bbenedict07
How to enable place a signaure feature
Apr 6, 2012 4:25 PM
Tags: #signature #acrobat_pro_9
I have a PDF form and I want people who view the form and enter data to also be able to use the Place a Signature feature to sign the form.  I created the form from a base PDF and made some minor edits to fields (date formatting, calculating a total).  I added the extended PDF features.  But when I open the form in reader, I still get the warning that says users can not add text or place a signature on the form because of the security settings.  I am using Acrobat 9 Pro to create the form.  Let me answer a few more questions based on what I have already read...
I do not want to use passwords in any way.  I do not need to protect the form in any way.
I do not want to explore digitial signatures.  If I can't get this to work, people will just print the form and sign with a pen.
I am sure I have the extended features becuase when I open the file again in Acrobat Pro 9 and try to add the extended features, I get a message that tells me this is already done.
I want to create a form that when opened in reader has the Place a Signature item enabled.  Please provide precise step-by-step instructions.
Thanks.
  • George Johnson
    Aug 11, 2002
    Apr 6, 2012 7:39 PM   in reply to bbenedict07
    I don't get what you want. The Place Signature feature is used to add a digital signature and should be available on the "Extended > Extended Features" panel, but you say you don't want to "explore digital signatures". Can you calrify?
    Apr 7, 2012 3:08 AM   in reply to bbenedict07
    I guess bbenedict07 is talking about the "Place signature" option in Sign pane? Is that right? All Sign pane options are disabled for Acroforms/XFA forms/Reader Extended PDFs in Reader 10.1.2.
    Apr 17, 2012 1:12 AM   in reply to bbenedict07
    Open PDF in Acrobat Pro, go to Tools->Forms->Edit. Go to edit mode and add a digital signature field from 'Add new field' option. Close Form editing and save the PDF. Save the PDF as Reader-Extended file so that Reader users are able to sign it from Reader. For this, in Acrobat Pro, go to File->Save As->Reader Extended PDF->Enable Additional features and save. Now if you open this saved file in Reader, you should be able to sign it from the Extended pane.
    Hope that helps!
