s) (F8:C8) [22:34:48:743]: Doing action: ProcessComponents
    Action 22:34:48: ProcessComponents. Updating component registration
    Action start 22:34:48: ProcessComponents.
    MSI (s) (F8:C8) [22:34:48:743]: Note: 1: 2205 2:  3: MsiPatchCertificate
    MSI (s) (F8:C8) [22:34:48:743]: LUA patching is disabled: missing MsiPatchCertificate table
    MSI (s) (F8:C8) [22:34:48:743]: Resolving source.
    MSI (s) (F8:C8) [22:34:48:743]: Resolving source to launched-from source.
    MSI (s) (F8:C8) [22:34:48:743]: Setting launched-from source as last-used.
    MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
    MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
    MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
    MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
    MSI (s) (F8:C8) [22:34:48:743]: Determining source type
    MSI (s) (F8:C8) [22:34:48:743]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
    MSI (s) (F8:C8) [22:34:48:743]: Source path resolution complete. Dumping Directory table...
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
    MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
    Action 22:34:48: GenerateScript. Generating script operations for action:
    GenerateScript: Updating component registration
    Action ended 22:34:48: ProcessComponents. Return value 1.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishComponents
    Action 22:34:48: UnpublishComponents. Unpublishing Qualified Components
    Action start 22:34:48: UnpublishComponents.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: UnpublishComponents. Return value 0.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: MsiUnpublishAssemblies
    Action 22:34:48: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 22:34:48: MsiUnpublishAssemblies.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: MsiUnpublishAssemblies. Return value 0.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishFeatures
    Action 22:34:48: UnpublishFeatures. Unpublishing product features
    Action start 22:34:48: UnpublishFeatures.
    Action ended 22:34:48: UnpublishFeatures. Return value 1.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: StopServices
    Action 22:34:48: StopServices. Stopping services
    Action start 22:34:48: StopServices.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 22:34:48: StopServices. Return value 1.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: DeleteServices
    Action 22:34:48: DeleteServices. Deleting services
    Action start 22:34:48: DeleteServices.
    Action ended 22:34:48: DeleteServices. Return value 1.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterComPlus
    Action 22:34:48: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 22:34:48: UnregisterComPlus.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: Complus
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
    Action ended 22:34:48: UnregisterComPlus. Return value 0.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: SelfUnregModules
    Action 22:34:48: SelfUnregModules. Unregistering modules
    Action start 22:34:48: SelfUnregModules.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
    Action ended 22:34:48: SelfUnregModules. Return value 1.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterTypeLibraries
    Action 22:34:48: UnregisterTypeLibraries. Unregistering type libraries
    Action start 22:34:48: UnregisterTypeLibraries.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
    Action ended 22:34:48: UnregisterTypeLibraries. Return value 0.
    MSI (s) (F8:C8) [22:34:48:836]: Doing action: RemoveODBC
    Action 22:34:48: RemoveODBC. Removing ODBC components
    Action start 22:34:48: RemoveODBC.
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
    MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2711 2: ODBCDriverManager
    1: Removing ODBC components
    MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2711 2: ODBCDriverManager64
    Action ended 22:34:48: RemoveODBC. Return value 1.
    MSI (s) (F8:C8) [22:34:48:852]: Doing action: UnregisterFonts
    Action 22:34:48: UnregisterFonts. Unregistering fonts
    Action start 22:34:48: UnregisterFonts.
    MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2205 2:  3: Font
    MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
    Action ended 22:34:48: UnregisterFonts. Return value 1.
    MSI (s) (F8:C8) [22:34:48:868]: Doing action: RemoveRegistryValues
    Action 22:34:48: RemoveRegistryValues. Removing system registry values
    Action start 22:34:48: RemoveRegistryValues.
    Action ended 22:34:48: RemoveRegistryValues. Return value 1.
    MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterClassInfo
    Action 22:34:48: UnregisterClassInfo. Unregister class servers
    Action start 22:34:48: UnregisterClassInfo.
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Class
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: UnregisterClassInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterExtensionInfo
    Action 22:34:48: UnregisterExtensionInfo. Unregistering extension servers
    Action start 22:34:48: UnregisterExtensionInfo.
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Extension
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: UnregisterExtensionInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterProgIdInfo
    Action 22:34:48: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 22:34:48: UnregisterProgIdInfo.
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: UnregisterProgIdInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterMIMEInfo
    Action 22:34:48: UnregisterMIMEInfo. Unregistering MIME info
    Action start 22:34:48: UnregisterMIMEInfo.
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: MIME
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: UnregisterMIMEInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveIniValues
    Action 22:34:48: RemoveIniValues. Removing INI file entries
    Action start 22:34:48: RemoveIniValues.
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
    Action ended 22:34:48: RemoveIniValues. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveShortcuts
    Action 22:34:48: RemoveShortcuts. Removing shortcuts
    Action start 22:34:48: RemoveShortcuts.
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
    Action ended 22:34:48: RemoveShortcuts. Return value 0.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveEnvironmentStrings
    Action 22:34:48: RemoveEnvironmentStrings. Updating environment strings
    Action start 22:34:48: RemoveEnvironmentStrings.
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Environment
    MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
    Action ended 22:34:48: RemoveEnvironmentStrings. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveDuplicateFiles
    Action 22:34:48: RemoveDuplicateFiles. Removing duplicated files
    Action start 22:34:48: RemoveDuplicateFiles.
    Action ended 22:34:48: RemoveDuplicateFiles. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveFolders
    Action 22:34:48: RemoveFolders. Removing folders
    Action start 22:34:48: RemoveFolders.
    Action ended 22:34:48: RemoveFolders. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: CreateFolders
    Action 22:34:48: CreateFolders. Creating folders
    Action start 22:34:48: CreateFolders.
    CreateFolders: Folder: Creating folders
    Action ended 22:34:48: CreateFolders. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: MoveFiles
    Action 22:34:48: MoveFiles. Moving files
    Action start 22:34:48: MoveFiles.
    Action ended 22:34:48: MoveFiles. Return value 1.
    MSI (s) (F8:C8) [22:34:48:899]: Doing action: InstallFiles
    Action 22:34:48: InstallFiles. Copying new files
    Action start 22:34:48: InstallFiles.
    MSI (s) (F8:C8) [22:34:48:915]: Dumping binary patch manager data...
    MSI (s) (F8:C8) [22:34:48:915]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
    InstallFiles: File: Copying new files,  Directory: ,  Size:
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiSFCBypass
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
    MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: PatchPackage
    Action ended 22:34:48: InstallFiles. Return value 1.
    MSI (s) (F8:C8) [22:34:48:946]: Doing action: NewCustomAction1
    Action 22:34:48: NewCustomAction1.
    Action start 22:34:48: NewCustomAction1.
    NewCustomAction1:
    Action ended 22:34:48: NewCustomAction1. Return value 1.
    MSI (s) (F8:C8) [22:34:48:946]: Doing action: PatchFiles
    Action 22:34:48: PatchFiles. Patching files
    Action start 22:34:48: PatchFiles.
    Action ended 22:34:48: PatchFiles. Return value 1.
    MSI (s) (F8:C8) [22:34:48:946]: Doing action: DuplicateFiles
    Action 22:34:48: DuplicateFiles. Creating duplicate files
    Action start 22:34:48: DuplicateFiles.
    Action ended 22:34:48: DuplicateFiles. Return value 1.
    MSI (s) (F8:C8) [22:34:48:946]: Doing action: BindImage
    Action 22:34:48: BindImage. Binding executables
    Action start 22:34:48: BindImage.
    Action ended 22:34:48: BindImage. Return value 1.
    MSI (s) (F8:C8) [22:34:48:946]: Doing action: CreateShortcuts
    Action 22:34:48: CreateShortcuts. Creating shortcuts
    Action start 22:34:48: CreateShortcuts.
    CreateShortcuts: Shortcut: Creating shortcuts
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Shortcut
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 22:34:48: CreateShortcuts. Return value 0.
    MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterClassInfo
    Action 22:34:48: RegisterClassInfo. Registering class servers
    Action start 22:34:48: RegisterClassInfo.
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Class
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 22:34:48: RegisterClassInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterExtensionInfo
    Action 22:34:48: RegisterExtensionInfo. Registering extension servers
    Action start 22:34:48: RegisterExtensionInfo.
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Extension
    MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 22:34:48: RegisterExtensionInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterProgIdInfo
    Action 22:34:48: RegisterProgIdInfo. Registering program identifiers
    Action start 22:34:48: RegisterProgIdInfo.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ProgId
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 22:34:48: RegisterProgIdInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterMIMEInfo
    Action 22:34:48: RegisterMIMEInfo. Registering MIME info
    Action start 22:34:48: RegisterMIMEInfo.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: MIME
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
    Action ended 22:34:48: RegisterMIMEInfo. Return value 0.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteRegistryValues
    Action 22:34:48: WriteRegistryValues. Writing system registry values
    Action start 22:34:48: WriteRegistryValues.
    WriteRegistryValues: Key: Writing system registry values, Name: , Value:
    Action ended 22:34:48: WriteRegistryValues. Return value 1.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteIniValues
    Action 22:34:48: WriteIniValues. Writing INI file values
    Action start 22:34:48: WriteIniValues.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: IniFile
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile `.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
    Action ended 22:34:48: WriteIniValues. Return value 1.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteEnvironmentStrings
    Action 22:34:48: WriteEnvironmentStrings. Updating environment strings
    Action start 22:34:48: WriteEnvironmentStrings.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Environment
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
    Action ended 22:34:48: WriteEnvironmentStrings. Return value 1.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterFonts
    Action 22:34:48: RegisterFonts. Registering fonts
    Action start 22:34:48: RegisterFonts.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Font
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
    Action ended 22:34:48: RegisterFonts. Return value 1.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: InstallODBC
    Action 22:34:48: InstallODBC. Installing ODBC components
    Action start 22:34:48: InstallODBC.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager64
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDriver
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`Fil eName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCTranslator
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,` Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDataSource
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registr ation` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
    Action ended 22:34:48: InstallODBC. Return value 0.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterTypeLibraries
    Action 22:34:48: RegisterTypeLibraries. Registering type libraries
    Action start 22:34:48: RegisterTypeLibraries.
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
    Action ended 22:34:48: RegisterTypeLibraries. Return value 0.
    MSI (s) (F8:C8) [22:34:48:977]: Doing action: SelfRegModules
    Action 22:34:48: SelfRegModules. Registering modules
    Action start 22:34:48: SelfRegModules.
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Actio n`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
    Action ended 22:34:48: SelfRegModules. Return value 1.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterComPlus
    Action 22:34:48: RegisterComPlus. Registering COM+ Applications and Components
    Action start 22:34:48: RegisterComPlus.
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: Complus
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
    Action ended 22:34:48: RegisterComPlus. Return value 0.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: InstallServices
    Action 22:34:48: InstallServices. Installing new services
    Action start 22:34:48: InstallServices.
    MSI (s) (F8:C8) [22:34:48:993]: Detected older ServiceInstall table schema
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceInstall
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`Erro rControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`Comp onentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
    Action ended 22:34:48: InstallServices. Return value 1.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: StartServices
    Action 22:34:48: StartServices. Starting services
    Action start 22:34:48: StartServices.
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 22:34:48: StartServices. Return value 1.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterUser
    Action 22:34:48: RegisterUser. Registering user
    Action start 22:34:48: RegisterUser.
    RegisterUser: Registering user
    Action ended 22:34:48: RegisterUser. Return value 1.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterProduct
    Action 22:34:48: RegisterProduct. Registering product
    Action start 22:34:48: RegisterProduct.
    RegisterProduct: Registering product
    MSI (s) (F8:C8) [22:34:48:993]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
    Action ended 22:34:48: RegisterProduct. Return value 1.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: PublishComponents
    Action 22:34:48: PublishComponents. Publishing qualified components
    Action start 22:34:48: PublishComponents.
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 22:34:48: PublishComponents. Return value 0.
    MSI (s) (F8:C8) [22:34:48:993]: Doing action: MsiPublishAssemblies
    Action 22:34:49: MsiPublishAssemblies. Publishing assembly information
    Action start 22:34:49: MsiPublishAssemblies.
    MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 22:34:49: MsiPublishAssemblies. Return value 0.
    MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishFeatures
    Action 22:34:49: PublishFeatures. Publishing product features
    Action start 22:34:49: PublishFeatures.
    PublishFeatures: Feature: Publishing product features
    Action ended 22:34:49: PublishFeatures. Return value 1.
    MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishProduct
    Action 22:34:49: PublishProduct. Publishing product information
    Action start 22:34:49: PublishProduct.
    1: Publishing product information
    Action ended 22:34:49: PublishProduct. Return value 1.
    MSI (s) (F8:C8) [22:34:49:024]: Skipping action: ScheduleReboot (condition is false)
    MSI (s) (F8:C8) [22:34:49:024]: Doing action: InstallFinalize
    Action 22:34:49: InstallFinalize.
    Action start 22:34:49: InstallFinalize.
    MSI (s) (F8:C8) [22:34:49:024]: Running Script: C:\Windows\Installer\MSI7D49.tmp
    MSI (s) (F8:C8) [22:34:49:024]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
    MSI (s) (F8:C8) [22:34:49:024]: Machine policy value 'DisableRollback' is 0
    MSI (s) (F8:C8) [22:34:49:086]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
    MSI (s) (F8:C8) [22:34:49:086]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082963033,LangId=1 033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVers ion=4,ScriptAttributes=1)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},Product Name=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language =1033,Version=184680650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPROD UCTICON.exe,,PackageCode={56994055-C101-488E-A9CB-CF207652B759},,,Inst anceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=Removing backup files,CleanupTemplate=File: [1])
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=0,)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=1,)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    Action 22:34:49: ProcessComponents. Updating component registration
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633}, KeyPath=C:\Windows\system32\Macromed\Flash\,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F}, KeyPath=C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe,State=3,,Dis k=1,SharedDllRefCount=1,BinaryType=1)
    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
    Action 22:34:49: RemoveODBC. Removing ODBC components
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=0)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=1)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    Action 22:34:49: CreateFolders. Creating folders
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
    CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    Action 22:34:49: InstallFiles. Copying new files
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
    MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetTargetFolder(Folder=C:\Users\Admin\AppData\Local\Temp\)
    MSI (s) (F8:C8) [22:34:49:118]: Executing op: SetSourceFolder(Folder=1\Temp\)
    MSI (s) (F8:C8) [22:34:49:118]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileNa me=C:\Windows\Installer\869bf.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (s) (F8:C8) [22:34:49:118]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=Install AX64.exe,DestName=InstallAX64.exe,Attributes=16384,FileSize=8767136,Pe rTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=11.2.202.228,Languag e=1033,InstallMode=58982400,,,,,,,)
    MSI (s) (F8:C8) [22:34:49:118]: File: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
    MSI (s) (F8:C8) [22:34:49:118]: Source for file 'InstallAX64.exe' is compressed
    InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Admin\AppData\Local\Temp\,  Size: 8767136
    MSI (s) (F8:C8) [22:34:49:290]: Executing op: CacheSizeFlush(,)
    MSI (s) (F8:C8) [22:34:49:290]: Executing op: ActionStart(Name=NewCustomAction1,,)
    Action 22:34:49: NewCustomAction1.
    MSI (s) (F8:C8) [22:34:49:290]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C :\Users\Admin\AppData\Local\Temp\InstallAX64.exe,Target=-install -msi,)
    CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
    MSI (s) (F8:C8) [22:34:57:066]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
    Info 2835.The control ErrorIcon was not found on dialog SetupError.
    Apr 12, 2012 9:14 PM   in reply to Darkmoon2010
    Now it worked!! Just reapplied the steps again. Thank you for the help!
