I am trying to find out why my pages panel will not respond to the mouse. The page thumbnails seem locked or frozen. The pages panel menu works fine, but I can’t navigate the pages by using the thumbnails on the pages panel.
try resetting preferences:=
These are normally hidden files, so you will need to set your system to show them. They will be found in various places depending on the OS, and the version of InDesign.
InDesign Defaults:
Windows : C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
Windows Vista or Windows 7: C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
InDesign SavedData:
Windows : C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
Windows Vista or Windows 7: C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
I'm not entirely clear waht version of Windows you are using, but it sounds like Windows 2007 Server, which I do not believe is an officially supported OS, which menas it may run, but no testing was done during development and there may be some things that don't work, and thers is no technical support available.
With that in mind, take a look at InDesign tools and panels don't respond to mouse clicks (Windows 7/Vista) and see if anything there applies to your setup.
Yes, it works!! I changed the screen resolution to 100% and the pages panel works now, as well as the tool icons (previously they were not responding to mouse click….I had to use the keyboard commands to select them.) I guess I’ll have to get new glasses now, as I had my screen resolution set to a higher DPI so that I could see better!
Thanks to you and Peter for your help!!
North America
Asia Pacific
