Installation program of adobe flash player on windows 7 - General Installation Error
Apr 6, 2012 11:42 AM
Tags: #windows #failed #flash_player #64bit #flash_player_11 #installation_failure
I cannot install flash player on a machine (running on windows 7 - 64 bits)
This is the error message that I get when progress bar reaches 50%: General Installation Error
Machine Details :
OS: Windows 7 64 bit
Tried installing the 64 bit version of flash player" install_flash_player_11_plugin_64bit.exe"  - Same problem
Tried uninstalling (based on this: http://forums.adobe.com/message/4041846#4041846) - Can't run uninstaller, not able to start the uninstaller software (It gives a blank error message pop window).
Tried running the exe file as "Run as admin" - Still same problem
Based on this: http://forums.adobe.com/message/4241994
I deleted flash folder from both locations:
C:\Windows\system32\Macromed\Flash\ (DELETED "Flash" folder)
C:\Windows\SysWOW64\ Macromed\Flash\ (DELETED "Flash" folder)
Still same problem
Please advise.
  • Chris Campbell
    May 4, 2010
    Apr 6, 2012 12:16 PM   in reply to helloflash123
    Can you post your flashinstall.log file?
    Where do I find the Flash Player installation log on Windows?
  • Chris Campbell
    May 4, 2010
    Apr 6, 2012 12:21 PM   in reply to helloflash123
    It sounds like you've done a clean install, though I'm posting a link just in case you missed anything.  I'm hoping the installer log sheds some light on what is failing.  You might also want to try to create a new, temporary, admin account and try installing from there.
    How do I do a clean install of Flash Player?
    Apr 6, 2012 8:26 PM   in reply to helloflash123
    After you run the uninstaller (or attempt to run the uninstaller), is there a FlashInstall.log file in either C:\Windows\System32\Macromed\Flash and/or C:\Windows\Syswow64\Macromed\Flash ?
    If so, can you list the contents of these files?
    Also, are there any other files in these folders?
    Apr 7, 2012 1:06 PM   in reply to Pat Willener
    I am having basically the same issue.  Installed Windows 7 recently, tried to install Adobe Flash Player (both 32 and 64), and it would get to about 49% then installation error.  Tried multiple times and ways but nothing worked.
  • Chris Campbell
    May 4, 2010
    Apr 9, 2012 2:53 PM   in reply to helloflash123
    Just out of curiosity, could you try running though the steps outlined in this FAQ and then try installing Flash Player again?
    How do I fix Windows permission problems with Flash Player?
    Apr 9, 2012 5:55 PM   in reply to helloflash123
    helloflash123 wrote:
    0000 [F] 00001004 broker
    I have definitely never seen this fatal error message; I hope someone from the installer team gets to have a look at it.
    Meanwhile, one last suggestion: can you try to run the MSI installers?
